Home » Modeling » M2T (model-to-text transformation) » [MWE] Use metamodel from other plugin
[MWE] Use metamodel from other plugin [message #701584] Mon, 25 July 2011 05:21 Go to next message
Hello guys,
I am using a xpand generator in my mwe workflow, which requires a metamodel file.
Until now I always stored the metamodel and the workflow file in the same eclipse plugin.
<workflow>
	<property name='metaecorefile1' value="/model/functionmodel.ecore"/>
	<!-- generate code -->
  	<component id="generator" class="org.eclipse.xpand2.Generator">
  		<expand value="functionmodelGenerator::function::main FOR model"/>
		<metaModel class="org.eclipse.xtend.typesystem.emf.EmfMetaModel">
     		<metaModelFile value='${metaecorefile1}'/>
  		</metaModel>
Now I want to store the ecore file in a different plugin. It is possible to specify the path to an other plugin or are other mechanism for that case ?
Sincerly
Patrick
Re: [MWE] Use metamodel from other plugin [message #701639 is a reply to message #701584] Mon, 25 July 2011 07:20 Go to previous messageGo to next message
Which Mwe Version do you use?
=> if 1.1.0 then use platform:/resource/plugin/.....
Is the second plugin a workspace project too?
=> then use platform:/resource/plugin/.....
Do you use dynamic EMF or do you have to Java Classes Generated too?
=> use the package instead of dynamic emf
~Christian
Re: [MWE] Use metamodel from other plugin [message #701785 is a reply to message #701639] Mon, 25 July 2011 11:38 Go to previous messageGo to next message
Yes I am using EMF Modeling Workflow Engine 1.1.0.
I tried <property name='metaecorefile1' value="platform:/resource/com.ksb.mechatronic.modeller/model/functionmodel.ecore"/>,
but when executing the code I get an error:
org.eclipse.emf.mwe.core.ConfigurationException: org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Resource '/com.ksb.mechatronic.modeller/model/functionmodel.ecore' does not exist.
The ecore file is in the build path of that plugin.
My second try:
I also have the generated java classes in that other plugin, but they are not recognised by the workflow.
I set the plugin, which contains the ecore file and the generated java classes, as required dependency and
added the generated packages to the imported packages of my generator plugin without success.
What must i do that the workflow knows the types of the imported package ?
Re: [MWE] Use metamodel from other plugin [message #701820 is a reply to message #701785] Mon, 25 July 2011 12:24 Go to previous messageGo to next message
do you call standalonesetup.setplatformuri in your wf?
Use the classes:
org.eclipse.xtend.typesystem.emf.EmfMetaModel.setMetaModelPackage(String)
~Christian
Re: [MWE] Use metamodel from other plugin [message #702338 is a reply to message #701820] Tue, 26 July 2011 04:29 Go to previous messageGo to next message
Hello Christian,
finally i found the solution Smile
I must not specify the direct path to my metamodel,
i just have to add following code to the workflow to get it working:
<!-- instantiate metamodel -->
<bean id="mm_emf" class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel"/>
<!-- <expand value="templates::Root::Root FOR RootDiagram"/> -->
<metaModel idRef="mm_emf"/>
What is that code doing? I want to understand it.
Re: [MWE] Use metamodel from other plugin [message #702410 is a reply to message #702338] Tue, 26 July 2011 06:28 Go to previous message
EmfRegistryMetaModel takes all EMF Metamodel that are registered to EMFs Registry.
~Christian
Previous Topic:[Acceleo] Does the Acceleo Language support constants?
Next Topic:acceleo : support for variable increment in for loops?
Current Time: Sun Jul 27 08:56:21 EDT 2025
Powered by FUDForum. Page generated in 0.05406 seconds
