Home » Modeling » EMF » How to use an external editor to edit attributes of type EString(instead of using the properties view)
How to use an external editor to edit attributes of type EString [message #698962] Wed, 20 July 2011 10:50 Go to next message
At some point in the metamodel that I have defined there's a class which contains an attribute of type EString. This attribute aims to store the body of a C++ method .
Sadly writing C++ code within the standard properties view is not usable in practice.
That's why I would like to add a command in the context menu of the attribute (in the tree view of the EMF Editor ) to open its value within an external text editor, the best would be the CDT editor.
Editor are usually associated with file extension ? So should I create a temporary file for each instances of this attribute and then open-it with the CDT editor ? How to handle the synchronization of the data between the two views ?
I don't really know where to start to done this in a proper way so suggestions are welcome.
Marc Palyart
Re: How to use an external editor to edit attributes of type EString [message #698967 is a reply to message #698962] Wed, 20 July 2011 10:55 Go to previous messageGo to next message
Marc,
Comments below.
On 20/07/2011 7:51 AM, Marc Palyart wrote:
> usable in practice.
You'd certainly need a multi-line editor; you can configure that in the
GenFeature...
Typically yes.
It's likely that it will only work with contents in a resource...
Typically though it would need to work with a complex context...
Good question. I've not solved a problem like this before...
You could always just force the user to do cut and paste between some
editor and the multi-line entry field.
> Thanks
> Marc Palyart
Re: How to use an external editor to edit attributes of type EString [message #698974 is a reply to message #698967] Wed, 20 July 2011 11:17 Go to previous messageGo to next message
Thanks Ed for the answer.
I've already enabled the multi-line feature in the GenModel but writing C++ source code in this view is not really user-friendly.
Regarding the copy/paste approach that's the current way but I was hoping that the integration of external editors for editing part of EMF model was not so complicated.
It would be marvelous to be able in EMF to define easily different viewpoints on the model (this part of the model can be edited with this editor or this one, this other part can be edited with this editor...), maybe it's planned ?
Marc Palyart
Re: How to use an external editor to edit attributes of type EString [message #698988 is a reply to message #698974] Wed, 20 July 2011 11:38 Go to previous message
Marc,
Certainly EMF supports models that cross resource boundaries so one
might imagine if you had a model for C++ you could just refer to
something in a C++ resource. Syncing up the value of an attribute with
the contents of some other resource isn't something we have designs or
plans for...
> Marc Palyart
Previous Topic:Using GenModel Redirection Pattern to change a single filename
Next Topic:Setting different default values for Inherited attributes
Current Time: Fri Jul 18 03:06:21 EDT 2025
Powered by FUDForum. Page generated in 0.12798 seconds
