Home » Archived » Voicetools » Call drops when it gets to DB query module
Re: Call drops when it gets to DB query module [message #694527 is a reply to message #694222] |
Fri, 08 July 2011 14:56   |
Hi Sergej--
I think we've found the problem. In the db export screen, you're
specifying
sqljdbc4.jar
as the JDBC Driver -- what it's actually looking for here is a class
file name (hence the error you're seeing), whereas this is the actual .
jar file name. Try something like this:
com.microsoft.sqlserver.jdbc.SQLServerDriver
And here's the document I got this from:
http://msdn.microsoft.com/en-us/library/ms378526.aspx
I'm not 100% sure this is the right answer for what should be in that
field, but at least we've identified the problem, so hopefully this
helps you along the way.
Good luck,
Randy
In <iv67ql$6h5$1@news.eclipse.org> Sergej wrote:
> Hi Randy!
> Here are few screenshots of db module conf. and db export conf.
> Hope it will help us to resolve this issue.
> Brgds and thanks in advance!
> Sergej
> M_]C_X``02D9)1@`!`0$`8`!@``#_VP!#``(!`0(!`0("`@("`@("`P4#`P,#
> M`P8$!`,%!P8'!P<&!P<("0L)"`@*"`<'"@T*"@L,#`P,!PD.#PT,#@L,#`S_
> MVP!#`0("`@,#`P8#`P8,"`<(#`P,#`P,#`P,#`P,#`P,#`P,#`P,#`P,#`P,
> M#`P,#`P,#`P,#`P,#`P,#`P,#`P,#`S_P``1"`'``GD#`2(``A$!`Q$!_\0`
> M'P```04!`0$!`0$```````````$"`P0%!@<("0H+_\0`M1```@$#`P($`P4%
> M!`0```%]`0(#``01!1(A,4$&$U%A!R)Q%#*!D:$((T*QP152T?`D,V)R@@D*
> M%A<8&1HE)B<H*2HT-38W.#DZ0T1%1D=(24I35%565UA96F-D969G:&EJ<W1U
> M=G=X>7J#A(6&AXB)BI*3E)66EYB9FJ*CI*6FIZBIJK*SM+6VMC9VN'BX^3EYN?HZ>KQ\O/T]?;W^/GZ_\0`'P$``P$!`0$!
> M`0$!`0````````$"`P0%!@<("0H+_\0`M1$``@$"!`0#!`<%!`0``0)W``$"
> M`Q$$!2$Q!A)!40=A<1,B,H$(%$*1H;'!"2,S4O`58G+1"A8D-.$E\1<8&1HF
> M)R@I*C4V-S@Y.D-$149'2$E*4U155E=865IC9&5F9VAI:G-T=79W>'EZ@H.$
> MA8:'B(F*DI.4E9:7F)F:HJ.DI::GJ*FJLK.TM;:WN+FZPL/$Q<;'R,G*TM/4
> MU=;7V-G:XN/DY>;GZ.GJ\O/T]?;W^/GZ_]H`#`,!``(1`Q$`/P#4U"WT*U6XO`
> M6P.QJ>$`S(&^Z2,UXU^VC\5M,\>V-OI6H:]8:/)HV8N+W1$<X!`!$NIQD=>X
> MS]*_7X7]K&C%675]CY'!X&%:E*O5E;6R_,]OT*UAUVV2>VFAN('^Z\3AU;Z$
> M<5TNG>!C<*#MZU\=_P#!,C7O(^+OB?1K#Q8_B+1VL!=R0"YTB>.SF$JJI'V/
> M4;J12ZL_WHU4_M%?!SPA\;_VE?A%HGC3PMX<\7Z-]CURX^P:WIL.
> MH6OFK':A7\N567<,G!QD9/K7#G&(GA':&NJ7;=I>>Q%+"PYW%O0]9_X5N".E
> M)_PK0>@_*OE;0_CYXB^#O@WQ)X5^#(M]7LH/&FH6G@G3_P"R$UVW.BV6GVKZ
> M@('GU;3H8K2UU&:6!2;DK%@01Q%54(?"O]K?Q]XJ\8ZG\4-8\4Z!H/@Z3N65^G>5_1,^J#\,P?X136^&0QRHKXU\0?
