Home » Archived » Maven Integration (M2E) » No SCM connector For Subclipse ??
icon5.gif  No SCM connector For Subclipse ?? [message #698635] Tue, 19 July 2011 17:11 Go to next message
Hello all,
I downloaded Eclipse Indigo for EE developpers and I don't see any subclipse connector for m2eclipse.
Subversive SCM connector is the only one existing ???
Thanks in advance.
Re: No SCM connector For Subclipse ?? [message #702069 is a reply to message #698635] Mon, 25 July 2011 19:29 Go to previous messageGo to next message
You can check out the project using Subclipse. Afterwards, right click on the project and choose:
* Configure > Convert to Maven Project
* Maven > Update Project Configuration
* Maven > Update Dependencies
If you have a multi-module project and want Maven to recognize all the sub-modules, then after the above steps do:
* Delete the project from within Eclipse, BUT DO NOT DELETE FROM DISK!
* Choose menu File > Import > Maven > Existing Maven Project with your project
And Eclipse will automatically create a Maven enabled Java project for each module.
[Updated on: Mon, 25 July 2011 19:35] by Moderator
Re: No SCM connector For Subclipse ?? [message #703677 is a reply to message #702069] Wed, 27 July 2011 16:21 Go to previous messageGo to next message
Thanks for answer.
It was so easy with Subclipse scm connector pffff
Re: No SCM connector For Subclipse ?? [message #703690 is a reply to message #703677] Wed, 27 July 2011 16:33 Go to previous message
I find a solution explained in m2e bug tracker.
The sonatype Subclipse connector has been updated to work with indigo.
bug id : 352686
Previous Topic:Same issue with Indigo for Java
Next Topic:Disable M2E logging for indigo
Current Time: Sun Jul 20 21:48:40 EDT 2025
Powered by FUDForum. Page generated in 0.08842 seconds
