| can't make VE to work with eclipse3 [message #69709] |
Tue, 02 November 2004 23:06  |
Originally posted by: eclipse3.spymac.com
i am a newbie to eclipse, i have copied ve into eclipse directory, and i
can see the plugin features in about eclipse platform, but i can't open
..java file with ve editor, i couldn't see the option there inside the
menu. thanks very much :)
Andy
| Re: can't make VE to work with eclipse3 [message #70276 is a reply to message #69709] |
Mon, 08 November 2004 11:14  |
Originally posted by: steve.sclarkes.me.uk
"andy" <eclipse3@spymac.com> wrote in message
news:cm9kur$nil$1@eclipse.org...
>.java file with ve editor, i couldn't see the option there inside the menu.
>thanks very much :)
> Andy
I'm having the same problem. I've tried everything mentioned in all the
various posts on this subject but without success.
For the record I installed via unzipping the following files:
eclipse-JDT-SDK-3.0.1.zip
eclipse-platform-SDK-3.0.1-win32.zip
emf-sdo-SDK-2.0.1.zip
GEF-SDK-3.0.1.zip
VE-SDK-1.0.1.1.zip
I didn't start eclipse at all until all files were unzipped.
I installed into a new directory and a clean workspace.
I tried -clean.
There were no errors logged.
I also tried with the runtime versions rather than SDKs ... and many other
combinations.
I tried under Linux as well as Windows.
I tried using update manager to install VE.
After many hours I'm about to give up ! Any more ideas ?
Steve
| Re: can't make VE to work with eclipse3 [message #602542 is a reply to message #69709] |
Wed, 03 November 2004 09:57  |
Make sure you also installed Eclipse SDK (not the RCP, or runtime), EMF
2.0.1, and GEF 3.0.1, and make sure you ran eclipse once with the -clean
option.
Rich Kulp
| Re: can't make VE to work with eclipse3 [message #602554 is a reply to message #69811] |
Wed, 03 November 2004 10:01  |
OR use the update manager instead, it will tell you what pre-reqs are
required and not allow an install until then, and it makes sure
everything is installed correctly.
I recommend using the update manager when you want to installed released
versions of code.
Rich Kulp
| Re: can't make VE to work with eclipse3 [message #602597 is a reply to message #69846] |
Thu, 04 November 2004 00:06  |
thanks so much:)
i am going to try it now
> versions of code.
| Re: can't make VE to work with eclipse3 [message #602697 is a reply to message #69709] |
>thanks very much :)
> Andy
GEF-SDK-3.0.1.zip
VE-SDK-1.0.1.1.zip
I tried -clean.
combinations.
Steve
FUDForum. Page generated in 0.05238 seconds
