Home » Archived » BIRT » Smart PIE Chart
Smart PIE Chart [message #697239] Fri, 15 July 2011 17:30 Go to next message
For a group data like 60, 20, 10, 5, 4, 0.5, 0.25, 0.125,........
I can add a filter to only have the TOP 5 values with their category name in the PIE Chart, and the other values are lost.
Is there a way to have a Pie Chart like:
Display the TOP 5 values in different pieces with their corresponding category name, and the others(with small values from 0.5 to 0.125) in a single piece named" the Others"
Thanks in advance,
Scroon
[Updated on: Mon, 18 July 2011 09:29] by Moderator
Re: Dynamic Pie Chart [message #697990 is a reply to message #697239] Mon, 18 July 2011 10:49 Go to previous messageGo to next message
Can you remove the top n filter and just set a min slice value?
Set it on the third tab of the chart wizard under Series->Category
Series. See attached example.
Jason
On 7/15/2011 5:30 PM, Scroon wrote:
> Hello,
> category name, and the others(with small values) in a single piece
> named" the Others"
> Thanks in advance,
> Scroon
Re: Dynamic Pie Chart [message #697994 is a reply to message #697990] Mon, 18 July 2011 11:11 Go to previous messageGo to next message
Jason Weathersby wrote on Mon, 18 July 2011 10:49
Jason
> Hello,
> named" the Others"
> Thanks in advance,
> Scroon
Thanks Jason, it works well.
But the fixed min slice value is not very lovely....Since the value of data for pie chart changed significantly each time. Sometimes all the data fell into the "Others", sometime none of them...
I tried to use a parameter in the min slice value like "params["valueoftop5"].value" but it didn't work. The pie chart wizard seems does not support JavaScript for min slice value..
Can I set the min slice value with JavaScript in some event of the Pie chart plz?
Best,
Scroon
Re: Dynamic Pie Chart [message #698009 is a reply to message #697994] Mon, 18 July 2011 11:25 Go to previous messageGo to next message
Scroon
I modified the example to show it tied to a parameter. Look at the
beforeDataSetFilled script.
Jason
>> Jason
>> > Hello,
>> > named" the Others"
>> > Thanks in advance,
>> > Scroon
> chart plz?
> Best,
> Scroon
Re: Dynamic Pie Chart [message #698120 is a reply to message #698009] Mon, 18 July 2011 16:03 Go to previous message
Jason Weathersby wrote on Mon, 18 July 2011 11:25
Scroon
Jason
>> Jason
>> > Hello,
>> > named" the Others"
>> > Thanks in advance,
>> > Scroon
> chart plz?
> Best,
> Scroon
Hello Jason,
Thanks so much for your help, now I can set the min slice value dynamically.
Best,
Scroon
[Updated on: Mon, 18 July 2011 16:04] by Moderator
Previous Topic:birt.ini
Next Topic:birt interactive viewer is not working in IE8
Current Time: Wed Jul 23 07:35:13 EDT 2025
Powered by FUDForum. Page generated in 0.51860 seconds
