Home » Modeling » GMF (Graphical Modeling Framework) » Initail position of a node & palette changed at runtime
Initail position of a node & palette changed at runtime [message #697040] Fri, 15 July 2011 07:33 Go to next message
Hi all.
I've got 2 problem with my editor.
First i would like to set initial position of a node in the diagram when the diagram is created and when the diagram is refreshed.
User must still be abele to move and resize nodes
I'v tryed diffrent solution like:
h**p://wiki.eclipse.org/Graphical_Modeling_Framework/Tips#Setting_Initial_Position_of_a_Node
and other post on the eclipse forum, but always without achive my goal.
When i try to set the node constraint, i still get the "cannot write in Read Only Transaction" also using editingDomain and command.
I need a hint on how solve this.
My second question ia about plaette. Is possible to change it at runtime? i need to hide/unide tool at runtime.
Tanks in advance.
Mauro P.
Re: Initail position of a node & palette changed at runtime [message #697043 is a reply to message #697040] Fri, 15 July 2011 07:48 Go to previous messageGo to next message
this is my code:
public void activate() {
	super.activate();
	AbstractEMFOperation emfOp = new AbstractEMFOperation(getEditingDomain(), "Location setting") {
		protected IStatus doExecute(IProgressMonitor monitor, IAdaptable info) throws ExecutionException {
			Location lc = (Location) ((Node) getModel()).getLayoutConstraint();
			int x=10;
			int y=10;
			//TODO: ---here the logic to calculate node position
			lc.setX(x);
			lc.setY(y);
			return Status.OK_STATUS;
	try {
		OperationHistoryFactory.getOperationHistory().execute(emfOp, null, null);
	} catch (ExecutionException e) {
		e.printStackTrace();
this the printStackTrace
Caused by: java.lang.IllegalStateException: Cannot activate read/write transaction in read-only transaction context
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.acquire(TransactionalEditingDomainImpl.java:561)
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.activate(TransactionalEditingDomainImpl.java:493)
at org.eclipse.emf.transaction.impl.TransactionImpl.start(TransactionImpl.java:204)
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.startTransaction(TransactionalEditingDomainImpl.java:409)
at org.eclipse.emf.workspace.AbstractEMFOperation.createTransaction(AbstractEMFOperation.java:617)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:147)
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:511)
... 44 more
After some test, i've noticed that the above code works perfectly the first time the nodes are created, it start to throw exception when i call the refresh method on XXXDiagramEditPart.
Because i need to set node position after a Diagram.refresh() is there a way to solve this?
[Updated on: Fri, 15 July 2011 08:11] by Moderator
Re: Initail position of a node & palette changed at runtime [message #700167 is a reply to message #697043] Fri, 22 July 2011 19:25 Go to previous message
For who will have the same problem and he/she will still need an easy solution, i've found it.
The big mistake is trying to set the LayoutConstraint on the node...
you should set the constraint on the parent of the node like this(I will post my few and easy line of code):
        //here we are in the EditPart of the node we want set the initial position
		super.activate();
                //The new rectangle rapresenting the new position and size of the node
                //size to -1 means "use preferredSize"
		Rectangle r = new Rectangle(0, 0, -1, -1);
                ((GraphicalEditPart) getParent()).setLayoutConstraint(this, getFigure(), r);
That is my code. has you can see no need to use command to do that, like suggest in other posts or tutorial.
You need to set the object constraint only on the parent (the diagram EditPart)
Hope this could help someone.
Previous Topic:GMF : Unhandled event loop exception error
Next Topic:how to add custom properties inside standard Advanced proerty tab
Current Time: Thu Jul 24 22:18:30 EDT 2025
Powered by FUDForum. Page generated in 0.03611 seconds
