Home » Eclipse Projects » Nebula » Questions about stability of certain widgets and usage in RCP application
Questions about stability of certain widgets and usage in RCP application [message #699589] Thu, 21 July 2011 17:10 Go to next message
I'm thinking about using a few of the Nebula widgets in an internal use RCP application that my team and I are developing.
I wanted to find out the stability of the widgets we are thinking about using (how stable, do they have maintainers, etc.), and how to best incorporate them into our tycho build and eventually put into our p2 repository for our RCP application.
We are considering using the widgets:
CalendarCombo
TableCombo
Grid
Please let me know what the current best practices are for incorporating the nebula widgets into an RCP application as well.
Thanks in advance,
Sharon
Re: Questions about stability of certain widgets and usage in RCP application [message #700138 is a reply to message #699589] Fri, 22 July 2011 17:58 Go to previous messageGo to next message
I can only comment on the grid which I'm more or less responsible for
and it is API stable. We are currently working on a release schedule
which will lead to a 1.0 marking this API stability also in version numbers.
Tom
Am 21.07.11 23:10, schrieb Sharon Snyder:
> CalendarCombo
> TableCombo
> Grid
> Thanks in advance,
> Sharon
Re: Questions about stability of certain widgets and usage in RCP application [message #702004 is a reply to message #700138] Mon, 25 July 2011 16:58 Go to previous messageGo to next message
Thanks for the reply. Can you tell me what is the currently accepted practice on including the nebula widgets in my RCP build? We have a tycho build set up and I'd like to be able to include this properly.
If you need more info...please let me know. Right now because the build page still says they are broken, I'm not sure how to proceed or where to get the latest builds.
Any info you can provide (pointers to current docs, etc.) would be appreciated!
Sharon
Re: Questions about stability of certain widgets and usage in RCP application [message #702026 is a reply to message #702004] Mon, 25 July 2011 17:10 Go to previous messageGo to next message
We have builds running on tycho see https://hudson.eclipse.org/hudson/
but we haveing had troubles publishing them when we worked on the build
that's why you can't download them from download.eclipse.org
You can find out build configuration in cvs.
Tom
Am 25.07.11 22:58, schrieb Sharon Snyder:
> appreciated!
> Sharon
Re: Questions about stability of certain widgets and usage in RCP application [message #702615 is a reply to message #702026] Tue, 26 July 2011 11:27 Go to previous messageGo to next message
Thanks Tom. I went to the web page and there seem to be 2 nebula widgets - xviewer and tableCombo being built, and the maven-nebula build. TableCombo has failed the last 4/5 builds. The CalendarCombo and Grid widgets do not appear to be there - or am I missing something?
I'm trying to convince my team that these widgets are useful, and we should be seriously considering them for our project....and because of the alpha status I'm having a tough time of it. This build situation is not helping my cause!
Please help!
Sharon
Re: Questions about stability of certain widgets and usage in RCP application [message #702649 is a reply to message #702615] Tue, 26 July 2011 12:09 Go to previous messageGo to next message
Let me correct that - Grid is in the main build - maven-nebula-1.0-nightly....but not calendarCombo. Any idea why it's not included in the build?
Sharon
Re: Questions about stability of certain widgets and usage in RCP application [message #702687 is a reply to message #702649] Tue, 26 July 2011 13:14 Go to previous messageGo to next message
What is the p2 repository URL I should reference in my build?
Re: Questions about stability of certain widgets and usage in RCP application [message #702702 is a reply to message #702687] Tue, 26 July 2011 13:40 Go to previous messageGo to next message
I'm afraid there's none yet. The main problem is that we don't have
people getting payed to do such work.
We are currently in the process to split nebula in 2 projects and once
this is done I'm going to set up a complete maven build.
I think the easiest for you might be to simply checkout nebula from CVS,
export it locally to a p2 repo and add it to your tycho as a locale p2-repo.
Tom
Am 26.07.11 19:14, schrieb Sharon Snyder:
Re: Questions about stability of certain widgets and usage in RCP application [message #702780 is a reply to message #702702] Tue, 26 July 2011 15:40 Go to previous messageGo to next message
Thanks Tom.
I understand that is a big problem - unfortunately it works against me in my argument, but hopefully I can show them how useful these 3 widgets are compared to the stock SWT widgets.
Sharon
Re: Questions about stability of certain widgets and usage in RCP application [message #702794 is a reply to message #702780] Tue, 26 July 2011 16:07 Go to previous messageGo to next message
Hi Sharon,
We are slowly improving and I can only speak for Grid (PShelf,PGroup)
which is very stable and if you need commercial support my company
provides support and bugfixing.
Tom
Am 26.07.11 21:40, schrieb Sharon Snyder:
> Thanks Tom.
> Sharon
Re: Questions about stability of certain widgets and usage in RCP application [message #702834 is a reply to message #702794] Tue, 26 July 2011 17:45 Go to previous message
I've now updated the build process and it creates a p2-repo now. See
https://hudson.eclipse.org/hudson/job/maven-nebula-1.0-nightly/lastSuccessfulBuild/artifact/org.eclipse.nebula.updatesite/target/site/
Tom
Am 26.07.11 22:07, schrieb Tom Schindl:
> Hi Sharon,
> Tom
>> Thanks Tom.
>> Thanks,
>> Sharon
Previous Topic:Nebula grid loads slowly when there are more than 200 columns on Ubuntu Linux
Next Topic:Miller Columns
Current Time: Wed Jul 23 02:44:23 EDT 2025
Powered by FUDForum. Page generated in 0.14425 seconds
