Home » Eclipse Projects » Eclipse Platform » Making view visible throws IndexOutOfBoundsException
Making view visible throws IndexOutOfBoundsException [message #696365] Wed, 13 July 2011 15:39 Go to next message
I have a view that is displayed automatically when the editor becomes
active. If the editor is opened following selection of an IResource,
everything works. However, if it is restored from the previous session,
and the editor is not active when restored (i.e. some other editor has
focus), then making this editor active again throws
IndexOutOfBoundsException in this code fragment:
IWorkbenchPage page = getSite().getWorkbenchWindow().getActivePage();
try {
if (page != null) {
MyView view = (MyView) page.findView(MyView.ID);
if (view == null) {
page.showView(MyView.ID, null, IWorkbenchPage.VIEW_CREATE); //
line 1068: throws IndexOutOfBoundsException
The exception is:
java.lang.IndexOutOfBoundsException: Index: -1, Size: 3
at java.util.ArrayList.add(ArrayList.java:367)
at org.eclipse.ui.internal.PartStack.replace(PartStack.java:912)
at
org.eclipse.ui.internal.PerspectiveHelper.addPart(PerspectiveHelper.java:400)
at org.eclipse.ui.internal.Perspective.showView(Perspective.java:2331)
at
org.eclipse.ui.internal.WorkbenchPage.busyShowView(WorkbenchPage.java:1071)
at org.eclipse.ui.internal.WorkbenchPage$20.run(WorkbenchPage.java:3822)
at
org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage.java:3819)
at
MyEditor.updateMyView(MyEditor.java:1068)
Any idea as to what to look for?
Alex Molochnikov
Fugro Seismic Imaging
Re: Making view visible throws IndexOutOfBoundsException [message #698000 is a reply to message #696365] Mon, 18 July 2011 11:19 Go to previous message
You might have to put your view creation in a job or display.asyncExec(*) to allow your editor part creation to finish before the showView(*) is called.
If that doesn't help, please open a bug at https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform&component=UI
PW
Previous Topic:dynamically installing a presentation reconciler
Next Topic:How to customize property of a project in Eclipse?
Current Time: Wed Jul 23 14:56:42 EDT 2025
Powered by FUDForum. Page generated in 0.06650 seconds
