Home » Archived » BIRT » RCP Birt Designer and Database Server running SSL(Using the RCP BIRT Designer application to develop reports against a hosted data base server running SSL)
RCP Birt Designer and Database Server running SSL [message #694725] Sat, 09 July 2011 09:21 Go to next message
is there a possibility to create/maintain reports using the BIRT RCP Report Designer application and connecting to an Apache Derby data base server only accepting SSL encrypted communication?
I am aware of the ssl= attribute I need to specify on the data base connection URL for the Derby JDBC driver when defining the data source, but where and how do I tell the BIRT Designer where to find the java keystore file storing the certificate that would need to be presented to the server?
Thomas
Re: RCP Birt Designer and Database Server running SSL [message #699700 is a reply to message #694725] Fri, 22 July 2011 02:39 Go to previous messageGo to next message
no answer after quite some time - would the next step be to raise a feature request based on the assumption that this is NOT possible?
Tx
Re: RCP Birt Designer and Database Server running SSL [message #699936 is a reply to message #699700] Fri, 22 July 2011 10:52 Go to previous message
Thomas,
I have not tried this but have you seen this link:
http://db.apache.org/derby/docs/dev/adminguide/cadminsslclient.html
Could you try using something like
jdbc:derby://myhost:1527/db;ssl=basic as the jdbc url? And set the
system properties for the keystore?
System.setProperty("javax.net.ssl.keyStore","clientKeyStore.key");
System.setProperty("javax.net.ssl.keyStorePassword","qwerty");
Jason
> Tx
Previous Topic:Validate input parameter in script
Next Topic:Setting a data base role
Current Time: Fri Jul 25 16:51:11 EDT 2025
Powered by FUDForum. Page generated in 0.03723 seconds
