Model changes triggered by Edit Helper Advice [message #697881] |
Mon, 18 July 2011 05:23  |
Inside a bigger GMF project we have to react to changes of the connections.
We are trying to implement an EditHelperAdvice class, which extends AbstractEditHelperAdvice, that reacts to the creation an the deletion of a connection and then changes a label in the target element according to the previous node.
We have created a test environment to focus on this issue. It consists of two nodes (TestSource and TestTarget) and a reference test pointing from the TestSource to the TestTarget. Both nodes are contained in TestCanvas.
Our definition of the advice in the plugin.xml seems to work:
<extension point="org.eclipse.gmf.runtime.emf.type.core.elementTypes" id="element-types">
<metamodel nsURI=".../testproject/1.0"><!--Forum didn't allow http-->
<adviceBinding
class="testproject.extend.advice.TestTargetAdvice"
id="TestProject.diagram.TestTargetAdvice"
inheritance="all"
typeId="TestProject.diagram.TestTarget_2002">
</adviceBinding>
<adviceBinding
class="testproject.extend.advice.TestSourceAdvice"
id="TestProject.diagram.TestSourceAdvice"
inheritance="all"
typeId="TestProject.diagram.TestSource_2001">
</adviceBinding>
</metamodel>
</extension>
<extension point="org.eclipse.gmf.runtime.emf.type.core.elementTypeBindings" id="element-types-bindings">
<binding context="TestProject.diagram.TypeContext">
<advice ref="TestProject.diagram.TestTargetAdvice"></advice>
<advice ref="TestProject.diagram.TestSourceAdvice"></advice>
</binding>
</extension>
And the TestTargetAdvice also works and writes "created" into the label:
package testproject.extend.advice;
public class TestTargetAdvice extends AbstractEditHelperAdvice {
protected ICommand getAfterCreateRelationshipCommand(
CreateRelationshipRequest request) {
if (request.getTarget() != null
&& request.getTarget() instanceof TestTargetImpl) {
SetValueCommand newSetCommand = new SetValueCommand(new SetRequest(
(EObject) request.getTarget(),
TestprojectPackageImpl.eINSTANCE
.getTestTarget_TestTargetLabel(), "created"));
ICommand command = super.getAfterCreateRelationshipCommand(request);
ICompositeCommand compositeCommand = new CompositeCommand("create");
if (command != null) {
compositeCommand.add(command);
compositeCommand.add(newSetCommand);
return compositeCommand;
} else
return super.getAfterCreateRelationshipCommand(request);
But if we try the same for the source the reference disappears but does not get deleted from the model. The reference's name remains in the sources properties. When we close the diagram and open it again, the reference reappears.
public class TestSourceAdvice extends AbstractEditHelperAdvice {
protected ICommand getAfterDestroyReferenceCommand(
DestroyReferenceRequest request) {
if (request.getReferencedObject() != null
&& request.getReferencedObject() instanceof TestTargetImpl) {
(EObject) request.getReferencedObject(),
.getTestTarget_TestTargetLabel(), "deleted"));
ICommand command = super.getAfterDestroyReferenceCommand(request);
ICompositeCommand compositeCommand = new CompositeCommand("delete");
} else
return super.getAfterDestroyReferenceCommand(request);
We also tried to execute the command right there but that just caused an exception "Cannot activate read/write transaction in read-only transaction context":
org.eclipse.core.commands.ExecutionException: While executing the operation, an exception occurred
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:519)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack.execute(DiagramCommandStack.java:206)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack.execute(DiagramCommandStack.java:169)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack.execute(DiagramCommandStack.java:156)
at testproject.extend.GefCommandHelper.sendCommand(GefCommandHelper.java:150)
at testproject.extend.advice.TestSourceAdvice.getAfterDestroyReferenceCommand(TestSourceAdvice.java:52)
at org.eclipse.gmf.runtime.emf.type.core.edithelper.AbstractEditHelperAdvice.getAfterEditCommand(AbstractEditHelperAdvice.java:129)
