Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Setting a 'unique' constraint on a many-to-one reference in hibernate
[Teneo] Setting a 'unique' constraint on a many-to-one reference in hibernate [message #69943] Fri, 02 February 2007 01:17 Go to next message
Originally posted by: Stephen.Egan.csiro.au
I'm trying to add a unique constraint to a many-to-one Ereference in my =
ecore model using Eannotaions. I've added the following Eannotation to =
the Ereference:
<eStructuralFeatures xsi:type=3D"ecore:EReference" name=3D"userAc=
count" =
eType=3D"#//Support/UserAccount">
<eAnnotations source=3D"teneo.hibernate">
<details key=3D"appinfo" value=3D"@Column(unique=3D&quot;true=
&quot;)"/>
</eAnnotations>
</eStructuralFeatures>
This works fine for an Eattribute, but doesn't seem to have any effect o=
n =
the generated hibernate mappings for an EReference:
<many-to-one name=3D"userAccount" entity-name=3D"UserAccount" =
cascade=3D"merge,persist,save-update,lock,refresh" lazy=3D"false" =
insert=3D"true" update=3D"true" not-null=3D"false">
<column not-null=3D"false" unique=3D"false" =
name=3D"`useraccount_useraccount_id`"/>
</many-to-one>
I'm still new to fiddling about with the Eannotations, so please forgive=
me if this is a dumb question.
//Stephen
Re: [Teneo] Setting a 'unique' constraint on a many-to-one reference in hibernate [message #69963 is a reply to message #69943] Fri, 02 February 2007 02:53 Go to previous messageGo to next message
Hi Stephen,
No dumb question, on an ereference you can use the JoinColumn annotation for this (so just replace
Column with JoinColumn).
gr. Martin
Stephen Egan wrote:
> the Ereference:
> <eStructuralFeatures xsi:type="ecore:EReference"
> name="userAccount" eType="#//Support/UserAccount">
> <eAnnotations source="teneo.hibernate">
> <details key="appinfo" value="@Column(unique=&quot;true&quot;)"/>
> </eAnnotations>
> on the generated hibernate mappings for an EReference:
> <many-to-one name="userAccount" entity-name="UserAccount"
> cascade="merge,persist,save-update,lock,refresh" lazy="false"
> insert="true" update="true" not-null="false">
> <column not-null="false" unique="false"
> name="`useraccount_useraccount_id`"/>
> </many-to-one>
> //Stephen
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Setting a 'unique' constraint on a many-to-one reference in hibernate [message #70508 is a reply to message #69963] Mon, 05 February 2007 19:48 Go to previous message
Thanks Martin,
Prompt and accurate as usual!
///Stephen
On Fri, 02 Feb 2007 18:53:27 +1100, Martin Taal <mtaal@elver.org> wrote:=
> Hi Stephen,
> No dumb question, on an ereference you can use the JoinColumn annotati=
on =
> for this (so just replace Column with JoinColumn).
> gr. Martin
> Stephen Egan wrote:
>> Hi,
>> I'm trying to add a unique constraint to a many-to-one Ereference in =
my =
>> ecore model using Eannotaions. I've added the following Eannotation =
to =
>> the Ereference:
>> <eStructuralFeatures xsi:type=3D"ecore:EReference" =
>> name=3D"userAccount" eType=3D"#//Support/UserAccount">
>> <details key=3D"appinfo" =
>> value=3D"@Column(unique=3D&quot;true&quot;)"/>
>> </eAnnotations>
>> This works fine for an Eattribute, but doesn't seem to have any effe=
ct =
>> <many-to-one name=3D"userAccount" entity-name=3D"UserAccount=
>> </many-to-one>
>> I'm still new to fiddling about with the Eannotations, so please =
>> forgive me if this is a dumb question.
>> //Stephen
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: [Teneo] Setting a 'unique' constraint on a many-to-one reference in hibernate [message #601973 is a reply to message #69943] Fri, 02 February 2007 02:53 Go to previous message
Hi Stephen,
gr. Martin
Stephen Egan wrote:
> the Ereference:
> </eAnnotations>
> </many-to-one>
> //Stephen
The Netherlands
Re: [Teneo] Setting a 'unique' constraint on a many-to-one reference in hibernate [message #602179 is a reply to message #69963] Mon, 05 February 2007 19:48 Go to previous message
Thanks Martin,
///Stephen
> Hi Stephen,
on =
> gr. Martin
> Stephen Egan wrote:
>> Hi,
my =
to =
>> the Ereference:
>> </eAnnotations>
ct =
>> </many-to-one>
>> //Stephen
Previous Topic:[teneo] bidirectional OneToOne containment association - container not set in child object
Next Topic:[Teneo] How to set 'cascade="none"' on many-to-one reference in Hibernate
Current Time: Sun Jul 20 03:21:20 EDT 2025
Powered by FUDForum. Page generated in 0.25245 seconds
