Re: trouble with this bug [message #701551 is a reply to message #699886] |
Mon, 25 July 2011 04:40   |
Originally posted by: Koen Yskout
Cindy,
It's probably not a matter of environment setup, but has something to do
with your model and/or model implementation. I tested with the simple
models below, i.e., only roles in the model, with a single attribute
'Name' of type string, and all other settings left to the default, which
worked perfectly well.
From the exception trace, the exception is trown by
EcoreEvaluationEnvironment.navigateProperty. This requires that the
target (i.e., the Role class in your case) is an EObject, and contains a
property 'Name'. Is this the case in your implementation? As I see in
another post that you have overridden the Instance Type Name, does your
implementation class still implement EObject?
## pim.ecore
<ecore:EPackage xmi:version="2.0"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="pim"
nsURI="http://pim.ecore" nsPrefix="pim">
<eClassifiers xsi:type="ecore:EClass" name="Role">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Name"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
</ecore:EPackage>
## psm.ecore
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="psm"
nsURI="http://psm.ecore" nsPrefix="psm">
</eClassifiers>
</ecore:EPackage>
On 22/07/11 16:39, Cindy wrote:
> hi could you tell me how did you set your m2m environment? maybe i could
> follow your setting and have a try again..:)
Re: trouble with this bug [message #701722 is a reply to message #701551] |
Mon, 25 July 2011 09:42   |
While in my case, role is a subclass of a more generalized class which has the attribute of Name, in which case i do think role has the same attribute of Name.
As for Instance Type Name, i set it to Role ,for example, for the class of Role in my ecore model ,but when i try to generate the model code i got many errors in the interface package... i donot know why.. should i make some implementation manually?
at last , i have a new question about the graphic transformation.. i mean does this qvto support graphic transformation ,ie, when i transform pim to psm can i get an graphic model of psm or only get a xml-format file...?
Thank you for all your attention really:-)
best wishes!
Re: trouble with this bug [message #702350 is a reply to message #701722] |
Tue, 26 July 2011 04:55   |
> attribute of Name.
That should be the case.
As long as you get errors in the generated code, it's unlikely that the
transformation will work, so you should first fix those errors.
In general, you don't need to set the Instance Type Name attribute; a
Java class with the same name as your model element will be generated
automatically.
> file...?
Graphical representations of your models are not within scope of EMF nor
M2M. You could look at GEF, GMF or Graphiti for this.
> best wishes!
Re: trouble with this bug [message #702453 is a reply to message #702350] |
Tue, 26 July 2011 07:49   |
hey Koen Yskout, I've made progress in this transformation work thanks to your help all the way . thank you very much!
as to the graphic transformation, i will refer to GMF for the solution..
however i am faced with new problems right now..
the problem I have is about flow transition in activity-alike diagram, for example ,i have an one to one transformation from PIM.ecore to PSM.ecore ..
in pim model , i have action a,b and flow c whose source is a and target b, now i can successfully transform a,b and c respectively to a1, b1 and c1, but i loss the relationship among them , ie i cannot make a1 to be c1's source and b1 target..
i failed to find a function in QVT to achieve this:-(
So do you have any idea how to realize this?
Re: trouble with this bug [message #703017 is a reply to message #702350] |
Wed, 27 July 2011 00:23  |
i succeeded in doing this by late resolveoneIn() and resolveone() function.. thanks all the same..
kind of excited after trapped by these days:-)
however problems seem to never stop..
i created dynamic instance from the pim.ecore in which way i got an input.xmi as input of this transformation.. now i can transform the element from input.xmi to output.psm(psm is the modeltype of my output model).. but i got an different structure from the input,and the example as fllows:
input xmi format:
<role RoleName="role1">
<activity xsi:type="www.org.eclipse.PIM:Action" ActName="act1"/>
</role>
output psm format:
<cog CogName="role1">
<activity NodeName="act1"/>
</cog>
ie, i lost [xsi:type="www.org.eclipse.PIM:Action"] this type information.. i was supposed to have [xsi:type="www.org.eclipse.PSM:Node"] here..
do you know how to prevent this type loss..
FUDForum. Page generated in 0.30774 seconds
