Home » Modeling » TMF (Xtext) » Duplicated Type Error
Duplicated Type Error [message #702283] Tue, 26 July 2011 03:22 Go to next message
Hello Everyone
Can you give me a hand please?
in myDsl, I have some Types as below;
LibraryModel:
  (types+=Type)*;
Type:
Comment1|NonEmpityLine|Version
Version:
   "@" name=Words ('=' DOUBLE)?
Words hidden ():
    	ID (WS ID)*
In the something.dsl file, I get Duplicate Type Error for version while I am typing version might be called more than one time e.g.
%comentss
@version=0.0
/////some code
@version=X
////some code
@version=2.2
////some code
PS: name "version" declared via content assist
Re: Duplicated Type Error [message #702291 is a reply to message #702283] Tue, 26 July 2011 03:33 Go to previous messageGo to next message
Version has a name feature the value of which will be used cross referencing. In the example all Versions are called "version" so there are duplicate names.
Do you want to have references to Version? If not, why call the feature name. If yes, you have to provide unique names (if you want referencing to work).
Alex
Re: Duplicated Type Error [message #702334 is a reply to message #702291] Tue, 26 July 2011 04:27 Go to previous messageGo to next message
How is it supposed to be than?
Version is just sort of information for user, it hasnt anything to do with code,
By the way, Thanks for your answer
Re: Duplicated Type Error [message #702344 is a reply to message #702334] Tue, 26 July 2011 04:47 Go to previous messageGo to next message
I don't know your language and what you want to do with it. If a version is only some info for the user then why not have
Version:'@' infoName=Words (versionNumber=DOUBLE)?;
It looks like you have a terminal rule for DOUBLE, it is better practice not to mess with terminals (if not necessary) and introduce datatype rules instead.
Alex
Re: Duplicated Type Error [message #702364 is a reply to message #702344] Tue, 26 July 2011 05:15 Go to previous messageGo to next message
Thank you so much , according your advice, I have declared the version
  Version:
  '@version=' (versionNumber=DOUBLE|'X' )?;
But i got a warning which is " The rule 'version' may be consumed without object instantiation.
Add an action to ensure object creation, e.g. '{version}'.
Does it matter do you think?
[Updated on: Tue, 26 July 2011 05:17] by Moderator
Re: Duplicated Type Error [message #702377 is a reply to message #702364] Tue, 26 July 2011 05:35 Go to previous messageGo to next message
the rule looks strange, either the version number is mandatory or you should move the "=" into the optional part. As to your question, it depends on what you want to do with your model. If you don't specify a versionNumber, no Version-Object will be created. That is, if your model looks like this
@version
@version
@version
and you "count" the versions in your model, the result will be 0. Anyway, I'd add the action, so that the model represents the input as far as possible
Version: {Version} '@version' ('=' versionNumber=(DOUBLE|'X'))?/*note the additional parentheses around Double and 'X', otherwise 'X' will not be stored as versionNumber, but maybe you wanted that*/
Alex
Re: Duplicated Type Error [message #702446 is a reply to message #702377] Tue, 26 July 2011 07:45 Go to previous messageGo to next message
Thanks a lot Alex
Now i have an other problem;
I have a type as below
tagTranslation:
	  {tagTranslation}
		'@translators' ('=' pattern1=myWords ) (','name1=myWords)? 	;
myWords hidden ():
    	myID (WS ID)*
terminal myID :
  	'^'?('a'..'z'|'A'..'Z'|'_'|'.'|'[]'|'()') ('a'..'z'|'A'..'Z'|'_'|'0'..'9'|'%')*
When I am coding in .mydsl file
@tagtranslators= spattern,wname
mismatched input ',' expecting ':'
- mismatched input '<EOF>' expecting ':'
- missing RULE_MYID at 'spattern'
[Updated on: Tue, 26 July 2011 07:49] by Moderator
Re: Duplicated Type Error [message #702458 is a reply to message #702446] Tue, 26 July 2011 07:52 Go to previous messageGo to next message
you did not give enough of the grammar. The error message indicates that there should be a colon somewhere, but none of the rules given contains one.
If possible, don't define a terminal myId but rather a datatype rule along with a value-converter that checks the correct syntax. It is well possible that input that you expect to be tokenised as ID will be myId instead.
It is never a good idea to have overlapping terminal definitions.
Alex
Re: Duplicated Type Error [message #702468 is a reply to message #702458] Tue, 26 July 2011 08:13 Go to previous messageGo to next message
Please excuse me for unclear question
Actually what i want to do is ;
i have special parameters names which contains some special characters such as "[,],%,|.."
@tagtranslators= [spa%ttern],(%nameID)
I tough if i define new terminal ID and modify it with these needed characters, I thought it will work,
Re: Duplicated Type Error [message #702478 is a reply to message #702468] Tue, 26 July 2011 08:26 Go to previous messageGo to next message
still, it is the question whether you want to solve that on the terminal level (for now, I don't recommend that) or on the parser level. How about something linke this
SpecialPatternSymbol: '[' | ']'|...;
Pattern: SpecialPatternSymbol? (ID SpecialPatternSymbol)* ID SpecialPatternSymbol?;
Of course this needs to be addapted to what your pattern really could look like.
Alex
Re: Duplicated Type Error [message #702525 is a reply to message #702478] Tue, 26 July 2011 09:47 Go to previous messageGo to next message
Hi again
I had so many errors until declaration which is below
Translation:
	 {Translation}
	'@translators'('=' pattern1=Characters )? (´,´ user=Characters)?
Characters hidden () :
 	ID(WS myID)*
terminal myID:
	'^'?('a'..'z'|'A'..'Z'|'_'|'.') ('a'..'z'|'A'..'Z'|'_'|'0'..'9'|'%'|'['|']'|'('|')'|'.')*
Now, if I type
@translators= pattern[%d],patternID
I get this error
missing RULE_ID at 'pattern[%d]'
Why do you think? Is there any missing?
Re: Duplicated Type Error [message #702537 is a reply to message #702525] Tue, 26 July 2011 09:54 Go to previous messageGo to next message
pattern[%d] is not covered by ID, and Characters requires there to be an ID and then possibly a white space followed by myID.
Did you intend
myID(WS myID)*
Alex
Re: Duplicated Type Error [message #702542 is a reply to message #702537] Tue, 26 July 2011 10:01 Go to previous messageGo to next message
well,I have tired this before and its an error
myID(WS myID)*
and with this way
i get this error;
missing RULE_MYID at '@ttranslators'
[Updated on: Tue, 26 July 2011 10:02] by Moderator
Re: Duplicated Type Error [message #702598 is a reply to message #702542] Tue, 26 July 2011 11:03 Go to previous message
grammar org.xtext.example.mydsl1.MyDsl1 with org.eclipse.xtext.common.Terminals
generate myDsl1 "http://www.xtext.org/example/mydsl1/MyDsl1"
Translation:
	 {Translation}
	'@translators'('=' pattern1=Characters )? (',' user=Characters)?
 	myID(WS myID)*
terminal myID:
works for
There is no way to help you, if you don't provide your full grammar along with a large set of input models you expect to be working. You should write unit tests that cover input. AbstractXtextTests in the xtext.junit plugin is helpful
You may want to have a look at this project. I think it also contains methods for testing terminal and parser rules, otherwise look at this somewhat outdated blog post.
As I said, messing with terminal rules may be painful.
Alex
Previous Topic:Xtext generated parser reports errors - why?
Next Topic:generator providing simple XML output
Current Time: Tue Jul 29 06:29:54 EDT 2025
Powered by FUDForum. Page generated in 0.30180 seconds
