(no subject) [message #698295] |
Tue, 19 July 2011 04:15  |
I noticed that UML2TOOLS has ceased developing and then found the
Papyrus project. Is the later of the successor of the former? Does
papyrus support code generation (e.g. to Java)?
Warren Tang
(no subject) [message #699287 is a reply to message #698823] |
Thu, 21 July 2011 05:19  |
Hi Mariot
Thanks. In case you are not aware, under
https://bugs.eclipse.org/bugs/show_bug.cgi?id=279638 I'm developing an
Acceleo template for direct OCL to Java generation which you may want to
leverage. Early performance results in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=341944 suggest that in
addition to eliminating the compilation cost at run-time, there may be a
twenty fold speed improvement when comparing equivalent functionality.
The template exploits the modelled standard library, so should extend
naturally to any extended OCL that defines an extended standard library
model.
Ed Willink
On 20/07/2011 10:33, Mariot Chauvin wrote:
> Hi Ed,
> Comments below.
> Le 20/07/2011 00:04, Ed Willink a écrit :
>> Hi
>> Is this available in the real non-social network world ?
>> Regards
>> Ed Willink
>>> For UML to Java generation have a look to
>>> http://www.obeonetwork.com/page/uml-to-java-generator.
>>> Regards,
>>> Mariot
> Being a member gives you access to documentation, and membership is free.
> But I may understand that you want only the code :
> https://github.com/ObeoNetwork/UML-Java-Generation
> Regards,
> Mariot
FUDForum. Page generated in 0.04927 seconds
