Home » Modeling » GMF (Graphical Modeling Framework) » Restricting attribute value choice
Restricting attribute value choice [message #697945] Mon, 18 July 2011 08:45 Go to next message
Hi !
I would like to know is there is a way to filter attribute choice for a field, instead of letting user choose any value and validating his choise with a constraint after.
What i need is a kind of StateMachine owning States, and i want to be able to choose the initial State of my machine.
I managed to make a constraint to prevent to select a State owned by a different machine, but they are still in the list, and i don't know how to fix it.
Any help is welcome !
Thanks in advance,
Valerian
Re: Restricting attribute value choice [message #698042 is a reply to message #697945] Mon, 18 July 2011 11:30 Go to previous messageGo to next message
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
<ul>
<li class="toclevel-2"><a
href="http://wiki.eclipse.org/index.php/EMF-FAQ#How_can_I_control_which_instances_are_available_as_choices_when_editing_a_property_in_the_properties_view.3F"><span
class="tocnumber">2.46</span> <span class="toctext">How can
I control which instances are available as choices when
editing a property in the properties view?</span></a></li>
</ul>
<br>
<br>
On 18/07/2011 5:45 AM, <a class="moz-txt-link-abbreviated" href="mailto:forums-noreply@eclipse.org">forums-noreply@eclipse.org</a> wrote:
<blockquote cite="mid:j019ae$9i5$1@news.eclipse.org" type="cite">Hi
<br>
<br>
<br>
<br>
be able to choose the initial State of my machine. I managed to
know how to fix it.
<br>
<br>
<br>
<br>
Thanks in advance, <br>
Valerian
<br>
<br>
</blockquote>
</body>
</html>
Re: Restricting attribute value choice [message #698291 is a reply to message #698042] Tue, 19 July 2011 04:18 Go to previous messageGo to next message
Nice it works perfectly, thanks a lot !
Re: Restricting attribute value choice [message #821618 is a reply to message #698291] Thu, 15 March 2012 12:02 Go to previous messageGo to next message
Hi, I want to do exactly what this message says, that is, to restrict the choice values in a list. As far as I understand, if I type this, there should not be any option available in the list, because I have not written any "coiceOfValue.add(object);":
   * This adds a property descriptor for the Foo feature.
   * <!-- begin-user-doc -->
   * <!-- end-user-doc -->
   * @generated NOT
  protected void addFooPropertyDescriptor(Object object)
    itemPropertyDescriptors.add
      (new ItemPropertyDescriptor
        (((ComposeableAdapterFactory)adapterFactory).getRootAdapterFactory(),
         getResourceLocator(),
         getString("_UI_Abc_foo_feature"),
         getString("_UI_PropertyDescriptor_description", "_UI_Abc_foo_feature", "_UI_Abc_type"),
         XyzPackage.Literals.ABC__FOO,
         true,
         false,
         true,
         null,
         null,
         null)
        public Collection<?> getChoiceOfValues(Object object)
          List<Object> choiceOfValues = new ArrayList<Object>(super.getChoiceOfValues(object));
          // Filter the choices before returning them.
          return choiceOfValues;
But if I type that still all the options are available, as they were before. What am I missing??
Thanks in advance!
Re: Restricting attribute value choice [message #821700 is a reply to message #821618] Thu, 15 March 2012 13:59 Go to previous messageGo to next message
Well, that's because you initialize the arraylist you are returning with
Re: Restricting attribute value choice [message #822464 is a reply to message #821700] Fri, 16 March 2012 13:00 Go to previous message
You are right. Thanks!
Previous Topic:refreshing/repainting figures in a diagram
Next Topic:Disable tool palette when opening an editor
Current Time: Sun Jul 27 16:25:21 EDT 2025
Powered by FUDForum. Page generated in 0.03833 seconds
