Home » Eclipse Projects » Virgo » Dump Inspector problem(Admin console doesn't read dumps)
Dump Inspector problem [message #696209] Wed, 13 July 2011 10:01 Go to next message
In M06 no dumps are listed in both Dump Inspector and Osgi State explorer. I tried to deploy simple two-bundle par with unresolved dependencies, which caused dump to be generated in serviceability dir. The same test case worked fine in M05 - dumps are listed in admin console. Am I missing some new configuration in M06, or is it a bug?
Re: Dump Inspector problem [message #696211 is a reply to message #696209] Wed, 13 July 2011 10:07 Go to previous messageGo to next message
It's a bug, but I am not immediately aware of changes in M06 that would obviously have caused it. Please could you raise the bug.
As a temporary workaround, you can probably copy the relevant dump directory to a M05 instance and use the M05 admin console to view it.
Re: Dump Inspector problem [message #696244 is a reply to message #696211] Wed, 13 July 2011 10:59 Go to previous messageGo to next message
M05 couldn't read the M06 dump.
I raised the bug.
Re: Dump Inspector problem [message #696266 is a reply to message #696244] Wed, 13 July 2011 11:35 Go to previous message
Thanks for raising the bug!
I'm a bit surprised that M05 couldn't read it, but I guess the reason is that the region digraph has moved on somewhat between M05 and M06.
Previous Topic:Unresolved dependency on com.sun.security.auth
Next Topic:The Closure of Event-Based Communication between Spring DM Extender and Spring-Power Bundlers
Current Time: Fri Jul 25 21:08:43 EDT 2025
Powered by FUDForum. Page generated in 0.03543 seconds