> MM(_%GXKZWX-TCQ58^#O"OCWP?\9+'2+";5+&.SM8DN_#5[(CW-I:ZI?@RJ9W
> M*0I?*9\PH3`7+#M/'_[='Q4T/X?ZAHVCKX0U_P")_AW6->@NFTCPW]JTG5=,
> MTP0^;?*MWK5DEFL3W5M!,INHW>F]DH.3_P"W>=<R
> M\FU>SL5,J4?9):\Z7WMU$E\U3;3\[=K_`$7<_"T,/NUFW/PH&[^W#X
> ML\+1^%_%FN6&EZ7X/\3^$/M()T0&.5G:2.WWOV(OCC\6_CC%<ZE\0/!MEI/AC5=+M=5T'5K2/3X8+CS<L
> M85^S:OJ)N$\MHW6X(MPPS^Z&1CJ>.J*M*@+;M)\L\'&
> M-*%?"/CSPOXFUZUOO$6K.BZKX)@M;J7^S%LGYR7;X&D_S]>]CU
> MV7X4C'W:K2?"<?W:\>^&WC\!W;_%
> M#PREWX3L](LKFR2/7I(X&MM(DFFN)#<M<F<E&2.$HMO+D,/F&]/-9R5TGTWT
> M^)-Q6MM9<KMYV6^A-3`QC4]DVKZ]?Y6E+_P%O7[]M3V.7X3#^
> MGI%MY$ZPB1+6]$&%9XHF1?+,L<8636&:U.::E\,&]?\`#!3;MO\`#=Z7^'NX
> MINIED%2IS3UFD[=5>4H_G%7V^+LFU[)<?",'M5.;X/AOX:\<\1?MK_$+P#\&
> MXO&.HWGPR\11>+O`>J^,M`M-'LF$_
> M?`1Q_$K]LWXD?!K3=9MB2.Z^U7JQW
> M"`LKQ2^?:+<>5(N(/OC?^UY1E>EYQ7SVLFSUJ?X.`_PU4E^#`S]VN"T'XY?'C5AX3\.ZOX=\)^#/$_
> MB+6;^S_M#6M.$T4EC!9I<)=+8V6IW`1S(7A,37QR$\W<N1%7!_#+XP>+_`GA
> M;PCJ7CA_#/Q%O)OB-XMM+69=#G34--2S@UR4BT>:#BM-3T:WU;PY>M%9_9P9'!>-%M
> M=7NVU`B!]\;$V*RM'M)B\S='W/B;XJ2^._V)M3\0:?XC@N
> MX\QR?4Z/-9O3OTZ/3:^_RV=A'^!@;^"H7^!&3]VN#UC]G'X.3?%CXKWGC#PM
> MX0L](\$Z'HT=EJT]M#:W'AJVBM9B'M;L;9+0Q[0RO$Z%&4$$$`URMO\`MC?$
> M0@9)V697\J*PN-K<.4#C
> M;G2XCFV^?3WN5=>LDF]-+\C?7K:]C2GE<*D.>'W/1MKMW_X;N>QM\!1CT/XN?%#P'X(\31KK^D^*O%&M^/-1TCPSI]MX3ENYBL+W$D\9^T:Q
> M;PB-88]R%IX5C$94>:TB*.<\`_'OQU\8?%>C^+=#U+X;>%O$>I?#'^UM1_MJ
> M"6]M'^RW]RC^3%!=)MA+D,TWVB5804`$V\.(CQ7-PI3::4TI>B]DZC?G9*S]
> M;J^SMY-!SG"+3<6UZVFH?+5W7I\SV,_`%1_!3&_9_4_P5YQJGK7QU\+K;Q/IMW::+J'C0ZO8:=I&B6_A^6TBTZ*\N)(X;AKV6DW&:=^9PMWDN71:VN^=-=U=Z)-K*.41<>?I92
> M^3Z_*VOFTE=M(ZNM#<SR><T@5H1*0&B5EJ.
