Home » Archived » BIRT » Internet Explorer 9 not displaying BIRT 2.5 reports
icon9.gif  Internet Explorer 9 not displaying BIRT 2.5 reports [message #698547] Tue, 19 July 2011 12:40 Go to next message
I've inherited a system built around BIRT 2.5 and the embedded BIRT viewer.
The reports seem to work fine in Chrome, Firefox and versions of IE previous to 9 but in IE 9 they fail to show and I can only get a blank screen with no error message.
The strange thing is, if I use the developer tools in IE 9 and set the document mode to IE7 or IE8 then refresh the page the reports work as expected.
Does anyone have any idea how to resolve this? I have a feeling that it may be JavaScript related somehow. I know that I'm in an old version of BIRT but unfortunately upgrading isn't an option right now.
Thanks.
Re: Internet Explorer 9 not displaying BIRT 2.5 reports [message #698617 is a reply to message #698547] Tue, 19 July 2011 16:16 Go to previous messageGo to next message
Can you verify that you have cookies enabled?
Jason
> expected.
> Thanks.
Re: Internet Explorer 9 not displaying BIRT 2.5 reports [message #703440 is a reply to message #698617] Wed, 27 July 2011 11:20 Go to previous messageGo to next message
Hi Jason,
Yes, cookies are enabled.
To clarify, in IE 9 I just get the "Processing, please wait..." message -- the report never actually renders. In other browsers, including earlier versions of IE the report renders fine.
In IE 9, when debugging I've noticed I get a JavaScript error in this section of AbstractBaseReportDocument.js.
if (BrowserUtility.isIE) {
    var reportContainer = this.__instance.firstChild;
    if (reportContainer != null) {
        var scrollBarWidth = BrowserUtility._getScrollBarWidth(reportContainer, width, height);
        var containerWidth = "100%";
        if (height < reportContainer.offsetHeight && width > scrollBarWidth) {
	     containerWidth = (width - scrollBarWidth) + "px";
        reportContainer.style.overflowX = "visible";
        reportContainer.style.overflowY = "visible";
        reportContainer.style.position = "relative";
        reportContainer.style.width = containerWidth;
The actual error is:
Unable to set value of the property 'overflowX': object is null or undefined
When I toggle IE 9's Document Mode between 9 and 8 I can see that the type and content of reportContainer varies between the two modes.
Re: Internet Explorer 9 not displaying BIRT 2.5 reports [message #703466 is a reply to message #703440] Wed, 27 July 2011 11:36 Go to previous messageGo to next message
What url are you using?
I assume you can not try with 3.7?
What happens if you put an if( reportContainer.style != null ){ around
the reportContainer lines?
Jason
On 7/27/2011 11:20 AM, Brian wrote:
> Hi Jason,
> width, height);
> undefined
Re: Internet Explorer 9 not displaying BIRT 2.5 reports [message #703482 is a reply to message #703466] Wed, 27 July 2011 12:05 Go to previous messageGo to next message
The report is embedded in an IFRAME, so the URL is something like:
...://test.dom/birt-viewer/output?__report=organisation.rptdesign$period=3&userId=2
If I check update the JavaScript to check that the reportContainer isn't null, I don't get the same error but the report still fails to render. Interestingly, when I debug the JavaScript in IE I see this:
In IE 9 reportContainer is a type of Object, Text
In IE 8 reportContainer is DispHTMLDivElement
I'm working on getting a 3.7 environment setup on a sandbox as we speak. I can't upgrade to 3.7 on the environment that's showing this bug, as this is a mirror of a production environment.
Re: Internet Explorer 9 not displaying BIRT 2.5 reports [message #703517 is a reply to message #703482] Wed, 27 July 2011 12:36 Go to previous messageGo to next message
Why are you using the output mapping? Can you open a bug for this?
