Home » Newcomers » Newcomers » Can't start eclipse after install on XP
Can't start eclipse after install on XP [message #68700] Tue, 24 May 2005 09:57 Go to next message
Originally posted by: bpwoolfolk.hotmail.com
I get the following when I try to start eclipse on XP:
java.lang.RuntimeException: Exception while creating System Bundle: Unable
to find system bundle manifest file.
at
org.eclipse.osgi.framework.internal.core.Framework.createSys temBundle(Framework.java:253)
(i've omitted the rest of the stack trace for brevity).
I set my PATH variable to include the Java runtime, 1.4.2_08. Any clues
would be appreciated
Thx,
Bernie
Re: Can't start eclipse after install on XP [message #69611 is a reply to message #68700] Thu, 26 May 2005 01:13 Go to previous message
Was java installed using the Java installer?
Can you run java from the command line?
How did you install eclipse?
Which version?
Previous Topic:Eclipse Startup Problem
Next Topic:Early startup
Current Time: Fri Sep 19 02:33:33 EDT 2025
Powered by FUDForum. Page generated in 0.07730 seconds
