Home » Archived » BIRT » what is doing between a dataset afterOpen event and onFetch event?
what is doing between a dataset afterOpen event and onFetch event? [message #702242] Tue, 26 July 2011 02:10 Go to next message
I have a report and from the debug message, I found a dataset need 14 minutes (from 14:26 to 14:40) to transfer from afterOpen event to onFetch event.
I want to know what is doing between a dataset afterOpen event and the same dataset onFetch event? I feel 14 minutes is too long and do not know what is the report doing during this phase.
My birt designer version is 2.2.1.r221_v20070924
attach is the report, the problematic dataset is "SingleServerDiskUtilization_Unix"
sample debug message output from eclipsec.exe is as following
end of disk beforeOpen event
Disk afterOpen event : Tue Jul 26 2011 14:26:14 GMT+0800 (CST)
Disk onFetch event : Tue Jul 26 2011 14:40:39 GMT+0800 (CST)
Disk beforeClose event : Tue Jul 26 2011 14:40:40 GMT+0800 (CST)
Disk afterClose event : Tue Jul 26 2011 14:40:40 GMT+0800 (CST)
[Updated on: Tue, 26 July 2011 04:00] by Moderator
Re: what is doing between a dataset afterOpen event and onFetch event? [message #703234 is a reply to message #702242] Wed, 27 July 2011 06:37 Go to previous messageGo to next message
Anyone can help?
is the sql already completely run between dataset beforeOpen and dataset afteropen event? or is the sql still running after dataset afterOpen event?
Or between dataset afterOpen and onFetch event is the time to fill up the fields of the dataset after database data is fetched?
(no subject) [message #703420 is a reply to message #703234] Wed, 27 July 2011 10:35 Go to previous messageGo to next message
The order is like this:
jdbc open
Dataset beforeOpen event
jdbc new query
jdbc prepare query
Dataset afterOpen event
jdbc execute query - all results are returned here.
Dataset onFetch for each result
Jason
On 7/27/2011 6:37 AM, tong123123 wrote:
> Anyone can help?
Re: (no subject) [message #703469 is a reply to message #703420] Wed, 27 July 2011 11:48 Go to previous messageGo to next message
oh, that means the 14 minutes between dataset afterOpen events and onFetch events is used for execute the query?!!
if I extract the sql and run on database client, it need to run about 14 minutes? (I am at home now and cannot test this in office server).
Re: (no subject) [message #703518 is a reply to message #703469] Wed, 27 July 2011 12:38 Go to previous message
It is preparing the query to get metadata for column types and then
running the query. 14 minutes seems excessive. How complex is the query?
Jason
On 7/27/2011 11:48 AM, tong123123 wrote:
> Quote:
Previous Topic:Multiple Submit Buttons in Custom Parameter Page
Next Topic:Pentaho Metadata Editor as an ODA datasource
Current Time: Sat Jul 26 01:07:31 EDT 2025
Powered by FUDForum. Page generated in 0.04804 seconds
