Home » Archived » M2M (model-to-model transformation) » [ATL] random function available?
[ATL] random function available? [message #69868] Tue, 18 December 2007 12:31 Go to next message
Originally posted by: r.c.ladan.tue.nl
I wonder if there is a random() function available in ATL since I need this in a program for work.
An alternative would be to post-process the output in Java (e.g. substituting strings 'RANDOM' with a random value).
Rene
Re: [ATL] random function available? [message #715185 is a reply to message #69868] Fri, 12 August 2011 12:00 Go to previous messageGo to next message
I also need it... some news? i need to invoke a rule using random function...I mean that in the input filter i would like to have a random calculation that decides if execute or not the rule...
Re: [ATL] random function available? [message #716014 is a reply to message #715185] Tue, 16 August 2011 04:21 Go to previous messageGo to next message
You can modify the ATL VM engine to add a random function or you can add an EOperation in your meta-model that you will call in the ATL code.
Re: [ATL] random function available? [message #716399 is a reply to message #716014] Wed, 17 August 2011 05:59 Go to previous messageGo to next message
can you provide more info on the second option? thx again
Re: [ATL] random function available? [message #716456 is a reply to message #716399] Wed, 17 August 2011 09:05 Go to previous messageGo to next message
I don't know how to use EOperation... can I define a EOperation that calls a java method like random in MAth class??
Re: [ATL] random function available? [message #716460 is a reply to message #716456] Wed, 17 August 2011 09:22 Go to previous messageGo to next message
Yes of course. EOperation are EMF things. Watch for the corresponding documentation.
Re: [ATL] random function available? [message #716765 is a reply to message #69868] Thu, 18 August 2011 07:38 Go to previous messageGo to next message
ok...I defined an EOperation on my mm.... but now...I'm working on ecore in input metamodel and I guess I have to call s.refInvokeOperation(p.name, Sequence{}); ...
if i print s.eoperations i receive the right operation name...but if i try to call it i receive an error:
org.eclipse.m2m.atl.engine.emfvm.VMException: Operation getRandom not found on EClass
do you know why??
Re: [ATL] random function available? [message #717602 is a reply to message #69868] Sun, 21 August 2011 12:34 Go to previous message
i defied correctly (i think) the eoperation...generated model code... defined the body of the Impl of the eoperation with my function...but:
Operation getRandom not found on C
Previous Topic:execute rule only for one object
Next Topic:[ATL] Getting ATL output file to correspond to correct Meta-Model
Current Time: Sat Jul 26 14:14:08 EDT 2025
Powered by FUDForum. Page generated in 0.09778 seconds
