[xtext 2.0] Create Scopes [message #699247] |
Thu, 21 July 2011 03:48  |
Hi again.
I read some scoping posts and the documentation but I don't get it. I written my own expression language which has a sub-expression that allows me to reference any EObject. I have several places where I allow to put expressions like on Constant assignments or on array-size specifiers:
ReferenceExpression returns IExpression:
{ReferenceExpression}
reference=[ecore::EObject|QualifiedName]
Constant:
name = ID '=' assignment = Expression ';'
Type:
'type' name = ID
('extends' superType = [Type|QualifiedName])? '{'
elements += TypeMember*
TypeMember:
Constant | TypeDeclarationVariable
TypeDeclarationVariable:
dataType = VariableType name = ID';'
VariableType:
type = DataType ('[' size = Expression ']')?
Now I want to restrict those references depending on where the expression is placed. On this post Alexander tells it's better to use a combination of Java Validation and Content Assist to rebuild scoping (better error messages). But that would lead me to very ugly code (a lot of instanceof checks to check if all elements are references are allowed within the current scope) or I'd have to rebuild the complete scoping system only.
I tried to use the AbstractDeclarativeScopeProvider to implement scoping.
I want to get the following scopes:
Within an constant assignment expression, it's only allowed to reference other Constants no matter where they got declared (globally or within a type). (Constant Scope)
Within a array size expression (VariableType) it's allowed to reference any Constant and any other Variable type declared within the same type declaration. (Constant Scope + Local TypeDeclaration Scope)
public IScope scope_ReferenceExpression_reference(Constant constant, EReference reference) {
List<EClassifier> allConstants = new ArrayList<EClassifier>();
// what to place here?
return Scopes.scopeFor(allConstants);
public IScope scope_ReferenceExpression_reference(Type type, EReference reference) {
List<EClassifier> allConstantsAndLocalVariables = new ArrayList<EClassifier>();
return Scopes.scopeFor(allConstantsAndLocalVariables);
In the documentation I found a description that exactly this behaviour can achieved using Scoping but it doesn't give any code samples how to implement it. I also tried to find algorithms within the source code but I couldn't find any place where it's described how to load specific elements from the global model.
Is there any class which allows me to query the current model like "give me all constants", "give me all variable declarations within this instance" without traversing manually trough the whole model?
Greetings Daniel
[Updated on: Thu, 21 July 2011 03:48] by Moderator
Re: [xtext 2.0] Create Scopes [message #703307 is a reply to message #703111] |
Wed, 27 July 2011 08:22  |
Finally it's done! After hours of work and annoying bugs is solved it using scopes within the JavaValidator. I load a scope for the current model which contains all EObjects. This model contains all elements of the current module inclusive possible duplicates. The problem is: Scopes are shadowing FQN of parent scopes. The solution: I walk up the scope hierarchy (getParent()) and store all URIs of any qualified name in a map. Afterwards I can access this map and check if a specific qualified name contains multiple elements.
Here my solution for everyone:
@Inject
private IResourceScopeCache cache = new IResourceScopeCache.NullImpl();
@Inject
private IQualifiedNameProvider fqnProvider;
@Inject
private IScopeProvider scopeProvider;
private void checkForDuplicates(EObject object, EStructuralFeature errorFeature) {
EObject parent = object.eContainer();
// only check root duplicates, if we prevent root duplicates
// nested type-duplicates are impossible
if (parent == null || !(parent instanceof Model)) {
return;
final Model model = (Model) parent;
// Build up a map which stores all URIs for a specific QualifiedName
// Store the map within a cache for large files
Map<QualifiedName, Set<URI>> duplicates = cache.get("duplicates", model.eResource(),
new Provider<Map<QualifiedName, Set<URI>>>() {
public Map<QualifiedName, Set<URI>> get() {
Map<QualifiedName, Set<URI>> duplicates = new HashMap<QualifiedName, Set<URI>>();
// get the scope for any EObject reference
// replace REFERENCE_EXPRESSION__REFERENCE with
// any EReference which allows all EObject references
// mine is: ReferenceExpression: reference = [ecore::EObject|FQN];
AbstractScope scope = (AbstractScope) scopeProvider.getScope(model,
MyDslPackage.Literals.REFERENCE_EXPRESSION__REFERENCE);
// walk up all parent scopes because scopes are shadowing
// duplicate QualifiedNames
while (scope != null) {
// receive all elements available in this scope
Iterable<IEObjectDescription> elements = scope.getAllElements();
for (IEObjectDescription element : elements) {
// Create a new HashSet for the QualifiedName if needed
QualifiedName qn = element.getName();
if(!duplicates.containsKey(qn)) {
duplicates.put(qn, new HashSet<URI>());
// Add the new ObjectURi to the list
duplicates.get(qn).add(element.getEObjectURI());
// Find the parent scope
if (scope.getParent() instanceof AbstractScope) {
scope = (AbstractScope) scope.getParent();
else {
scope = null;
return duplicates;
// Now we can simply access all URIs of a qualified name
final QualifiedName fqn = fqnProvider.getFullyQualifiedName(object);
if (duplicates.get(fqn).size() > 1) {
error(String.format("Duplicate symbol '%s'", nameResolver.apply(object)),
errorFeature);
// Usage:
@Check
public void checkDuplicateDeclarations(Constant constant) {
checkForDuplicates(constant, MyDslPackage.Literals.CONSTANT__NAME);
There are several improvements possible:
- You can modify the cache only to return your desired qualified name (replace scope.getAllElements())
- Create a project global cache which stores all registered types.
The main performance issue is: Scopes don't allow accessing the getLocalElements method. Therefore we need to check all "un-swallowed" elements multiple times. Would it be worth to create a bug in the bugtracker to make this element public. It's quite annoying that you only can access the elements of all scopes in the hierarchy. Not only the local scope elements.
Restrictions:
- This solution only works if there's one "namespace" declaration within the file. Multiple namespace blocks won't work.
- The scopeProvider don't allow receiving a scope based on a EClass. The EClass is received using the EReference. Therefore you need a Rule which has a CrossReference to an EObject.
[Updated on: Wed, 27 July 2011 08:30] by Moderator
FUDForum. Page generated in 0.32900 seconds
