Home » Language IDEs » AspectJ » Declare parents in concrete aspect?
Declare parents in concrete aspect? [message #70428] Tue, 14 August 2007 10:21 Go to next message
Originally posted by: martin.frey.logicacmg.com
to make a long story short i have two aspects. A abstract, B concrete of A.
A defines a general PropertyChangeSupport handler but it should not define
which classes should get woven at loadtime. Thats why the concrete aspect B
is there to define this.
I don't know why this shouldnt work. Since other concrete aspects work
perfectly. Are there some known issues regarding the "declare parents"
functionality?
If i define the declare parents directly in BeanChangeDefinitions all works
as expected. But i want to be able to use this aspect for multiple plugins.
So i dont want to use a concrete aspect to define the within package stuff.
Did someone solve this problem already?
regards Martin
Here's the code of the two aspects.
public abstract aspect BeanChangeDefinitions {
// Add PropertyChangeSupport variable
private PropertyChangeSupport
PropertyChangeNotifier.propertyChangeSupport;
public void
PropertyChangeNotifier.addPropertyChangeListener(PropertyCha ngeListener
listener) {
propertyChangeSupport.addPropertyChangeListener(listener);
public void PropertyChangeNotifier.addPropertyChangeListener(String
propertyName, PropertyChangeListener listener) {
propertyChangeSupport.addPropertyChangeListener(propertyName ,
listener);
public void
PropertyChangeNotifier.removePropertyChangeListener(Property ChangeListener
listener) {
propertyChangeSupport.removePropertyChangeListener(listener) ;
public void PropertyChangeNotifier.removePropertyChangeListener(String
propertyChangeSupport.removePropertyChangeListener(propertyN ame,listener);
public void PropertyChangeNotifier.firePropertyChange(String
propertyName,Object oldValue, Object newValue) {
propertyChangeSupport.firePropertyChange(propertyName,
oldValue,newValue);
public void PropertyChangeNotifier.createPropertyChangeSupport() {
propertyChangeSupport = new PropertyChangeSupport(this);
private pointcut createBean() : execution(new(..)) && withinBean();
private pointcut propertyChange() : set(* *) && !set(static * *) &&
withinBean();
public abstract pointcut withinBean();
after() : propertyChange() {
String sigName = thisJoinPoint.getSignature().getName();
Object newValue = thisJoinPoint.getArgs()[0];
PropertyChangeNotifier bean = (PropertyChangeNotifier)
thisJoinPoint.getThis();
bean.firePropertyChange(sigName, "", newValue);
after() : createBean() {
bean.createPropertyChangeSupport();
public aspect ConcreteBeanChangeDefinitions extends BeanChangeDefinitions {
declare parents : models.* implements PropertyChangeNotifier;
public pointcut withinBean() : within(models.*);
Re: Declare parents in concrete aspect? [message #70448 is a reply to message #70428] Thu, 16 August 2007 05:11 Go to previous message
Never mind
I've solved this problem by using annotation based definitions.
"Martin Frey" <martin.frey@logicacmg.com> wrote in message
news:f9sdpa$9qf$1@build.eclipse.org...
> Hi
> A. A defines a general PropertyChangeSupport handler but it should not
> define which classes should get woven at loadtime. Thats why the concrete
> aspect B is there to define this.
> functionality?
> works as expected. But i want to be able to use this aspect for multiple
> plugins. So i dont want to use a concrete aspect to define the within
> package stuff.
> regards Martin
> public void
> listener) {
> listener);
> public void
> listener) {
> oldValue,newValue);
> withinBean();
Re: Declare parents in concrete aspect? [message #596315 is a reply to message #70428] Thu, 16 August 2007 05:11 Go to previous message
Never mind
> Hi
> functionality?
> package stuff.
> regards Martin
> public void
> listener) {
> listener);
> public void
> listener) {
> oldValue,newValue);
> withinBean();
Previous Topic:Declare parents in concrete aspect?
Next Topic:Deploy Aspectj plugin/fragment as part of a feature
Current Time: Thu Jul 24 23:00:29 EDT 2025
Powered by FUDForum. Page generated in 0.04600 seconds
