Home » Modeling » UML2 » runtime error when creating a simple class in a java program
runtime error when creating a simple class in a java program [message #696778] Thu, 14 July 2011 16:00 Go to next message
I try to use java to create a simple class diagram. But I get some runtime error.
Here is the code:
Model myModel = UMLFactory.eINSTANCE.createModel();
//myModel.setName("MyFirstModel");
Class department = UMLFactory.eINSTANCE.createClass();
Property dept_name = UMLFactory.eINSTANCE.createProperty();
dept_name.setName("address");
dept_name.setType(department);
department.getOwnedAttributes().add(dept_name);
It seems the above setter methods dont work and neither does add. The error I got
is:
Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/uml2/common/util/CacheAdapter
at org.eclipse.uml2.uml.internal.impl.ElementImpl.getCacheAdapter(ElementImpl.java:714)
at org.eclipse.uml2.uml.internal.impl.ElementImpl.eNotificationRequired(ElementImpl.java:852)
at org.eclipse.uml2.uml.internal.impl.NamedElementImpl.setName(NamedElementImpl.java:263)
at MyUML.main(MyUML.java:17)
Thanks.
Re: runtime error when creating a simple class in a java program [message #696817 is a reply to message #696778] Thu, 14 July 2011 17:12 Go to previous messageGo to next message
HI
Looks familiar. I suspect that you haven't replicated the Eclipse plugin
registrations for standalone usage.
You may find org.eclipse.ocl.uml.OCL.initialize(ResourceSet) helpful.
Ed Willink
> runtime error.
> Here is the code:
> error I got
> is:
> at
> at
> at
> Thanks.
Re: runtime error when creating a simple class in a java program [message #696818 is a reply to message #696817] Thu, 14 July 2011 17:50 Go to previous messageGo to next message
Hi, Ed,
I don't get your idea. Can you tell me what I should do in details. What I did
is to just create a Java Project and then add those jar files to the library since
I only want to play with the UML2's implemenation. Thanks.
Edward Willink wrote on Thu, 14 July 2011 17:12
HI
Ed Willink
> runtime error.
> Here is the code:
> error I got
> is:
> at
> at
> at
> Thanks.
Re: runtime error when creating a simple class in a java program [message #696833 is a reply to message #696818] Thu, 14 July 2011 18:41 Go to previous messageGo to next message
In which jar is the CacheAdapter class and have you put it on your
classpath? I assume you've looked it
http://wiki.eclipse.org/MDT/UML2/FAQ too...
On 14/07/2011 2:50 PM, Wuwei wrote:
> Hi, Ed,
> What I did
> library since
>> HI
>> plugin registrations for standalone usage.
>> Regards
>> Ed Willink
>> > runtime error.
>> > Here is the code:
>> The > error I got
>> > is:
>> > Exception in thread "main" java.lang.NoClassDefFoundError: >
>> > at >
>> > at >
>> > at >
>> > Thanks.
Re: runtime error when creating a simple class in a java program [message #696834 is a reply to message #696818] Thu, 14 July 2011 18:41 Go to previous messageGo to next message
> Hi, Ed,
> What I did
> library since
>> HI
>> Regards
>> Ed Willink
>> > runtime error.
>> > Here is the code:
>> The > error I got
>> > is:
>> > at >
>> > at >
>> > at >
>> > Thanks.
Re: runtime error when creating a simple class in a java program [message #696865 is a reply to message #696834] Thu, 14 July 2011 21:44 Go to previous messageGo to next message
Ed,
Sorry, how do I know which jar has CacheAdapter? I tried to read the
FAQ but not quite understand it. I think Q. 6 might be relevant to my
problem but have no idea how to solve it. Thanks.
Ed Merks wrote on Thu, 14 July 2011 18:41
> Hi, Ed,
> What I did
> library since
>> HI
>> Regards
>> Ed Willink
>> > runtime error.
>> > Here is the code:
>> The > error I got
>> > is:
>> > at >
>> > at >
>> > at >
>> > Thanks.
Re: runtime error when creating a simple class in a java program [message #696877 is a reply to message #696865] Thu, 14 July 2011 22:50 Go to previous message
Ctrl-Shift-T can be very helpful for finding a class. You can use the
"Link with Editor" button in the project explorer to find out where that
file is located. I'll bet you can guess which jar it's in just from the
package name and looking at the bundle names...
On 14/07/2011 6:44 PM, Wuwei wrote:
> Ed,
>> > Hi, Ed,
>> details. > What I did
>> the > library since
>> >> HI
>> >> Regards
>> >> Ed Willink
>> some >> > runtime error.
>> >> > Here is the code:
>> add. >> The > error I got
>> >> > is:
>> >> > Exception in thread "main" java.lang.NoClassDefFoundError: > >>
>> >> > at > >>
>> >> > at > >>
>> >> > at > >>
>> >> > Thanks.
Previous Topic:UML2 installation question
Next Topic:Fundamental question on array/list instance specifications for UML interaction call messages
Current Time: Wed Jul 23 10:48:57 EDT 2025
Powered by FUDForum. Page generated in 0.05731 seconds
