Home » Modeling » Graphiti » Calculate minimal width of text in shape
Calculate minimal width of text in shape [message #698875] Wed, 20 July 2011 08:14 Go to next message
My context: I create a shape with an icon and (multi-)text in the AddFeature and I want to set the width of the shape according to the length of the text. Is there already a Graphiti function for doing that?
My current approach is to multiply the text length with a certain factor but this works out not very well. I found another approch by using FontMetrics in another Eclipse forum post, but do not know how to get a drawable from a Graphiti shape.
GC gc = new GC(drawable);
FontMetrics fontMetrics = gc.getFontMetrics();
gc.dispose();
int width = fontMetrics.getAverageCharWidth() * text.toCharArray().length;
Joerg
Re: Calculate minimal width of text in shape [message #698888 is a reply to message #698875] Wed, 20 July 2011 08:33 Go to previous messageGo to next message
Good question. I tried to find something for this as well and could not find it either. Also see this thread: http://www.eclipse.org/forums/index.php/m/651158/?srch=text+graphiti#msg_651158
Jos
Re: Calculate minimal width of text in shape [message #698898 is a reply to message #698888] Wed, 20 July 2011 08:40 Go to previous messageGo to next message
Hi Jos,
with new Shell() the code seems to work.
GC gc = new GC(new Shell());
gc.dispose();
int width = fontMetrics.getAverageCharWidth() * ((text != null) ? text.toCharArray().length : 0);
This was inspired by:
http://www.eclipse.org/forums/index.php/mv/msg/164898/522303/#msg_522303
There is also a FigureUtilities.getTextExtents but this requires a org.eclipse.swt.graphics.Font to pass
http://www.eclipse.org/forums/index.php/mv/msg/3735/11116/#msg_11116
Joerg
Re: Calculate minimal width of text in shape [message #699346 is a reply to message #698898] Thu, 21 July 2011 07:54 Go to previous messageGo to next message
Graphiti provides the UI layout service for doing this
(GraphitiUi.getUiLayoutService().calculateTextSize(String text, Font font)).
As you see it also requires the font (and in the end delegates to draw2D
TextUtilities), but for knowing the correct extend of a text it is important
to know the font because characters might have different widths in different
fonts.
The thread Jos found is a different issue.
HTH,
Michael
"Joerg Reichert" schrieb im Newsbeitrag
news:j06hpp$eli$1@news.eclipse.org...
Hi Jos,
gc.dispose();
Joerg
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Re: Calculate minimal width of text in shape [message #699357 is a reply to message #699346] Thu, 21 July 2011 08:28 Go to previous messageGo to next message
Hi Michael,
sure you need the concrete font properties to calculate the size.
Thanks for pointing to GraphitiUi.getUiLayoutService().calculateTextSize
There are two overloading methods one taking a org.eclipse.graphiti.mm.algorithms.styles.Font
and one taking a org.eclipse.swt.graphics.Font, so it fits will.
Joerg
[Updated on: Thu, 21 July 2011 09:04] by Moderator
Re: Calculate minimal width of text in shape [message #699385 is a reply to message #699357] Thu, 21 July 2011 09:08 Go to previous messageGo to next message
Really, are you sure?
I see org.eclipse.graphiti.mm.algorithms.styles.Font for both the return
value of AbstractText.getFont and the Parameter font in
IUiLayoutService.calculateTextSize.
Michael
news:j095ed$v6m$1@news.eclipse.org...
Hi Michael,
But org.eclipse.graphiti.mm.algorithms.AbstractText#getFont returns
org.eclipse.graphiti.mm.algorithms.styles.Font the method above needs
org.eclipse.swt.graphics.Font. SO you have to convert the Graphiti font
to a SWT font first
org.eclipse.graphiti.ui.internal.util.DataTypeTransformation.toSwtFont(Font
pictogramFont)
When searching for references where this method is used, I found this method
org.eclipse.graphiti.ui.internal.services.impl.GefService.calculateTextSize(String
text, Font font)
that takes a org.eclipse.graphiti.mm.algorithms.styles.Font. So will use
this method instead (although it is in a internal package).
Joerg
Re: Calculate minimal width of text in shape [message #699392 is a reply to message #699385] Thu, 21 July 2011 09:35 Go to previous message
oh, sorry I mixed it up in the Eclipse search result view. There is only one method for org.eclipse.graphiti.mm.algorithms.styles.Font.
Joerg
Previous Topic:ImageProvider using provided images from third-party plugins
Next Topic:Resizing of a Polygon - Bug?
Current Time: Wed Jul 23 17:37:36 EDT 2025
Powered by FUDForum. Page generated in 0.04594 seconds
