Home » Archived » M2M (model-to-model transformation) » [ATL] performance tips
[ATL] performance tips [message #70523] Sat, 05 January 2008 09:55 Go to next message
Hi all, I have some problem of performance during the execution of ATL
higher-order transformations: they take about one/two minutes to finish.
My ATL transformations are composed of:
- amw and emf handlers for input models
- approximately 20 rules
- 20 helpers
- 1 entrypoint rule
- 1 endpoint rule (with 20/30 calls to the inject("OUT", "ebnf2", ...)
method)
- about 30/35 calls to thisModule.ResolveTemp
- almost every rule contains a call to some element of the input metamodels
(i.e. MOF!EModelElement.getInstanceById(modelName,classifierID))
- about 10 calls to the inject("OUT", "ebnf2", ...) method
Does anyone know how ATL virtual machine handles such type of
transformation, where is the bottleneck, and how to make a better
performance tuning of my transformation?
Thank you, Ivano
Re: [ATL] performance tips [message #70619 is a reply to message #70523] Mon, 07 January 2008 03:47 Go to previous messageGo to next message
--------------030406000401030203050705
Have you tried to run it on the new emf VM ?
http://wiki.eclipse.org/ATL_VM_Testing
Stephane
Ivano a
Re: [ATL] performance tips [message #70718 is a reply to message #70619] Tue, 08 January 2008 03:21 Go to previous message
I will give it a try, thank you!
Ivano
Previous Topic:[ATL] Reference output model elements
Next Topic:[ATL]UML Transformation
Current Time: Sun Nov 16 03:53:54 EST 2025
Powered by FUDForum. Page generated in 0.05914 seconds