> M>5I55!;/DU;M_$;2TWTMJG9]+-W2C^S*7+S7U]N:Y\._#OPOK4]CHVJ7^I6/B:_O=)L6(NIET@3Y2
> M!26OV=4BECD2?S(PQ?_587YLL/Q'4KS5.FI-OEZ/>7PJ^UWK\U
> M;>UYCED'3]ITU]=$F]-]+J_77LFUW=_\`Q#%D1UQ_B+X7-IP8A2,5N7'QGU[
> M6O'T_P`'/&-MX0UOQ7=WV+TV^F20V&I^&WM/,EO39R7$K(IEWV)#2R+YI5B"
> MK;!%\'KN6_\`@GID=S+/<OIDMWI4=Q/(TDMS%:W4MM'*2L_+_AKI^E[==5).UE?FQ>!IT>FWW_.SMHT^IYMJ.DM82D'C%,MI
> M=K5TGC:%%D8C&:Y2-_G(]Z^LHSYHW9X<XV=C5AD15M&W"M2"0
> M'(I:8IP:?2:&F2`Y%`.#3$;%/J`V9(#D44U#SBG4%+L/4Y%4M;XMS]*MJ<&J
> MNLH7MV^E)C.(N),7#>A-/*AP*K:CF&X.?6B.\!4#FO5H+W3R:\K2+B!11.BR
> M*1FJZW8'7^=+]K6M>5&',RG=:()FS47_``CD?I6C]K6C[6M3[*)HJK*"^'$/
> M:G?\(VA[5<^VIZTX7R^M+V,1JK(H-X?$?08J>VT50<GM5D7H-*MX`>M3["(_
> M;2+5B%L1U%6)/$"QKC</SK'NRH#=Z[
> M:LPW_O7/
> MK>XZGBI83!\BLG$T3`GG!_.F..*<6S36&14-%7,?QUKP\
> M-V7A.Z.1M\68/_A.^(#_`$J&S^."-C!8_C7&?MA^%;KQC\)/#=G:(?*&F_`#6%?!$X(Z@YXK\,X_Q-2EF4E&-]%^2/Z5\)
> M,NPN(RKFKU.5\SZ?\$^\H?C6A'\5;?P:TKQ;\;_!%KK6D>-?`%LMA,T/C6#6
> M+1]+E\`(J&8WD@:Z=;ZU:..;RY$:`.WEYV`7'V?X0M/@%J^S_EK^=>Y?!/XR
> M^(OV>_`&G^'/#?@'PZ;.]E9_&3ZI<_;Y?&D;1M$;9R85%O`JR2;$`D"G;G?F
> M;SODLFS&C*<_KJ26EKWO>_2RV0(OQK&G1W;1Z;J8TM]*.IVP5<3_`&62:5X@S[]H=]Q0(S+&
> MS%%FN?CBBCJP_&OD/Q9\$YM4\1ZA=:3I%QH.DW$YDM--;4&OS8H0/W8F9$9U
> M#;MI9=P7:"SD%CR^I?`35\_\MN?<UR5,QJ?6)1IQ3C?2STMY:'M8;(\&\!2E
> M6JM3<5=22YDZZ7_A#?AM_P!$G\`?^"M/\*^>OV!O`U]X#/CB&\21"VD>&4RPZ-]K\32;
> M?KLDC;'HZGN*^@MXK]ZX2HQK952E5CKK^9_)_'#]AGF(IT97BG^B%)P*\:_:
> M1_89\"_M1$2ZXFJ:9?Y&Z^TJX6">10"-K;T=&'N5SQUZUT_
> M_P"@%\,__!7J?_RQK[/#TJ\Y<]"#?*6NZ/DH8J5&+BI\O-TU_R9O+F7SKJ]8=#(^!G&3@``#/2O2OB)\,OA
> M_P#'G3'M]22V=AAF19D8*2!@D8)KX3_P#EC3U_X*`>/UZ:)\-/_!7J?_RQK/$Y3B:[;JTF[]W%_P#M
> MPH8V,7S*>OS_`,CB$JNU1M4D#`J63X>?#J1=%!\%>#V'AO3I=(T@'1&:_VE'3W]MM].O;N?6VG_LV
> M?!71O!-QX:M/A/\`#*U\.7=T;V?2H?#%BEE-<&)H3,T(BV&3RG>/<1G8S+G!
