Home » Archived » BIRT » Birt connexion to Hive(new feature of Birt 3.7 => Hive driver)
Birt connexion to Hive [message #698804] Wed, 20 July 2011 04:55 Go to next message
Hi all,
I am currently trying to connect Birt 3.7 to Hive 0.7.0 with the new plugin, but I am experiencing troubles... My configuration is a windows 7 on which I run Birt 3.7 and a virtual machine with the pre-packed cloudera : CDH3u0 on ubuntu 10.10. The VM is accessible at 192.168.18.129 from my local and I can run Hue beeswax from both the VM and windows.
The only documentation I found on this matter is the Birt's new feature page..Here are the points where I am blocking:
- First the validation button in birt does not work, but it's no big deal..
- Then the lack of description regarding the syntax : I use "jdbc:hive://192.168.18.129:10000/default" but I can only assume it's correct.
- Regarding the id/pwd I use cloudera/cloudera as they are the one set for hive.
- The "Add file statement" is not very clear also, I didn't find any documentation on that point, so I tried several things such as "add file /user/hive/warehouse/sample_07/sample_07.csv" which seems to look like the print screen on Birt's new feature page...
So, up to now, I haven't been able to settle the connexion and I placed the only log I have as a join file.
I hope someone was able to go further than me and take some time to explain how he managed to..
Thank you in advance,
Al
  • Attachment: birt_log.txt
    (Size: 5.11KB, Downloaded 250 times)
Re: Birt connexion to Hive [message #698972 is a reply to message #698804] Wed, 20 July 2011 11:08 Go to previous messageGo to next message
Can you try adding slf4j-log4j12-1.6.1.jar and slf4j-api-1.6.1.jar from
the hive distribution to the list of jars you added using the manage
drivers button. After you do this, you may want to restart eclipse and
try your connection again.
The jdbc connection string looks fine as long as hive is running on port
10000. The add file property is used if you are using a custom
map/reduce script. Like
Select
transform ...
using 'python mytest.py'
then you would want the mytest.py in your add file property
If you are not using it you do not need the add file property. Just
leave it blank.
Jason
On 7/20/2011 4:55 AM, al wrote:
> Hi all,
> Al
Re: Birt connexion to Hive [message #698985 is a reply to message #698972] Wed, 20 July 2011 11:18 Go to previous messageGo to next message
Al
Let me know if this works and I will put up a wiki page for it.
Jason
> Select
> transform ...
> leave it blank.
> Jason
>> Hi all,
>> VM and windows.
>> deal..
>> correct.
>> for hive.
>> Al
Re: Birt connexion to Hive [message #698997 is a reply to message #698985] Wed, 20 July 2011 11:59 Go to previous messageGo to next message
Hi Jason,
Thank you very much for your time!
I tried adding the jar files, and the "test connection" is now working. I deleted the add file statement also, because I'm only trying to connect to a single Hive table for now.
I still have the following log inside the test connection pop up:
org.eclipse.birt.report.data.oda.jdbc.JDBCException: There is an error in get connection, Could not establish connecton to 192.168.18.129:10000/default: java.net.ConnectException: Connection refused: connect.
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.doConnect(JDBCDriverManager.java:264)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.getConnection(JDBCDriverManager.java:188)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.tryCreateConnection(JDBCDriverManager.java:728)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.testConnection(JDBCDriverManager.java:634)
at org.eclipse.birt.report.data.oda.jdbc.ui.util.DriverLoader.testConnection(DriverLoader.java:120)
at org.eclipse.birt.report.data.oda.hive.ui.profile.HiveSelectionPageHelper.testConnection(HiveSelectionPageHelper.java:410)
at org.eclipse.birt.report.data.oda.hive.ui.profile.HiveSelectionPageHelper.access$4(HiveSelectionPageHelper.java:398)
at org.eclipse.birt.report.data.oda.hive.ui.profile.HiveSelectionPageHelper$2.widgetSelected(HiveSelectionPageHelper.java:340)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.birt.report.designer.ui.dialogs.BaseDialog.open(BaseDialog.java:111)
at org.eclipse.birt.report.designer.data.ui.actions.EditDataSourceAction.doAction(EditDataSourceAction.java:69)
at org.eclipse.birt.report.designer.internal.ui.views.actions.AbstractElementAction.run(AbstractElementAction.java:70)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.birt.report.designer.ui.rcp.DesignerApplication.run(DesignerApplication.java:38)
at org.eclipse.equinox.internal.app.EclipseAppContainer.callMethodWithException(EclipseAppContainer.java:587)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:198)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Re: Birt connexion to Hive [message #699009 is a reply to message #698997] Wed, 20 July 2011 12:13 Go to previous message
Do you have the hiveservice running on the hadoop box?
$ bin/hive --service hiveserver
Jason
On 7/20/2011 11:59 AM, al wrote:
> Hi Jason,
> refused: connect.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> at
> at
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
Previous Topic:Birt and Hive
Next Topic:Changing a line style/width/color dynamically?
Current Time: Wed Jul 23 14:54:56 EDT 2025
Powered by FUDForum. Page generated in 0.06448 seconds
