Home » Eclipse Projects » Plugin Development Environment (PDE) » How can I see <echo> output from custom build callbacks?
How can I see <echo> output from custom build callbacks? [message #699307] Thu, 21 July 2011 06:10 Go to next message
I have a customBuildCallbacks.xml file and
customBuildCallbacks = customBuildCallbacks.xml
customBuildCallbacks.inheritall = true
in build.properties. However, it isn't working as desired, and I can't even see output from <echo> tasks (whether in Console View or in the terminal from which Eclipse was started) to help with debugging. Are custom build callbacks used at all when doing "Export > Plug-in development > Deployable plug-ins
and fragments"?
Re: How can I see <echo> output from custom build callbacks? [message #714278 is a reply to message #699307] Wed, 10 August 2011 04:12 Go to previous message
I have checked that customBuildCallbacks.xml is called. Unfortunately, the best I can do for output so far is
<concat append="true" destfile="${log.file}">Output</concat>
which doesn't show Ant errors Sad
Previous Topic:Why does a run configuration include unexpected plugins?
Next Topic:Eclipse plugin development Maven repository
Current Time: Sat Jul 26 06:18:28 EDT 2025
Powered by FUDForum. Page generated in 0.04067 seconds
