nested packages [message #705254] |
Fri, 29 July 2011 12:16  |
Suppose I have package A and package B.
I would like to have package C as a container package. Package C will
basically will a wrapper package for A and B
ti.packageC
ti.packageC.packageA
ti.packageC.packageB
packageA has packageA.h as interface
packageB has packageB.h as interface
I assume that if I write as below, I will pull in packageA and packageB
if a package requires packageC.
- I write packageC.h to include ti/packageA.h and ti/packageB.h
- I write packageC.xdc with requires statements for ti.packageA and
ti.packageB
Can you confirm?
Patrick Geremia
Re: nested packages [message #705345 is a reply to message #705254] |
Fri, 29 July 2011 14:46   |
RTSC consistently uses the package path exclusively to locate all files;
C headers, JavaScript files, libraries, ... In addition, all references
consistently use the package name prefix to ensure files with the same
base name in two different packages are never confused.
So, C sources that #include <ti/packageC/packageA/package.h> will
include the first file named 'ti/packageC/packageA/package.h' found by
successively appending this name to each directory appearing in the
package path.
Since packages can be installed and found in any directory on the
package path, the fact that a package shares a common prefix does not
imply any "container" relationship between the two. For example, if you
build a release of pkgC, the package pkgC's archive will _not_ contain
pkgA of pkgB. The package name is mostly just a namespace.
'requires' statements do not affect the package path. The 'requires'
declaration affects
1. whether a package's libraries will be added to the list of
libraries to link with; if pkgA requires pkgC and your app
uses pkgA, pkgC's libraries will be automatically added
to the generated linker command file
2. the ordering of libraries in the the generated linker command
files; if pkgA requires pkgB, pkgB's library is linked after
pkgA's library
3. the order in which packages are built by the xdc tool (when
using -PD option)
> ti.packageC
> ti.packageB
> Can you confirm?
> Regards
> Patrick Geremia
Re: nested packages [message #707104 is a reply to message #705345] |
Mon, 01 August 2011 04:43  |
Understood. Thanks.
> package path.
> declaration affects
> pkgA's library
> using -PD option)
>> ti.packageC
>> ti.packageB
>> Can you confirm?
>> Regards
>> Patrick Geremia
FUDForum. Page generated in 0.25703 seconds