> M(JWXG^"GPG\9?#O2/"&L?#?X?ZMX3T!O,TO1+SP_9SZ=IK`,`8;=XS'&<,PR
> MJCACZFOCT_M_^/S_`,P3X:_^"S4__EC33^WUX^/71/AK_P""S4__`)8TO]7Z
> MK5G2=M.L>FWVNG0G^T5=/GV]>N_3J?9?A_X;_#;P=X\'BK2/`O@O2O$ZV2::
> M-8L]%MH+\6J(D:6_GH@D\I4CC4)NVA44`8`JG\,_AK\,_@+>:C<^!_`G@GP9
> M<:QM^WRZ%HMKISWNTL5\TPHI?!9B-V<;CZFOCYOV]?'K?\P3X;?^"S4__EC4
> M;_MU^.I!SH?PW_\`!;JG_P`L:M9#5OS>R=_6/7?*^79_VU?&EQ]4_^6-59?VO_%TWWM"^'?\`
> MX`:I_P#+&KCD,U=>R=F[D*68MJSFNW7:][;;7U2Z/7J?
> M4=WX*^&$GQ0E\</X$\#MXTG#++X@.B6IU20-%Y)#7.SS3F+]V<M]SY>G%8/C
> M?0;'Q=\0/`\\MUHUKX-^'\BZCI6@VVE^6\>H)#+;PR^<)=BP10S.%A6$$.%;
> MS,*$KYS?]J_Q5)UT+X>?^`.J?_+&H7_:A\32==!^'W_@%JO_`,L:VCDDE;]T
> M]+/>/35?:Z-W79ZK4S>/>MIK5-==GNMNJT?=:/0^O]=^(VB:KLI)XDD:SFV/'YL9()1]DDB:)3<0PR,CR1+)C<J.T4190<$QH2#M&/D=_VD_$3]=!^'_\`X!ZK_P#+&HW_
> M`&B-??KX?^'_`/X!ZK_\L:Z(92XNZIR_\E[6_F[:>AC+%R>G.OQ_R/:_'_PL
> M^'NL_#?XAZ-X:\/>$_!>J?$C2$MX;BY>=)`9IC&$:<AI&?#-R2>
> M0236MX:T#X;>#?!.K>'=-\&>#;'1/$`8ZQ86VCVT-KJG';2RJ$D=%C4!6=0`Q&"P`!S3K2_P#!&F^)I]:MO#7AJWUFXO?Y.[8[+G!(KYM/QTUD_P#,O>`?_`35?_EC0?CG
> MK)_YE[P#_P"`NJ__`"QK6.5Q3OOL;:?WO)?<C%UY_P`Z_'_(]MA^%WP;
> MMM-UFRC^&7PXCL_$;(^K0+X<LA%JC))YB&=?+Q*5D^<;\X;D<\UT^H:]X5U'
> MX:3^#CIFGP>%Y].;23IEM&L%M':F,Q^2B)@(@0OWV/<9/`_P`-M7UW1M<U_P`*^%_%?BW1(K>.#Q)K&C65QJY>#!CE,XB4
> MJX8;AL"A6.5`K1\::7\.?B1XRT>\0:/Y?V#4]1TBVNKRQ\MS(G
> ME32(73:Y+#:1ACD<U\^_\+RUG_H7O`/_`("ZK_\`+&D/QQUD_P#,O>`?_`75
> M?_EC3_LNG_SY>]_L;O=_%OYA]9J_SKMUV[;;>1[^'G@"\LM
> M!1(],MY]`M)(M.5&9D6%3&1&%+N0%`P68CJ:\,_X7AK'_0O>`?\`P%U7_P"6
> M-'_"\-8_Z%I_QL@^(GA:)?`7C!Q)%JFH>'=3Z%\/
> MV/PS>ZE::3;PW=Y*X8-))*J!W9@O4U1
> M\&^"_A3\.H;J/P]X`\":%'>W%O=W"Z=H5K:BXFMY/-@E<(@W/%)\Z,>4;D$'
> MFO"/^%X:Q_T+W@'_`,!=5_\`EC1_PO#6/^A>\`_^`NJ__+&JCEM.+4HTI)K_
> M``>7]1:.T^.VDT*R
> M#/)\IE,PEG,LFYG8",^5$!"-K%\Z+7-,\%^$-.T+2D,6GZ3:QVELC2-(PC10
> MHW,Q)9L#DDDDY)Y->5-\;M888/A6_\`]"S\/_\`P$U7_P"6
> M->M#$RBK*E+_`,E_^2//>#;=^=?C_D;-O+@BK\$G%<ROQ;U!>GAGX?\`_@)J
> MO_RQJ1?C-J:#CPU\/O\`P#U7_P"6-5]<G_SZE_Y+_P#)"^I?WU^/^1U%/4Y%
> M<P/C=JH_YEKX>_\`@'JO_P`L:!\;]6!_Y%KX>_\`@'JO_P`L:/KD_P#GU+_R
