Home » Modeling » GMF (Graphical Modeling Framework) » Updating models
Updating models [message #69950] Thu, 26 October 2006 07:25 Go to next message
Originally posted by: matroska.libero.it
i am writing a gmf project generating code by the use of gmf. Now i have
done various modifications to the code so i need to know i can make
changes in the model and produce effects in the code and not overwrite
my modified code. Can i simply modify the model an then regenerate
everything?
Thanks in advance
John Slave
Re: Updating models [message #70008 is a reply to message #69950] Thu, 26 October 2006 07:35 Go to previous message
Hello John,
If all your modifications are marked with "@generated NOT" javadoc-comments
and you are using org.eclipse.gmf.bridge.trace plugin it is possible to modify
the model and regenerate the code i most cases.
Alex Shatalin
Previous Topic:Which version supports affixed side?
Next Topic:Change object properties when clicked
Current Time: Fri Jul 18 19:41:26 EDT 2025
Powered by FUDForum. Page generated in 0.67043 seconds
