Home » Eclipse Projects » P2 » plugin is not picked up from dropins folder, exception in org.eclipse.equinox.p2.reconciler.dropins
plugin is not picked up from dropins folder, exception in org.eclipse.equinox.p2.reconciler.dropins [message #702077] Mon, 25 July 2011 19:55 Go to next message
I am using STS 2.6.1 which includes Eclipse 3.6.2
I wrote a custom plugin and asked my users to put the .jar file into their "dropins" folder in order to use it. Most of the times it works, but some users have told me the plugin doesn't show up for them. In each case their logs show the same error: java.lang.NoSuchMethodError: org.eclipse.equinox.internal.provisional.p2.directorywatcher.RepositoryListener.<init>, see the details below.
1) I don't understand how they get this error and I don't although we have the same STS environment. Where should I look for differences?
2) Any idea what could case this error or where to start to debug this?
3) Is there any other simple way to deploy a custom plugin that doesn't involve using the "dropins" directory.
Thanks!
--Laurent
!ENTRY org.eclipse.equinox.p2.reconciler.dropins 4 0 2011-07-07 14:35:59.075
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.start() of bundle org.eclipse.equinox.p2.reconciler.dropins.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:806)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:755)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:370)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:374)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1067)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:561)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:546)
Caused by: java.lang.NoSuchMethodError: org.eclipse.equinox.internal.provisional.p2.directorywatcher.RepositoryListener.<init>(Ljava/lang/String;Ljava/util/Map;)V
at org.eclipse.equinox.internal.p2.reconciler.dropins.DropinsRepositoryListener.<init>(DropinsRepositoryListener.java:53)
at org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.watchDropins(Activator.java:489)
at org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.start(Activator.java:172)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:783)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:774)
Re: plugin is not picked up from dropins folder, exception in org.eclipse.equinox.p2.reconciler.drop [message #702099 is a reply to message #702077] Mon, 25 July 2011 20:46 Go to previous messageGo to next message
Give the users a p2 repository instead. It can be on disk. And this
repository is added as any other repository in the p2 ui. This way you
get much better feedback on why it does not install ok for some users.
- henrik
Re: plugin is not picked up from dropins folder, exception in org.eclipse.equinox.p2.reconciler.drop [message #702103 is a reply to message #702099] Mon, 25 July 2011 21:02 Go to previous messageGo to next message
hi Henrik,
I am not familiar with p2. What do you mean by "Give the users a p2 repository instead"?
--Laurent
Re: plugin is not picked up from dropins folder, exception in org.eclipse.equinox.p2.reconciler.drop [message #702223 is a reply to message #702103] Tue, 26 July 2011 01:39 Go to previous messageGo to next message
- create a feature
- create an update site project
- build the update site project --> that's the p2 site (aka update site)
> software distributed in that way get "installed" not just "copied in"
HTH
Michael
Re: plugin is not picked up from dropins folder, exception in org.eclipse.equinox.p2.reconciler.drop [message #702672 is a reply to message #702223] Tue, 26 July 2011 12:52 Go to previous messageGo to next message
OK, thanks, that was plan for the long term. But for quick internal updates I would still like to understand the java.lang.NoSuchMethodError exception and why the normal "dropins" directory method fails for some users.
Can someone give me tops on how to debug this?
Thanks!
--Laurent
Re: plugin is not picked up from dropins folder, exception in org.eclipse.equinox.p2.reconciler.drop [message #703508 is a reply to message #702672] Wed, 27 July 2011 12:30 Go to previous messageGo to next message
> users.
> Thanks!
> --Laurent
The idea was, that if you produce a p2 repository - the users where it
fails tries this repo. If there are errors installing that way you
actually get to see what may be wrong !!
That was the idea.
The setup of an update site project and export to p2 is very simple.
Using "dropin" is a crutch with severe limitations in functionality. It
should really be removed from Eclipse as it does not have a chance of
working as people expect. IMHO it is a waste of time trying to hunt down
and fix issues related to use of "dropin".
- henrik
Re: plugin is not picked up from dropins folder, exception in org.eclipse.equinox.p2.reconciler.drop [message #703509 is a reply to message #703508] Wed, 27 July 2011 12:41 Go to previous message
On 2011-07-27 6:30 PM, Henrik Lindberg wrote:
> It should really be removed from Eclipse as it does not have a chance of
+1
Michael
Previous Topic:P2 greedy behavior inside a feature
Next Topic:Error mirroring an exported feature with B3
Current Time: Fri Jul 25 06:21:48 EDT 2025
Powered by FUDForum. Page generated in 0.06750 seconds
