Re: use UI libraries in custom parameter page [message #702556 is a reply to message #702015] |
Tue, 26 July 2011 10:13   |
Do you mean to define the parameters like:
<birt:parameterPage
Date From:
<input type="text" name="date_from" />
To:
<input type="text" name="date_to" />
<br>
<input type="submit" name="submit" value="Run Report"/>
</birt:parameterPage>
It works good, but the input box is still a plain text box.
I already added a calendar widget to the BIRT viewer, and parameters with date type in BIRT default parameter page are now rendered with a calendar:
But it does not work for parameters defined with BIRT tag library in a custom parameter page:
I also tried:
Date From:
<input type="date" name="date_from" />
To:
<input type="date" name="date_to" />
It still rendered as plain text boxes...
Jason Weathersby wrote on Mon, 25 July 2011 17:09Why not just use normal text boxes for the two date parameters and add
onclick events to these. Just make sure to use the name attribute and
set it to the correct parameter name. Next use something like is shown
in this thread to hook up a calendar.
http://www.birt-exchange.org/org/forum/index.php/topic/11498-birt-datepicker-plzzzzzzzzzzz/
Jason
On 7/25/2011 3:13 PM, Scroon wrote:
> Hello,
> I've used BIRT tag library to build a custom parameter pages:
> <%@ page language="java" contentType="text/html; charset=ISO-8859-1"
> pageEncoding="ISO-8859-1"%>
> <%@ taglib uri="/birt.tld" prefix="birt" %>
> <!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
> "http://www.w3.org/TR/html4/loose.dtd">
> <html>
> <head>
> <meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1">
> </head>
> <body>
> <birt:parameterPage id="birtParmPage" reportDesign="report\Report.rptdesign"
> name="my form"
> pattern="frameset"
> format="html"
> isCustom="true"
> showTitle="true"
> showToolBar="true"
> showNavigationBar="true"
> target="content"
> ClientName:<birt:paramDef id="11" name="ClientName" />
> <br>
> Date From:
> <birt:paramDef id="22" name="date_from"/>
> Date To:
> <birt:paramDef id="33" name="date_to"/>
> <br>
> <br>
> </body>
> </html>
> It works well, the only problem is it does not looks lovely. Especially the input for the dates, they are just plain text boxes...:
> Since the input boxes is defined by the BIRT tag library, the input elements does not defined in regular way like
> <input id="datefrom" type="text">
> but with:
> How can I use some JavaScript UI library with the custom parameter page for some elements in the page ? e.g: Add a calendar widget for the Date input.
Attachment: c1.JPG
(Size: 19.29KB, Downloaded 1223 times)
Attachment: c2.JPG
(Size: 8.51KB, Downloaded 1102 times)
[Updated on: Tue, 26 July 2011 10:18] by Moderator
Re: use UI libraries in custom parameter page [message #702586 is a reply to message #702556] |
Tue, 26 July 2011 10:27  |
I am not sure what widget you are using but I assumed it needed to be
launched from javascript. So to hook it you would use normal text box
with onclick event like:
<script type="text/javascript">
function callcalendar()
//do something with calendar
</script>
<input type=text name=type onclick="callcalendar();">
Jason
On 7/26/2011 10:13 AM, Scroon wrote:
> <birt:parameterPage
> Date From:
> To: <input type="text" name="date_to" />
> <br>
> with date type are now rendered with a calendar. But it does not work
> for parameters defined with BIRT tag library....
> I also tried:
> Date From:
> To: <input type="date" name="date_to" />
>> Jason
>> > Hello,
>> > <html>
>> > <head>
>> > </head>
>> > <body>
>> > name="my form"
>> > pattern="frameset"
>> > format="html"
>> > isCustom="true"
>> > showTitle="true"
>> > showToolBar="true"
>> > target="content"
>> > <br>
>> > Date From:
>> > Date To:
>> > <br>
>> > <br>
>> > </body>
>> > </html>
>> > but with:
>> the Date input.
FUDForum. Page generated in 0.04797 seconds
