Home » Eclipse Projects » Eclipse 4 » XWT - ATL(XWT Ecore file)
XWT - ATL [message #696866] Thu, 14 July 2011 21:47 Go to next message
Dear all,
I am actually working on ATL.
I would like to know if there is any ecore file describing the XWT metamodel.
While looking into the forums closest thing I found was the XWT.getAllMetaclasses() method to create manually an ecore file.
Is it the only way to get an ecore file?
Thank you in advance,
Re: XWT - ATL [message #697887 is a reply to message #696866] Mon, 18 July 2011 05:32 Go to previous messageGo to next message
There is no (ecore) meta model for XWT.
Though, it may be interesting to derive an ecore meta model from the XWT MetaClasses...
Re: XWT - ATL [message #697900 is a reply to message #697887] Mon, 18 July 2011 06:03 Go to previous messageGo to next message
Dear Erdal Karaca,
Thank you very much for you answer.
I would like to ask a related question, I know that it may sound a little bit naïve, but is there any XSD Schema available?
Re: XWT - ATL [message #698131 is a reply to message #697900] Mon, 18 July 2011 16:40 Go to previous messageGo to next message
Creating an XSD is even harder to achieve... Just consider this xml fragment:
<text text="Hello" />
The following has the same semantics:
<text>
<text.text>Hello</text.text>
</text>
I am not sure whether defining an xsd to handle all of this would be much fun...
Re: XWT - ATL [message #698292 is a reply to message #698131] Tue, 19 July 2011 04:22 Go to previous message
Dear Erdal,
Ok, thank you very much for the information
Previous Topic:org.eclipse.ui.preferencePages example
Next Topic:Use of 3.x plugins in e4
Current Time: Sat Jul 19 01:20:34 EDT 2025
Powered by FUDForum. Page generated in 0.08608 seconds