> M7_Y(/J7]]?C_`)'44]3D5RO_``O+5O\`H6OAY_X!ZK_\L:4?'/5Q_P`RU\//
> M_`/5?_EC2>+G_P`^I?\`DO\`\D/ZGI\:_'_(ZJG@Y%<E_P`+TU?_`*%KX>?^
> M`6J__+&E'QVU@?\`,M?#S_P"U7_Y8TOK4_\`GU+_`,E_^2#ZG_?7X_Y'6TDT
> M8GC(/I7*?\+WUC_H6OAY_P"`6J__`"QH'QYU@?\`,M?#S_P"U7_Y8T?6I_\`
> M/J7_`)+_`/)#^J?WU^/^18UOPP;AB5'6L=O"$H;.*T&^.^L-U\-?#S_P"U7_
> M`.6--_X7GJ__`$+7P\_\`M5_^6-5''5EHJ4O_)?_`)(AY?%N[DOQ_P`BD/!\
> MQ[4X>$)O2K?_``O/5O\`H6?AY_X!:K_\L:4?'75Q_P`RS\.__`+5?_EC3_M"
> MO_S\?_DB5EL/YE^/^13_X1"7TI'\)2JI.*N_\+VU?_H6?AW_X!:K_`/+&
> MAOCIJR_\E_\`D@_LZ'\Z_'_(Q)=#F20#!ZU<
> M@\*S2*#4LGQ@U.1\GPS\._\`P"U7_P"656(_CCJT0P/#/P35O_`(7MJ_\`T+/P-6_Z%GX=_P#@%JO_`,L:3_A>>K#_`)EGX>?^`6J_
> M_+&E]?K?\^I??'_Y(/*Y?_`(7GJ_\`
> MT+7P\_\``+5?_EC0?CIJY_YEKX>_^`>J_P#RQK.6)J/>E+5_^6-92E4?_`"ZE]\?_`)(T5%+:7IX;^'O_@%JO\`\L:E3]H;78^GASX><?\`3EJO
> M_P`L:PE"J]J4OOC_`/)&L8);S7X_Y'LNF:IR.:Z;1M5S@9KYYC_:3\01'CP[
> M\.__``!U3_Y8U;M_VKO%%L?D\/?#D8_Z<-4_^6-<\J%=_P#+I_?'_P"2-5R_
> MSK\?\CZ>LKS>HYJL`#X:_^"W5/_EC0N%**_P"81?\`DG^8WQ'C7OBI??(^
> MF_#>G:;X9TTV6D:=!I=G),;F6..6:>2YG("M---,/U84445[1QA1110`4444`%%%%`!1110`4444`%%%%`!1110`4
> M444`%%%%`!1110`4444`%%%%`!1110`4444`%%%%`!1110`4444`%%%%`!11
> M10`4444`%%%%`!1110`4444`%%%%`!1110`4444`%%%%`!1110`4444`%%%%
> M`!1110`4444`%%%%`!1110`4444`%%%%`!1110![K^PLVV'XD?[V@?\`N8KW
> M7[37A'M48^!FC?]CE9?^FS5J^;*]C)/X=3_%_[;$Y,9O'T_5A1
> M117M'&%%%%`!1110`4444`%%%%`!1110`4444`%%/MK:2\N(X88WEEE8(B(I
> M9G8G```ZDFOK?]F__@C3\4?C996VI>(/LO@'17CW+(.T5*7HE^K1[$.&\7+>R^?\`DF?BO17GG_HGW_E=U/_
> M`.2*/^'1?[//_1/O_*T?_DB_P#5C%?S1^]_Y'XF45^V
> M?_#HO]GG_HGW_E=U/_Y(H_X=%_L\_P#1/O\`RNZG_P#)%'_$0<N_DG]T?_D@
> M_P!6,5_-'_Y'XF45^V?_``Z+_9Y_Z)]_
> MY7=3_P#DBC_AT7^SS_T3T?_D@_U8Q7\T?O?^1^)E%?MG_PZ+_9Y_Z)]_Y7=3_^2*/^'1?[//\`T3[_
> M`,KNI_\`R11_Q$'+OY)_='_Y(/\`5C%?S1^]_P"1^)E%?MG_`,.B_P!GG_HG
> MW_E=U/\`^2*/^'1?[//_`$3[_P`KNI__`"11_P`1!R[^2?W1_P#D@_U8Q7\T
> M?O?^1^)E%?MG_P`.B_V>?^B??^5W4_\`Y(H_X=%_L\_]$^_\KNI__)%'_$0<
> MN_DG]T?_`)(/]6,5_-'$^_\KNI_P#R11_Q$'+OY)_='_Y(/]6,5_-'[W_D?B917[9_\.B_V>?^
> MB??^5W4__DBC_AT7^SS_`-$^_P#*[J?_`,D4?\1!R[^2?W1_^2#_`%8Q7\T?
