Home » Modeling » OCL » oclIsTypeOf error with OCLinEcore
oclIsTypeOf error with OCLinEcore [message #701981] Mon, 25 July 2011 16:21 Go to next message
Hi again,
I use a metamodel where a class A is composed of two eReferences : leftMember and rightMember. Those references can be of some types I created, let's say : T1, T2, T3...
when I test the trivial operation self.left_member=self.left_member in the OCLinEcore console, I get a response.
when I test self.right_member.oclIsTypeOf(T1), I also get a boolean answer.
but, when I test something like self.left_member.oclIsTypeOf(self.right_member) or even self.left_member.oclIsTypeOf(self.left_member), I am given the following error : Cannot find operation (oclIsTypeOf(T1)) for the type (T1).
Is it because of my class hierarchy ? How can I solve this ? thanks
Re: oclIsTypeOf error with OCLinEcore [message #702229 is a reply to message #701981] Tue, 26 July 2011 01:43 Go to previous messageGo to next message
oclIsTypeOf takes a Type argument. Type Literals and Type Expressions
are ill-defined in the OCL specification and Eclipse OCL is prototyping
solutions to these problems.
self.left_member is not a type expression so your expression cannot work.
From the error message, it looks as if you're using the Helios release.
I think the Indigo release is more precise on the bad type.
In the Indigo, release oclType() has fully reflective semantics so you
could well find that
self.left_member.oclIsTypeOf(self.left_member.oclType())
works. (Did you perhaps mean oclIsKindOf which is more general?)
Ed Willink
On 25/07/2011 21:21, fafanellu wrote:
> Hi again, I use a metamodel where a class A is composed of two
> answer.
> (T1).
Re: oclIsTypeOf error with OCLinEcore [message #702408 is a reply to message #702229] Tue, 26 July 2011 06:21 Go to previous messageGo to next message
Hi, thanks for your quick answer, I actually use the Helios release.
I understood my mistake, in fact I re-defined some basetypes so I got confused with that, for me self.left_member was a type (because of my metamodel !), but it is not.
I'll try to test it with indigo, because oclType() doesn't seem to be recognized by Helios.
Thanks again,
regards
Re: oclIsTypeOf error with OCLinEcore [message #702584 is a reply to message #702408] Tue, 26 July 2011 10:43 Go to previous messageGo to next message
Hi again,
I tried self.left_member.oclIsTypeOf(self.left_member.oclType()) but the operation oclType() seems to be unknown (moreover, it is not proposed among the others operations I get after having typed the dot...).
I get the following error :
Cannot find operation (oclType()) for the type (T1)
The purpose of what I would like to do with this is just to check that both of the members linked to class A belong to the same type, I think you have guessed it Wink
I'm a little bit lost...how could I fix this ?
thanks
Re: oclIsTypeOf error with OCLinEcore [message #702646 is a reply to message #702408] Tue, 26 July 2011 12:02 Go to previous messageGo to next message
So which release are you now corresponding about?
Re: oclIsTypeOf error with OCLinEcore [message #702685 is a reply to message #702646] Tue, 26 July 2011 13:12 Go to previous messageGo to next message
since you told me to test with the Indigo, I installed it and imported my ecore project inside. The OCL version is 3.1.0.
this message :
Hi again,
thanks
was written after having tested the code with the Indigo version
[Updated on: Tue, 26 July 2011 13:52] by Moderator
Re: oclIsTypeOf error with OCLinEcore [message #702709 is a reply to message #702685] Tue, 26 July 2011 13:37 Go to previous messageGo to next message
Something similar works fine for me. You give me very little to go on
apart from the clue that even you didn't understand left_member.
Ed Willink
Re: oclIsTypeOf error with OCLinEcore [message #702710 is a reply to message #702709] Tue, 26 July 2011 13:53 Go to previous messageGo to next message
I'll try to send you a message with a diagram attached, so that you could see what I mean. Anyway, thanks for your help
Re: oclIsTypeOf error with OCLinEcore [message #702799 is a reply to message #702710] Tue, 26 July 2011 16:19 Go to previous messageGo to next message
Here we are, I tried to make a very simple example to explain what I want.
Type is an abstract class with two children, T1 and T2.
Expression is a class with two eReferences, left_member and right_member, which can be T1 or T2.
When I create a dynamic instance of Expression, I give it its two members (left and right). My goal is to check with OCL if both of them belong to the same type (i.e, for instance, within the Expression context, self.left_member.oclIsTyeOf(T1)=true and self.right_member.oclIsTyeOf(T1)=true)
My problem is oclIsTypeOf() operation, as I said before...
self.left_member.oclIsTyeOf(T1) does work, it evaluates the type of left_member and writes it, but I can't compare it with the right_member type...
index.php/fa/3486/0/
thanks
  • Attachment: example.jpg
    (Size: 57.50KB, Downloaded 877 times)
[Updated on: Tue, 26 July 2011 16:23] by Moderator
Re: oclIsTypeOf error with OCLinEcore [message #703098 is a reply to message #702799] Wed, 27 July 2011 02:43 Go to previous messageGo to next message
If you want me to help provide something I can work with. A JPEG is
pretty but unuseable.
clearly doesn'tr work since it has a double typo.
