[Eugenia] Diagram partitioning [message #705186] |
Fri, 29 July 2011 10:43  |
I am using Eugenia to create my GMF editor and I need to partition my diagram. What I need to do is to create new diagram which is based on the same editing domain (same domain model) when the user double clicks a specific node. I found information in GMF forum and other articles which give instructions on how to do that (which is not trivial and I didn't manage yet to what I need). The question is, did anyone try to do something similar using Eugenia? I would really appreciate if someone share his/her experience with me.
Thanks in advance,
Aris
Re: [Eugenia] Diagram partitioning [message #750589 is a reply to message #716099] |
Tue, 25 October 2011 17:11  |
Hi Aris, Dimitris,
I also work with EuGENia, and I have the same problen than you. I need to partition my diagram. Did you solve the problem? I tried to use the example attached in the bug 295271 (sorry I cannot use links yet) but I need more than one concepts which can be used as partitioning subdiagrams. This means, I need to support diagrams of different type (a parent diagram with various subdiagrams), which requires generating multiple sets of gmfxxx files.
Thanks in advance,
Jessica.
FUDForum. Page generated in 0.35181 seconds
