Home » Archived » Buckminster » Problems installing Buckminster on Indigo
Problems installing Buckminster on Indigo [message #696830] Thu, 14 July 2011 18:34 Go to next message
Hi All,
I encountered problems installing Buckminster on Indigo from
http://download.eclipse.org/tools/buckminster/updates-3.7
I followed the instructions of the CDO source installation and created a new
Eclipse installation and only installed the CDO required features. However
when trying to install Buckminster I have the folowing errors. (I also tried
some archives found on the Buckminster download page which gave the same
erros)
help is appriciated, Koos
An error occurred while collecting items to be installed
session context was:(profile=SDKProfile,
phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=,
action=).
Retry another mirror
Problems downloading artifact:
osgi.bundle,org.eclipse.buckminster.model.common,1.1.0.v20110629-1242.
Unpacking fails because intermediate file is empty:
C:\DOCUME~1\Koos\LOCALS~1\Temp\work25645\p2.optimizers.incoming25640.jar
osgi.bundle,org.eclipse.buckminster.model.common.edit,1.1.0.v20110629-1242.
C:\DOCUME~1\Koos\LOCALS~1\Temp\work23950\p2.optimizers.incoming23944.jar
osgi.bundle,org.eclipse.buckminster.mspec,1.1.0.v20110629-1242.
C:\DOCUME~1\Koos\LOCALS~1\Temp\work24425\p2.optimizers.incoming24413.jar
osgi.bundle,org.eclipse.buckminster.mspec.edit,1.1.0.v20110629-1242.
C:\DOCUME~1\Koos\LOCALS~1\Temp\work24072\p2.optimizers.incoming24070.jar
osgi.bundle,org.eclipse.buckminster.mspec.editor,1.0.0.v20110629-1242.
C:\DOCUME~1\Koos\LOCALS~1\Temp\work25361\p2.optimizers.incoming25358.jar
osgi.bundle,org.eclipse.buckminster.rmap,1.1.0.v20110629-1242.
C:\DOCUME~1\Koos\LOCALS~1\Temp\work25812\p2.optimizers.incoming25809.jar
osgi.bundle,org.eclipse.buckminster.rmap.edit,1.1.0.v20110629-1242.
C:\DOCUME~1\Koos\LOCALS~1\Temp\work24442\p2.optimizers.incoming24439.jar
osgi.bundle,org.eclipse.buckminster.rmap.editor,1.0.0.v20110629-1242.
C:\DOCUME~1\Koos\LOCALS~1\Temp\work25896\p2.optimizers.incoming25892.jar
osgi.bundle,org.eclipse.buckminster.rmap.pde,1.0.0.v20110629-1242.
C:\DOCUME~1\Koos\LOCALS~1\Temp\work26285\p2.optimizers.incoming26284.jar
osgi.bundle,org.eclipse.buckminster.rmap.pde.edit,1.0.0.v20110629-1242.
C:\DOCUME~1\Koos\LOCALS~1\Temp\work25701\p2.optimizers.incoming25698.jar
Re: Problems installing Buckminster on Indigo [message #696969 is a reply to message #696830] Fri, 15 July 2011 04:12 Go to previous messageGo to next message
Sounds like you encountered some kind of network problem. I just tried to install Buckminster into a fresh Indigo IDE
installation from http://download.eclipse.org/tools/buckminster/updates-3.7 and everything installed without problems so
our update site is OK.
- thomas
On 2011-07-15 00:34, Koos de Goede wrote:
> Hi All,
> erros)
> action=).
Re: Problems installing Buckminster on Indigo [message #697085 is a reply to message #696969] Fri, 15 July 2011 09:15 Go to previous messageGo to next message
Hi Thomas,
Thanks for your quick answer. I dowloaded a fresh Indigo and tried the
install again but stil have the same error as below at the same point.
Yesterday I have dowloaded several archives from:
http://archive.eclipse.org/tools/buckminster/archivedsites-3.7/
containing an update site which I stored locally having the same errors as
shown below, all other installs such as EMF/GMF and other install wothout
errors.
Is there somewhere a zip available which I can install the old way? e.g.
unpack and run eclipse with -clean?
Koos
"Thomas Hallgren" <thomas@tada.se> wrote in message
news:ivos7h$ikm$1@news.eclipse.org...
> install Buckminster into a fresh Indigo IDE installation from
> installed without problems so our update site is OK.
> - thomas
>> Hi All,
>> new
>> However
>> tried
>> erros)
>> action=).
Re: Problems installing Buckminster on Indigo [message #697086 is a reply to message #697085] Fri, 15 July 2011 09:38 Go to previous messageGo to next message
What type of JVM are you using? Is it very old? From the looks of it the install might fail when unpacking the pack200
files.
On 2011-07-15 15:15, Koos de Goede wrote:
> Hi Thomas,
> errors.
No, sorry. That's not a viable approach in a modern eclipse.
- thomas
Re: Problems installing Buckminster on Indigo [message #697091 is a reply to message #697086] Fri, 15 July 2011 09:51 Go to previous messageGo to next message
Hi Thomas,
I am using : jre1.5.0_06
Koos
news:ivpf99$7l8$1@news.eclipse.org...
> install might fail when unpacking the pack200 files.
>> Hi Thomas,
>> as
>> errors.
> - thomas
Re: Problems installing Buckminster on Indigo [message #697120 is a reply to message #697091] Fri, 15 July 2011 10:57 Go to previous messageGo to next message
On 2011-07-15 15:51, Koos de Goede wrote:
> Hi Thomas,
Could you try updating to a more modern JVM ;-) ? Java 1.5 has reached its end of life in October 2009.
http://www.oracle.com/technetwork/java/javase/eol-135779.html
- thomas
Re: Problems installing Buckminster on Indigo [message #697140 is a reply to message #697120] Fri, 15 July 2011 11:45 Go to previous message
Hi Thomas,
Thanks very much for your support, updating the JDK does the trick,
Koos
news:ivpjut$chu$1@news.eclipse.org...
>> Hi Thomas,
> - thomas
Previous Topic:Solutions to &quot;Circular Component Dependency Issue with JDT&quot;
Next Topic:Git Auto-Fetch not working
Current Time: Sat Jul 26 07:53:24 EDT 2025
Powered by FUDForum. Page generated in 0.55250 seconds
