Home » Archived » Jubula » Testing SWT controls on a splash screen
Testing SWT controls on a splash screen [message #698278] Tue, 19 July 2011 03:43 Go to next message
I have a problem using Jubula to test an RCP application that contains a splash screen with SWT controls. I want to test the controls in the splash but the object mapping mode don't work at this time. The splash screen is used as a log-in screen. After the log-in, when the real application started, everything works fine.
So what is the problem? Are the Jubula plug-ins not loaded at splash screen time?
Can anybody help me?
Thanks for help!
Christian
Re: Testing SWT controls on a splash screen [message #698410 is a reply to message #698278] Tue, 19 July 2011 08:41 Go to previous message
the RCP remote control plugin for component recognition is not yet loaded when the splash screen appears. For dialogs such as workspace choosers, a test can get around this by setting the workspace as a part of the AUT configuration (using the -data option), in the AUT Arguments. If your application can be started with login parameters, then this would be the route to use.
Hope that helps!
Alex
Previous Topic:Jubula Control Flow
Next Topic:Error 7009: Test Execution Error during replay of recorded actions
Current Time: Sun Aug 31 02:28:57 EDT 2025
Powered by FUDForum. Page generated in 0.08053 seconds
