Home » Archived » BIRT » Changing a line style/width/color dynamically?
Changing a line style/width/color dynamically? [message #698891] Wed, 20 July 2011 08:35 Go to next message
Is there a way to change the line attributes of a line graph on the fly? For example, I have a series that shows value X, but I'd like the series line to be solid when another data attribute Y is true and dashed when Y is false. Is this possible?
Re: Changing a line style/width/color dynamically? [message #698961 is a reply to message #698891] Wed, 20 July 2011 10:49 Go to previous messageGo to next message
From a priority point of view I have used a different technique to visualize what I am after, however I'd still like to know the answer to this for future reference.
What I did was add a new series that plots the same data as the original and conditioned the value based on the data attribute Y (see above) else null. This way I can set the line attributes any way I want and just make sure that the Z order of this series is on top of the original series.
This works for me as I actually wanted the legend to show information for the "annotated" part of the plot so a new series actually works better than just changing the line attributes on the fly.
(no subject) [message #698991 is a reply to message #698961] Wed, 20 July 2011 11:45 Go to previous messageGo to next message
You should be able to do this with a beforeGeneration script like::
function beforeGeneration( chart, icsc )
importPackage( Packages.org.eclipse.birt.chart.model.attribute );
importPackage( Packages.org.eclipse.birt.chart.model.attribute.impl );
importPackage( Packages.org.eclipse.birt.chart.model.component.impl );
importPackage( Packages.org.eclipse.birt.chart.model.data.impl );
var newxAxis = chart.getBaseAxes()[0];
var newyAxis = chart.getOrthogonalAxes( newxAxis, true)[0]
var newseriesDef = newyAxis.getSeriesDefinitions().get(0)
var runSeries = newseriesDef.getRunTimeSeries().get(0);
runSeries.getLineAttributes().setStyle(LineStyle.DASHED_LITERAL);
LineStyle has
DASH_DOTTED_LITERAL
DASHED_LITERAL
DOTTED_LITERAL
SOLID_LITERAL
Jason
Re: (no subject) [message #699004 is a reply to message #698991] Wed, 20 July 2011 12:13 Go to previous messageGo to next message
I think you misunderstood my requirement. I am looking for a way to change the line attributes for just portions of the line, not the entire line. For example, make a portion of the line if the value is above 100 red and blue otherwise, etc...
Re: (no subject) [message #699015 is a reply to message #699004] Wed, 20 July 2011 12:16 Go to previous message
I do not think this is currently possible with the current line series.
It would be a good idea to log a bug for this if you do not mind.
Jason
Previous Topic:Birt connexion to Hive
Next Topic:how to calculate uptime as java expression
Current Time: Fri Jul 25 22:46:33 EDT 2025
Powered by FUDForum. Page generated in 0.04176 seconds