Jason
Re: Internet Explorer 9 not displaying BIRT 2.5 reports [message #780687 is a reply to message #698547] Wed, 18 January 2012 23:09 Go to previous messageGo to next message
Was there ever a solution found to this problem? I'm having the exact same problem using the Birt 3.7 Viewer. I've tried setting the X-UA-Compatible meta tag, which didn't seem to help with the error. The viewer runs fine in IE 9 in compatibility mode and fine outside of an iframe.
The JavaScript Error is as follows:
User Agent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.1; WOW64; Trident/5.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; InfoPath.3)
Timestamp: Thu, 19 Jan 2012 03:13:01 UTC
Message: Unable to set value of the property 'overflowX': object is null or undefined
Line: 171
Char: 5
Code: 0
URI: localhost:8443/birt/webcontent/birt/ajax/ui/report/AbstractBaseReportDocument.js
Re: Internet Explorer 9 not displaying BIRT 2.5 reports [message #780878 is a reply to message #780687] Thu, 19 January 2012 13:55 Go to previous messageGo to next message
Shane,
can you add your issue to this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=350736
Also how are you running it with an iframe? Or just the standard viewer
with no customizations?
Jason
> iframe.
> or undefined
> Line: 171
> Char: 5
> Code: 0
> URI:
Re: Internet Explorer 9 not displaying BIRT 2.5 reports [message #780904 is a reply to message #780878] Thu, 19 January 2012 16:21 Go to previous messageGo to next message
I am running the viewer in an iframe. I haven't modified the viewer code at all.
The error seems to occur when I use frameset. The preview works fine, but for my requirements I really need to use the frameset with the different export options (csv, excel, pdf, etc.).
The viewer seems to run fine in IE 9 in compatibility mode. It also runs fine outside of an iframe. It seems to be the exact same issue that Brian logged in this thread.
Does anyone know of a temporary workaround/fix?
I'll log the bug as requested.
Re: Internet Explorer 9 not displaying BIRT 2.5 reports [message #781148 is a reply to message #780904] Fri, 20 January 2012 12:56 Go to previous messageGo to next message
Have you tried the BIRT tag libraries? I am trying reproduce this error
and I can not seem to do that.
Jason
> at all.
Re: Internet Explorer 9 not displaying BIRT 2.5 reports [message #781155 is a reply to message #781148] Fri, 20 January 2012 13:14 Go to previous messageGo to next message
I am running a PHP application so was trying to run the reports in an iframe to avoid using the Java Bridge. The reports work fine in IE9 outside of an iframe. Have you tryed using an iframe?
I assume the tag libraries require the use of JSP pages?
Re: Internet Explorer 9 not displaying BIRT 2.5 reports [message #782387 is a reply to message #781155] Mon, 23 January 2012 11:27 Go to previous messageGo to next message
I tried it with an iframe in a jsp page and it worked for me.
I tried this with BIRT 2.5.2.
Jason
> Thanks
Re: Internet Explorer 9 not displaying BIRT 2.5 reports [message #784902 is a reply to message #782387] Sat, 28 January 2012 00:42 Go to previous messageGo to next message
It works on all browsers for me except IE 9. Did you try IE 9? If you run IE 9 in compatibility mode, it works for me as well.
Re: Internet Explorer 9 not displaying BIRT 2.5 reports [message #786591 is a reply to message #784902] Mon, 30 January 2012 10:58 Go to previous messageGo to next message
What mode are you running IE 9 in when it fails?
Jason
> Thanks
Re: Internet Explorer 9 not displaying BIRT 2.5 reports [message #786621 is a reply to message #698547] Mon, 30 January 2012 11:49 Go to previous message
I was finally able to get the following to work:
Added the following headers to my PHP script:
header('X-UA-Compatible: IE=7');
header('X-UA-Compatible: IE=EmulateIE7');
Deleted the browser cache and completely closed IE 9. Now I no longer get the JavaScript error running on IE 9.
Shane
Previous Topic:Error While Creating Data Source
Next Topic:Birt Client side scripting
Current Time: Sat Jul 19 03:01:24 EDT 2025
Powered by FUDForum. Page generated in 0.04445 seconds
