Home » Modeling » TMF (Xtext) » generated EPackage's Literals not generated; why?
generated EPackage's Literals not generated; why? [message #705803] Sat, 30 July 2011 07:38 Go to next message
The EPackage interface generated by xtext on my dsl ('MyDslPackage extends EPackage' does not contain the 'Literals' public static field and so the whole project fails to compile.
There are no error messages or standard output that helps me understand why.
I commented out some of my dsl until it was generated again. In this way, I hoped to find some error on a line of my grammar. No, I didn't. Instead, I have the opinion that the problem is related to the number of grammar rules; I don't have the option to reduce the number of rules.
What can I look for to debug this issue?
(no subject) [message #705810 is a reply to message #705803] Sat, 30 July 2011 07:52 Go to previous messageGo to next message
Are you sure that the "Literals Interface" property in your genmodel is
"true".
Xtext's ability to auto-generate an Ecore model is very convenient when
starting, but once your grammar grows or you want more stability for
evolution it can be better to define the model manually and import it
into Xtext.
Ed Willink
> understand why.
> number of rules.
(no subject) [message #705934 is a reply to message #705803] Sat, 30 July 2011 11:46 Go to previous messageGo to next message
Hi John,
if your EPackage becomes too large, the Literals may be skipped by the
genmodel generator because it may exceed the maximum size for class
files. You may want to use
MyDslPackage.eInstance.getClassName_FeatureName instead.
Sebastian
> why.
Re: (no subject) [message #706042 is a reply to message #705934] Sat, 30 July 2011 15:30 Go to previous messageGo to next message
Excellent. Thanks for your time for responding.
Ed: Just for the sake of completing my question, I should say that I took the default setting for 'use Literal Interface'. In early stages of developing the grammar, things worked fine. I have looked in my genmodel for 'use Literals Interface' and don't see it. So, I think the default is active and I guess that default is 'true'.
"Xtext's ability to auto-generate an Ecore model is very convenient when starting, but once your grammar grows or you want more stability for evolution it can be better to define the model manually and import it into Xtext"
This comment is more than I can handle right now. Count me as still starting. I've invested time to learn the xtext grammar -- now I don't need it? I say: Huh? I didn't see that coming.
Sebastion: Ok. This explanation makes sense. How can I tell the generator to use MyDslPackage.eInstance.getClassName_FeatureName when it generates: AbstractMyDslSemanticSequencer? There are multitude of references to Literals in this file. Do you suggest I edit manually?
Re: (no subject) [message #706050 is a reply to message #706042] Sat, 30 July 2011 15:48 Go to previous messageGo to next message
Oh, also: What number (or range) of Rules do you think is 'too big' for either: 1) this effect of not generating Literals occurs, and 2) things are more supportable by editing ecore directly. I have about 130.
Re: (no subject) [message #706090 is a reply to message #706050] Sat, 30 July 2011 16:38 Go to previous messageGo to next message
John,
As a point of reference, when a GenModel (and hence a GenPackage) are
first created, GenPackageImpl.isBigModel calculates how many things are
in the model:
return (classes + supers + features + operations + parameters +
exceptions + enums + literals + datatypes) > 500;
This gives it a rough idea of how many things in the Literals interface
and when it's likely to be too many (along with whether it's likely the
package initialization logic will be too large).
boolean isBigModel = isBigModel();
setLoadInitialization(isBigModel);
setLiteralsInterface(!isBigModel);
Re: (no subject) [message #706144 is a reply to message #706042] Sat, 30 July 2011 18:33 Go to previous messageGo to next message
Hi John,
the invalid Literals access is already fixed in the latest nightly
builds. Please expect 2.0.1 to be out in a couple of days. Meanwhile,
you could disable the SerializerFragment in the workflow and use the
ParsetreeConstructorFragment instead.
Sebastian
> Quote:
>> it into Xtext"
Re: (no subject) [message #706199 is a reply to message #706144] Sat, 30 July 2011 21:00 Go to previous message
Thank you.
Previous Topic:[Xtext2.0] Validation
Next Topic:[Xtend] Increase a postfix in a for loop
Current Time: Fri Nov 07 22:57:43 EST 2025
Powered by FUDForum. Page generated in 0.05368 seconds
