Home » Modeling » Epsilon » EVL: more do's in one fix?(EVL: more do's in one fix?)
EVL: more do's in one fix? [message #701570] Mon, 25 July 2011 04:58 Go to next message
I use EOL for checking consistency between 2 xml files and EVL to fix occuring inconsistencies. If it is possible I want to design my solution based on a framework from literature which says there are several options to handle inconsistencies (like ignoring, deferring, circumventing, etc.). Therefore I was wondering whether it is possible to define several "do's" in one fix, for which a choice can be made for 1 "do" during execution. Because of time pressure I'm not able to find out myself, but I only have to know whether it is possible or not, to make a statement about this in my report.
Kind regards, Tom
Re: EVL: more do's in one fix? [message #701582 is a reply to message #701570] Mon, 25 July 2011 05:19 Go to previous messageGo to next message
Hi Tom,
It is not possible to define multiple do parts for a fix, however it is possible to define many fixes for the same constraint.
Dimitris
Re: EVL: more do's in one fix? [message #701586 is a reply to message #701582] Mon, 25 July 2011 05:25 Go to previous message
Thanks!! I expanded an available example and doing it this way indeed results in the needed solution!
Previous Topic:Parameter type checking in extended rules in ETL
Next Topic:[EWL] Embed EWL in gmf project
Current Time: Sat Jul 26 02:53:38 EDT 2025
Powered by FUDForum. Page generated in 0.08569 seconds
