Home » Eclipse Projects » Eclipse Platform » default perspective for launch
| Re: default perspective for launch [message #70707 is a reply to message #70634] |
Wed, 11 June 2003 09:04   |
Originally posted by: darin_swanson.oti.com
Ok..in the future we both need to specify which build / stream of Eclipse we
are talking about. :-)
I was talking about 3.0...it appears you were talking about 2.1? And I
assumed you were using the UI...you did not state that you wanted to do it
programmatically.
In the 2.1 code stream you will need to set the debug preference for:
IDebugUIConstants.PREF_SHOW_DEBUG_PERSPECTIVE_DEFAULT and
IDebugUIConstants.PREF_SHOW_RUN_PERSPECTIVE_DEFAULT.
See the DebugPreferencePage as an example of where this is done currently.
In 3.0 you specify the perspective for the launch configuration type
directly using DebugUITools.setLaunchPerspective(ILaunchConfigurationType
type, String mode, String perspective);
Hope I have helped you this time,
Darins
"Christian Sell" <christian.sell@netcologne.de> wrote in message
news:bc6tiv$afb$1@rogue.oti.com...
> huh? You lost me..
> 1. What launch configuration dialog are you talking about? The only one
> I know is when creating a launch configuration. That is one step too far.
> 2. In that dialog, all I can specify is which perspective to switch to
> when the launch is run. Among the perspective choices, there is a
> "default" choice. It is the value of that "default" choice that I want
> to determine in advance!
> 3. I want to do this programmatically, i.e. along with my
> ILaunchConfigurationDelegate, i want to specify what "default" stands
> for. I have found no way to do this.
> thanks,
> Christian
> Darin Swanson wrote:
> > In the launch configuration dialog, select the launch configuration type
and
> > then set the default perspective for the launch mode.
> > HTH
> > Darins
> > "Christian Sell" <cse@dynabean.de> wrote in message
> > news:bc5jqa$e3c$1@rogue.oti.com...
> >>Hello,
> >>can somebody please give me a hint how to specify the default
> >>perspective for a given launch type?
> >>thanks,
> >>Christian Sell
| Re: default perspective for launch [message #70739 is a reply to message #70707] |
Wed, 11 June 2003 09:30   |
I have meanwhile looked into the source code of
org.eclipse.debug.internal.ui.launchConfigurations.Perspecti veManager,
and it appears to me that the preference keys you mention:
have to be set in the PreferenceStore of the DebugUIPlugin and will thus
have global effect for all launches. I was expecting to be able to
specify the meaning of "default" in the context of a specifiy launch
type (which would make sense IMO). That does not seem possible - does
3.0 allow that?
What I am doing now is subclass CommonTab in my
LaunchconfigurationTabGroup, and implement the seDefaults method such:
config.setAttribute(IDebugUIConstants.ATTR_TARGET_DEBUG_PERS PECTIVE,
MY_PERSPECTIVE_ID);
config.setAttribute(IDebugUIConstants.ATTR_TARGET_RUN_PERSPE CTIVE,
MY_PERSPECTIVE_ID);
I dont like that solution, but it seems the only one for now.
thanks,
Christian
> programmatically.
> Darins
>>huh? You lost me..
>>thanks,
>>Christian
> and
>>>HTH
>>>Darins
>>>>Hello,
>>>>thanks,
>>>>Christian Sell
| Re: default perspective for launch [message #70752 is a reply to message #70739] |
Wed, 11 June 2003 10:02  |
Yes, in 3.0 using DebugUITools.setLaunchPerspective(ILaunchConfigurationType
type, String mode, String perspective) you set the default perspective for
the type and the mode.
Glad to see we have anticipated you needs :-)
Darins
news:bc7aul$nqe$1@rogue.oti.com...
> 3.0 allow that?
> MY_PERSPECTIVE_ID);
> MY_PERSPECTIVE_ID);
> thanks,
> Christian
Eclipse we
it
> > programmatically.
currently.
> > directly using
> > Darins
> >>huh? You lost me..
far.
> >>thanks,
> >>Christian
type
> > and
> >>>HTH
> >>>Darins
> >>>>Hello,
> >>>>thanks,
> >>>>Christian Sell
Current Time: Thu Nov 06 17:02:30 EST 2025
Powered by FUDForum. Page generated in 0.06625 seconds
