Home » Modeling » Epsilon » [Epsilon] Not F.A.Q.
[Epsilon] Not F.A.Q. [message #698205] |
Mon, 18 July 2011 21:53  |
Hi Dimitris,
here the questions repost.
A) Help Questions:
- How can an EOL module import external modules from installed plugins in the the eclipse target platform or from other open projects?
- How can registered metamodels in the Metemodel Registry of Epsilon be unregistered?
- How can I use the debugger in the SVN?
B) More About Epsilon Plugins - Questions
- Is it possible to parametrize EVL messages with what is found in the check part. I mean to have global variables in a rule. For example if I count something, I want to inform the number to the user but I don't want to repeat the query in the message part.
- Is it possible to include cases in the EVL check parts, I mean include if statements in order not to repeat EVL instructions in multiple rules.
- Is it possible to use ModelLink of two models conforming to different metamodels?
- Does ModelLink defines eclipse extension points to link n-models?
- Is it possible to include custom annotations to Epsilon languages in different levels (i.e. context, rule definition, named block, message).
C) Epsilon with Xtext, Xpand Questions:
- Is it possible to override an EOL module? Or is it possible to override an EOL fragment (part of the body or of an operation)? Like in Xpand <<AROUND>>.
- Have you tried to use EVL to validate a model written with an Xtext-DSL, or do you know about any try on this way?
- Have you tried to create an extension language of EOL with Xtext in order to have the benefits from both of them? Or do you know about any try on this?
Thanks.
Silvia
[Updated on: Mon, 18 July 2011 22:14] by Moderator
Re: [Epsilon] Not F.A.Q. [message #698384 is a reply to message #698205] |
Tue, 19 July 2011 07:42   |
Hi Silvia,
Please see comments below.
You can use platform:/plugin/com.x.y/... URIs for the former, and platform:/resource/... or relative paths for the latter.
This is not possible at the minute. Could you please file an enhancement request and we'll fix this asap?
You need to set breakpoints in your E*L programs and then instead of launching using the Run button, do so using the Debug button. We plan to create screencasts and an article that discusses the debugger shortly so this should hopefully answer any more questions you may have on this.
Yes, variables in the check part are also available in the message part
Yes. Instead of check: <condition> you can use check { statement; statement; return boolean; } for more complicated code. I believe this is discussed in the EVL chapter of the book but I need to double-check this.
Yes.
ModeLink can link n models. I'm not sure I understand how eclipse extension points relate to this.
Epsilon supports annotations in some constructs (e.g. operations in EOL, rules in ETL/EML/ECL, constraints in EVL) but not in others (e.g. check part of an EVL constraint). Could you please file an enhancement request for this one too?
You can override an EOL operation with another operation with the same name/parameters
Yes. The process is very similar to this one http://eclipse.org/gmt/epsilon/doc/articles/evl-gmf-integration/ as Xtext reuses the EMF validation framework.
We do have an internal project running on redefining the EOL parser using Xtext but I wouldn't expect any results to be made publicly available for at least 6 months.
Dimitris
Re: [Epsilon] Not F.A.Q. [message #699257 is a reply to message #699162] |
Thu, 21 July 2011 03:36   |
Dear Silvia,
Many thanks for trying this out. ANT's class loader is forever causing
problems. I remember coming across this at one point, but cannot quite
remember what I did to fix it. Dimitris, Louis, do you have a suggestion?
In any case, you seem to be able to do more than me at the moment: My
Eclipse installation is currently refusing to do any Epsilon work at all
:-( . It is good to hear, though, that you can get something to work,
because it means that this is a problem with my installation rather than
with Epsilon or the extensions. I am still looking into this and as soon
as I can get my Eclipse setup to work again I will hopefully be able to
figure out a solution... I'll report back...
Best,
Steffen
On 21/07/2011 02:23, Silvia wrote:
> Hi Steffen,
> It seems the svn path in sourceforge change to:
> https://epsilonlabs.svn.sourceforge.net/svnroot/epsilonlabs
> I downloaded and successfully installed from there. The ant tasks were
> installed. But I have the following error:
> \EJB3Generation\workflow\build.xml:23: Problem: failed to create task
> or type epsilon.eglRegister
> Cause: Could not load a dependent class EglTask
> This class may be in a separate JAR that is not installed.
> Action: Determine what extra JAR files are needed, and place them in
> one of:
> -<ECLIPSE_PATH>\plugins\org.apache.ant_1.7.1.v20100518-1145\lib
> -<SYSTEM_USER_PATH>\.ant\lib
> -a directory added on the command line with the -lib argument
> Do not panic, this is a common problem.
> The commonest cause is a missing JAR.
> This is not a bug; it is a configuration problem
> The epsilon tasks are installed, and I can run other workflows calling
> the epsilon.egl task in the same jre of eclipse. I'm using Epsilon
> (Incubation) version 0.9.0.201106111013, could this be related?
> Silvia
Re: [Epsilon] Not F.A.Q. [message #699279 is a reply to message #699257] |
Thu, 21 July 2011 05:07  |
Hi Steffen,
I believe is not a problem with your extension, although when I imported it one of the plugins didn't compile because it couldn't find the *.epsilon.workflow.jar. I first imported from the svn the workflow project and it didn't work, as the head version is missing an import class for the EglTask. import org.eclipse.epsilon.egl.formatter.Formatter; Then I imported the installed version and the ao extension compiled. So I think is related to the location of this plugin and its dependencies.
Hope you solve your setup problems.
Silvia
Current Time: Sat Jul 26 11:08:26 EDT 2025
Powered by FUDForum. Page generated in 0.06179 seconds