Ed Willink
Re: oclIsTypeOf error with OCLinEcore [message #703202 is a reply to message #703098] Wed, 27 July 2011 05:32 Go to previous messageGo to next message
here is what I have for my .ecore metamodel.
abstract class Type;
	class T1 extends Type;
	class T2 extends Type;
	class Expression
		property left_member : Type[1] { ordered composes };
		property right_member : Type[1] { ordered composes };
I meant that when I use the oclIsTypeOf() operation in a simple context, it works. I'll try to explain it clearly :
I instanciated the Expression class using the dynamic instance creation, then I gave it a left member and a right member, I chose to give to both of them the same type : T1.
As I said above, oclIsTypeOf() operation works fine if I use it in this way :
Evaluating:
self.left_member.oclIsTypeOf(T1)
Results:
true
Evaluating:
self.right_member.oclIsTypeOf(T2)
Results:
false
Evaluating:
Results:
true
But my problem is : what if I didn't use the same type for left_member and right_member ?
How can I check directly with OCL that both of them belong to the same type ? Do I use the right operation ? My problem, I think, is about what parameters I give to oclIsTypeOf().
regards
[Updated on: Wed, 27 July 2011 08:48] by Moderator
Re: oclIsTypeOf error with OCLinEcore [message #703566 is a reply to message #703202] Wed, 27 July 2011 13:23 Go to previous messageGo to next message
self.left_member.oclIsTypeOf(self.right_member.oclType())
works for me.
Are you using the Interactive Xtext Console? the Interactive Console
uses the mature evaluator that has minimal support for oclType().
Ed Willink
On 27/07/2011 10:32, fafanellu wrote:
> class Expression
> creation, then I gave it a left member and a right member, both of
> them have the same type : T1.
> this way :
> Evaluating:
> Results:
> true
> Evaluating:
> Results:
> false
> Evaluating:
> Results:
> true
> and right_member ?
> regards
Re: oclIsTypeOf error with OCLinEcore [message #703567 is a reply to message #703202] Wed, 27 July 2011 13:23 Go to previous messageGo to next message
works for me.
Ed Willink
> class Expression
> this way :
> Evaluating:
> Results:
> true
> Evaluating:
> Results:
> false
> Evaluating:
> Results:
> true
> and right_member ?
> regards
Re: oclIsTypeOf error with OCLinEcore [message #703598 is a reply to message #703566] Wed, 27 July 2011 14:33 Go to previous messageGo to next message
Hi, I don't use the Xtext console, since it doesn't recognize the "." (dot).
So, I use the "normal" OCL console.
I always get the same thing...
Evaluating:
Results:
Cannot find operation (oclType()) for the type (Type)
Damn...
Maybe it's because whent I first tried to do the tutorial, I clicked "Yes" when I was asked if I wanted to add the Xtext nature for the project ?
It was said "Click Yes to avoid answering the question in the future"...so I did it. Maybe I should try to cancel this (how?).
Anyway, my final goal is to add a constraint directly in the .ecore model...maybe oclType() will work in this case ?
thanks Smile
Re: oclIsTypeOf error with OCLinEcore [message #703712 is a reply to message #703598] Wed, 27 July 2011 16:42 Go to previous messageGo to next message
As I wrote, the non-Xtext Console doesn't support oclType().
What do you mean by doesn't recognize the dot?
which seems to be recognizing the dor four times.
Ed Willink
> (dot). So, I use the "normal" OCL console.
> Evaluating:
> Results:
> Damn...
> project ?
> thanks :)
Re: oclIsTypeOf error with OCLinEcore [message #704124 is a reply to message #703712] Thu, 28 July 2011 05:51 Go to previous messageGo to next message
Well, when I start to type in the "normal" console "self.", I am proposed some things after the dot : left-member, right_member, and some OCL operations.
In the Xtext console, I am not, so I thought it didn't work.
But I've just tried to write my code "manually", and it works well !! Smile
Thanks !!
I'm now trying to integrate it in the .ecore metamodel, as a class invariant (is this a class invariant ?).
Again, I thank you for your help Smile
Re: oclIsTypeOf error with OCLinEcore [message #704416 is a reply to message #704124] Thu, 28 July 2011 11:39 Go to previous messageGo to next message
Xtext offers no completion after "." by default since the choice can be
massive. Customizing this is one of many
editor improvements that might happen for Juno. If you type "xxx.a" then
backup to the dot you do get
some completions; can't promise that they're accurate.
Ed Willink
> But I've just tried to write my code "manually", and it works well !! :)
> Thanks !!
> Again, I thank you for your help :)
Re: oclIsTypeOf error with OCLinEcore [message #704427 is a reply to message #704416] Thu, 28 July 2011 12:02 Go to previous message
Ok thanks, I'll try this out !
I'll be back soon for some help, I think...
Have a nice day
regards
Stephane
Previous Topic:[CompleteOCL] Problems with CompleteOCL editor
Next Topic:Is there a caching version of org.eclipse.ocl.AbstractEnvironment?
Current Time: Mon Jul 21 00:24:08 EDT 2025
Powered by FUDForum. Page generated in 0.28303 seconds
