Home » Archived » BIRT » MONTH IS NOT IN PROPER ORDER IN CHART(MONTH IS NOT IN PROPER ORDER IN CHART)
MONTH IS NOT IN PROPER ORDER IN CHART [message #698731] Wed, 20 July 2011 01:53 Go to next message
I AM USING A CHART WHICH IS HAVING MONTH IN X AXIS.
MONTH IS NOT IN PROPER ORDER. IT COMES LIKE APR,AUG,FEB LIKE THAT.
PLEASE LET ME KNOW HOW TO ORDER.
THANKS,
ABDEEN
Re: MONTH IS NOT IN PROPER ORDER IN CHART [message #699008 is a reply to message #698731] Wed, 20 July 2011 12:10 Go to previous messageGo to next message
If the x-axis defined as a date or a string? If it is a string add a
computed column to the chart binding tab with an expression similar to this:
if( dataSetRow["month"] == "Jan" ){
1;
}else if(dataSetRow["month"] == "Feb"){
2;
}else if(dataSetRow["month"] == "Mar"){
3;
Then use this in the sort field on the x-axis.
See attached example.
Jason
> THANKS,
> ABDEEN
Re: MONTH IS NOT IN PROPER ORDER IN CHART [message #702279 is a reply to message #699008] Tue, 26 July 2011 03:19 Go to previous messageGo to next message
The file which you attached is not supported.
my version is version="3.2.20".
where is the computed column in chart
Please let me know.
Re: MONTH IS NOT IN PROPER ORDER IN CHART [message #702355 is a reply to message #699008] Tue, 26 July 2011 05:02 Go to previous message
Its working fine jason.
Thanks.
Previous Topic:Using parameter in Custom Parameter Page
Next Topic:Multi-value cascading parameters in Custom Parameter Page
Current Time: Fri Jul 25 23:57:31 EDT 2025
Powered by FUDForum. Page generated in 0.25696 seconds