at org.eclipse.gmf.runtime.emf.type.core.edithelper.AbstractEditHelper.getEditCommand(AbstractEditHelper.java:206)
at org.eclipse.gmf.runtime.emf.type.core.edithelper.AbstractEditHelper.getEditCommand(AbstractEditHelper.java:137)
at org.eclipse.gmf.runtime.emf.type.core.SpecializationType.getEditCommand(SpecializationType.java:238)
at testproject.diagram.edit.policies.TestProjectBaseItemSemanticEditPolicy.getEditHelperCommand(TestProjectBaseItemSemanticEditPolicy.java:136)
at testproject.diagram.edit.policies.TestProjectBaseItemSemanticEditPolicy.getSemanticCommand(TestProjectBaseItemSemanticEditPolicy.java:101)
at org.eclipse.gmf.runtime.diagram.ui.editpolicies.SemanticEditPolicy.getCommand(SemanticEditPolicy.java:69)
at testproject.diagram.edit.policies.TestProjectBaseItemSemanticEditPolicy.getCommand(TestProjectBaseItemSemanticEditPolicy.java:83)
at org.eclipse.gef.editparts.AbstractEditPart.getCommand(AbstractEditPart.java:501)
at org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionEditPart.access$0(ConnectionEditPart.java:1)
at org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionEditPart$3.run(ConnectionEditPart.java:598)
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.runExclusive(TransactionalEditingDomainImpl.java:328)
at org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionEditPart.getCommand(ConnectionEditPart.java:593)
at testproject.diagram.part.DeleteElementAction.getCommand(DeleteElementAction.java:78)
at org.eclipse.gmf.runtime.diagram.ui.actions.DiagramAction.getCommand(DiagramAction.java:161)
at org.eclipse.gmf.runtime.diagram.ui.actions.DiagramAction.calculateEnabled(DiagramAction.java:124)
at org.eclipse.gmf.runtime.diagram.ui.actions.DiagramAction.refresh(DiagramAction.java:114)
at org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandler.selectionChanged(AbstractActionHandler.java:387)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramGraphicalViewer.flushSelectionEvents(DiagramGraphicalViewer.java:269)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramGraphicalViewer$1.run(DiagramGraphicalViewer.java:247)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4041)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3660)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
Caused by: java.lang.IllegalStateException: Cannot activate read/write transaction in read-only transaction context
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.acquire(TransactionalEditingDomainImpl.java:576)
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.activate(TransactionalEditingDomainImpl.java:508)
at org.eclipse.emf.transaction.impl.TransactionImpl.start(TransactionImpl.java:204)
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.startTransaction(TransactionalEditingDomainImpl.java:424)
at org.eclipse.emf.workspace.AbstractEMFOperation.createTransaction(AbstractEMFOperation.java:617)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:147)
at org.eclipse.gmf.runtime.common.core.command.CompositeCommand.doExecuteWithResult(CompositeCommand.java:403)
at org.eclipse.gmf.runtime.common.core.command.AbstractCommand.execute(AbstractCommand.java:135)
at testproject.extend.GefFromGmfCommand.execute(GefFromGmfCommand.java:48)
at org.eclipse.gmf.runtime.diagram.ui.commands.CommandProxy.doExecuteWithResult(CommandProxy.java:50)
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:511)
... 50 more
I hope that someone can help us with this issue since we have been working on it for quite some time. Somehow all the available documentation and tutorials (online, in eclipse and on third-party sites) seem to be outdated and the examples there don't work on our Helios.
[Updated on: Mon, 18 July 2011 07:05] by Moderator
Re: Model changes triggered by Edit Helper Advice [message #701482 is a reply to message #701166] |
Mon, 25 July 2011 03:10  |
Thank you for your response.
I first wanted to ask others (after not finding anything anywhere) before calling it a bug. The whole framework still is a huge mystery to me and good documentation seems rare.
I have just reported it as a bug here:
bugs.eclipse.org/bugs/show_bug.cgi?id=352968
FUDForum. Page generated in 0.04985 seconds
