Home » Modeling » UML2 » How to read UML elements from a loaded file
How to read UML elements from a loaded file [message #699012] |
Wed, 20 July 2011 12:21  |
I tried to read the model elements from the fowlloing .uml file:
<xmi:XMI xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmlns:uml="http://www.eclipse.org/uml2/3.0.0/UML">
<uml:Model xmi:id="_6HP2ALLqEeC4NenKT57Ftw" name="MyFirstModel"/>
<uml:Class xmi:id="_6HP2AbLqEeC4NenKT57Ftw" name="University">
<ownedAttribute xmi:id="_6HP2ArLqEeC4NenKT57Ftw" name="dept_end" association="_6HP2BrLqEeC4NenKT57Ftw"/>
</uml:Class>
<uml:Class xmi:id="_6HP2A7LqEeC4NenKT57Ftw" name="Department">
<ownedAttribute xmi:id="_6HP2BLLqEeC4NenKT57Ftw" name="address" type="_6HP2A7LqEeC4NenKT57Ftw"/>
<ownedAttribute xmi:id="_6HP2BbLqEeC4NenKT57Ftw" association="_6HP2BrLqEeC4NenKT57Ftw"/>
</uml:Class>
<uml:Association xmi:id="_6HP2BrLqEeC4NenKT57Ftw" name="Owns" memberEnd="_6HP2ArLqEeC4NenKT57Ftw _6HP2BbLqEeC4NenKT57Ftw"/>
</xmi:XMI>
which was created from an in-memory model. To read the model, I have the following code:
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("uml", new UMLResourceFactoryImpl());
URI uri = URI.createURI("file:/C:/projects/Myself/MyUMLProject/src/out.uml");
Resource resource = resourceSet.getResource(uri,true);
System.out.println(((Model)resource.getContents().get(0)).toString());
But the last statment gives me the following runtime error:
Exception in thread "main" java.lang.ClassCastException: org.eclipse.emf.ecore.xml.type.impl.AnyTypeImpl
at ReadFile.main(ReadFile.java:30)
But when I save the out.uml using a program, the program calls resource.getContents().add(model) first. So, why I cannot get the first model element after loading out.uml. Also, is there any API which allows me to read all instance of a specific element such as all Class' instances and Asscoaition's instances in a .uml file after it is loaded. Thanks.
wuwei
Re: How to read UML elements from a loaded file [message #699070 is a reply to message #699020] |
Wed, 20 July 2011 15:02   |
Thanks for the update. I get confused about how to use that code.
what does the following statement do?
URI uri = URI.createURI("jar:file:/C:/eclipse/plugins/org.eclipse.uml2.uml.resources_2.0.0.v200606221411.jar!/");
In my previous program, it gives the file to be loaded? Where should I provide the .uml file to be loaded in this case.
Thanks.
Wuwei
Ed Merks wrote on Wed, 20 July 2011 12:28<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
<ul>
<li class="toclevel-1"><a
href="http://wiki.eclipse.org/MDT-UML2-FAQ#What.27s_required_to_load_a_UML_.28.uml.29_resource_from_a_standalone_application.3F"><span
class="tocnumber">6</span> <span class="toctext">What's
required to load a UML (.uml) resource from a standalone
application?</span></a></li>
</ul>
<br>
<br>
On 20/07/2011 9:21 AM, Wuwei wrote:
<blockquote cite="mid:j06uno$sfe$1@news.eclipse.org" type="cite">I
<br>
<br>
<br>
xmlns:xmi=<a class="moz-txt-link-rfc2396E" href="http://schema.omg.org/spec/XMI/2.1">"http://schema.omg.org/spec/XMI/2.1"</a>
xmlns:uml=<a class="moz-txt-link-rfc2396E" href="http://www.eclipse.org/uml2/3.0.0/UML">"http://www.eclipse.org/uml2/3.0.0/UML"</a>>
<br>
<br>
name="University">
<br>
<br>
</uml:Class>
<br>
name="Department">
<br>
<br>
<br>
</uml:Class>
<br>
<br>
</xmi:XMI>
<br>
<br>
<br>
<br>
<br>
<br>
URI uri =
URI.createURI(<a class="moz-txt-link-rfc2396E" href="file:/C:/projects/Myself/MyUMLProject/src/out.uml">"file:/C:/projects/Myself/MyUMLProject/src/out.uml"</a>);
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
wuwei <br>
</blockquote>
</body>
</html>
Re: How to read UML elements from a loaded file [message #699074 is a reply to message #699070] |
Wed, 20 July 2011 15:14   |
Comments below.
It's just initialization code.
> URI uri =
It's the base URI for locating things that are needed within the jars.
What you have is fine. You just need to be sure you've initialized the
environment properly.
> Thanks.
