Home » Eclipse Projects » Equinox » Difference between Bundles and Management Bundles
Difference between Bundles and Management Bundles [message #68699] Wed, 21 June 2006 05:46 Go to next message
Originally posted by: Hubert.Farnsworth.gmx.de
this question might have already appeared, but I found no matching thread.
What is the difference between a simple Bundle and a Management Bundle
and how can I create a Management Bundle?
Management Bundles occured several times in the OSGi-Specs (I need one
to access the PermissionAdmin-Service), but I never figured out how to
create one.
Thanks for answering,
Holger
PS: anyone knows a good OSGi-Tutorial or Wiki?
Re: Difference between Bundles and Management Bundles [message #69653 is a reply to message #68699] Tue, 11 July 2006 22:57 Go to previous messageGo to next message
Originally posted by: p.p.com
there was a good tutorial at eclipse con 2006 and the slides are available
online,
"Holger Lauinger" <Hubert.Farnsworth@gmx.de> wrote in message
news:e7b4gp$pk1$1@utils.eclipse.org...
> create one.
> Holger
Re: Difference between Bundles and Management Bundles [message #69863 is a reply to message #68699] Thu, 13 July 2006 16:47 Go to previous messageGo to next message
Hi Holger,
There is no fundamental difference between a management bundle and a
simple bundle. Each can use the features provided by the framework
(Import-Package, Export-Package, publish and use OSGi Services etc.).
The reason the OSGi specification makes a distinction on a management
bundle is because these types of bundles generally need a very high
level of permissions (in most cases AllPermissions is needed) than
normal bundles in order to perform operations that are considered to be
management operations. Such as
installing/starting/stopping/uninstalling bundles, using PermissonAdmin
Service, using PackageAdmin service, etc.
HTH
Tom
Re: Difference between Bundles and Management Bundles [message #70096 is a reply to message #69863] Mon, 17 July 2006 03:19 Go to previous message
Thank you Tom,
the reason I was asking is that in several parts of the documentation
there are references to Management Bundles in the form of "only a
Management Bundle can do that...". Therefor I assumend that there should
be a little more about it.
Happy Day,
Holger
Tom Watson schrieb:
> Hi Holger,
> HTH
> Tom
Previous Topic:Declarative services: how to set a property?
Next Topic:How to auto-startup a bundle in server-side?
Current Time: Wed Sep 03 22:04:40 EDT 2025
Powered by FUDForum. Page generated in 0.55888 seconds