> Wuwei
>> <html>
>> <head>
>> </head>
>> <ul>
>> </ul>
>> <br>
>> <br>
>> <br>
>> <br>
>> <?xml version="1.0" encoding="UTF-8"?>
>> <br>
>> <br>
>> <br>
>> name="University">
>> <br>
>> <br>
>> </uml:Class>
>> <br>
>> name="Department">
>> <br>
>> <br>
>> <br>
>> </uml:Class>
>> <br>
>> <br>
>> </xmi:XMI>
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> URI uri =
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> wuwei <br>
>> </blockquote>
>> </body>
>> </html>
Re: How to read UML elements from a loaded file [message #699084 is a reply to message #699074] |
Wed, 20 July 2011 15:34   |
I still have a question. So to be sure, I want to verify the following statementS.
My comment starts with // in CAPITALS.
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
Map uriMap = resourceSet.getURIConverter().getURIMap();
URI uri = URI.createURI("jar:file:/D:/Eclipse_Related_SW/Eclipse_Plugins/UML2_v3.2/eclipse/plugins/org.eclipse.uml2.uml.source_3.2.0.v201105231350.jar!/");
// I CHANGE THE ABOVE STATEMENT GIVING THE LOCATON OF THE BASE URI, RIGHT ?
uriMap.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP), uri.appendSegment("libraries").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.METAMODELS_PATHMAP), uri.appendSegment("metamodels").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP), uri.appendSegment("profiles").appendSegment(""));
// NO CHANGES here, right?
/* resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("uml", new UMLResourceFactoryImpl());
URI uri = URI.createURI("file:/D:/projects/Myself/MyUMLProject/src/Superstructure.uml");
Resource resource = resourceSet.createResource(uri);
// SINCE I COMMENT OUT THE TWO STATEMENTS ABOVE TO LOAD THE UML FILE, HOW CAN I DO HERE?
Thanks.
Ed Merks wrote on Wed, 20 July 2011 15:14Comments below.
> URI uri =
> Thanks.
> Wuwei
>> <html>
>> <head>
>> </head>
>> <ul>
>> </ul>
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> name="University">
>> <br>
>> <br>
>> </uml:Class>
>> <br>
>> name="Department">
>> <br>
>> <br>
>> <br>
>> </uml:Class>
>> <br>
>> <br>
>> </xmi:XMI>
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> URI uri =
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> <br>
>> wuwei <br>
>> </blockquote>
>> </body>
>> </html>
Re: How to read UML elements from a loaded file [message #699097 is a reply to message #699084] |
Wed, 20 July 2011 16:08   |
Comments below.
> statementS.
> URI uri =
> RIGHT ?
Yes, you'd better find that jar's location/version on your machine.
Yep.
> URI uri =
> HOW CAN I DO HERE?
What you had before should work nicely:
URI uri =
With the UML package properly registered, it should create UML instances
for you.
> Thanks.
>> Comments below.
>> > URI uri = >
>> > In my previous program, it gives the file to be loaded? What you
>> > Thanks.
>> > Wuwei
>> >> <html>
>> >> <head>
>> >> </head>
>> >> <ul>
>> >> </ul>
>> >> <br>
>> >> <br>
>> >> <br>
>> >> <br>
>> >> <br>
>> >> xmlns:xmi=<a class="moz-txt-link-rfc2396E" >>
>> >> xmlns:uml=<a class="moz-txt-link-rfc2396E" >>
>> >> <br>
>> >> <br>
>> >> name="University">
>> >> <br>
>> >> <br>
>> >> </uml:Class>
>> >> <br>
>> >> name="Department">
>> >> <br>
>> >> <br>
>> >> <br>
>> >> </uml:Class>
>> >> <br>
>> >> <br>
>> >> </xmi:XMI>
>> >> <br>
>> >> <br>
>> >> <br>
>> >> <br>
>> >> <br>
>> >> <br>
>> >> URI uri =
>> >> URI.createURI(<a class="moz-txt-link-rfc2396E" >>
>> >> <br>
>> >> <br>
>> >> <br>
>> >> <br>
>> >> <br>
>> >> <br>
>> >> <br>
>> >> <br>
>> >> <br>
>> >> <br>
>> >> <br>
>> get the
>> any API
>> such as
>> >> <br>
>> >> wuwei <br>
>> >> </blockquote>
>> >> </body>
>> >> </html>
Re: How to read UML elements from a loaded file [message #699113 is a reply to message #699106] |
Wed, 20 July 2011 17:13  |
I'm not so familiar with the UML2 model to know all the places that
Class and Association can be contained. Looking at the model definition
should help you answer that.
On 20/07/2011 1:41 PM, Wuwei wrote:
> Thanks, Ed. It works. Now, is there any easy way to get
> all instances of an element such as Class and Association
> in the UML model? Right I iterate each element to check its
> type via instanceof. Thanks.
> Wuwei
Current Time: Wed Jul 23 04:49:50 EDT 2025
Powered by FUDForum. Page generated in 0.08502 seconds