> MO?\`D?B917_Y7=3_`/DBC_AT7^SS_P!$^_\`*T?\`Y(/]6,5_-'[W_D?B917GG_HGW_E=U/_`.2*
> M/^'1?[//_1/O_*[J?_R11_Q$'+OY)_='_P"2#_5C%?S1^]_Y'XF45^V?_#HO
> M]GG_`*)]_P"5W4__`)(H_P"'1?[//_1/O_*[J?\`\D4?\1!R_Y'XF45^V?_#HO]GG_HGW_E=U/_Y(H_X=%_L\_P#1/O\`RNZG_P#)
> M%'_$0<N_DG]T?_D@_P!6,5_-'_Y'XF45
> M^V?_``Z+_9Y_Z)]_Y7=3_P#DBC_AT7^SS_T3T?_D@_U8Q7\T?O?^1^)E%?MG_PZ+_9Y_Z)]_Y7=3_^
> M2*/^'1?[//\`T3[_`,KNI_\`R11_Q$'+OY)_='_Y(/\`5C%?S1^]_P"1^)E%
> M?MG_`,.B_P!GG_HGW_E=U/\`^2*/^'1?[//_`$3[_P`KNI__`"11_P`1!R[^
> M2?W1_P#D@_U8Q7\T?O?^1^)E%?MG_P`.B_V>?^B??^5W4_\`Y(H_X=%_L\_]
> M$^_\KNI__)%'_$0<N_DG]T?_`)(/]6,5_-'$^_\KNI_P#R11_Q$'+OY)_='_Y(/]6,5_-'[W_D
> M?B917[9_\.B_V>?^B??^5W4__DBC_AT7^SS_`-$^_P#*[J?_`,D4?\1!R[^2
> M?W1_^2#_`%8Q7\T?O?\`D?B917_Y7=3_`/DBC_AT7^SS
> M_P!$^_\`*T?\`Y(/]6,5_-'[W_D?B917
> MGG_HGW_E=U/_`.2*/^'1?[//_1/O_*[J?_R11_Q$'+OY)_='_P"2#_5C%?S1
> M^]_Y'XF45^V?_#HO]GG_`*)]_P"5W4__`)(H_P"'1?[//_1/O_*[J?\`\D4?
> M\1!R_Y'XF45^V?_#HO]GG_HGW_E=U/_Y(H_X=%_L\
> M_P#1/O\`RNZG_P#)%'_$0<N_DG]T?_D@_P!6,5_-'_Y'XF45^V?_``Z+_9Y_Z)]_Y7=3_P#DBC_AT7^SS_T3T?_D@_U8Q7\T?O?^1^7_KGN=
> M\[7/B*-GW3.[#*QH,`X^7IDG/&>7[BHHXV&+YL3332D[J^_3U,J^'E1:I3W2
> M/+_VVTV?`S1?^QRLO_39JU?--?2_GO2+N_O++3[2+QE9>9<74Z0
> M0QYTW5@,NY"C)(`R>20.M?)'_"V_!_\`T.7@W_P?6G_QROJN'<+7JT:DJ4')
> M<W1-_9B<>+HU).+C%O3MYLZ"BN?_`.%M^#_^AR\&_P#@^M/_`(Y1_P`+;\'_
> M`/0Y>#?_``?6G_QRO?\`S.@HKG_\`A;?@_P#Z
> M'+P;_P"#ZT_^.4?\+;\'_P#0Y>#?_!]:?_'*/S
> M.@HKG_\`A;?@_P#Z'+P;_P"#ZT_^.4?\+;\'_P#0Y>#?_!]:?_'*/S.@HKG_\`A;?@_P#Z'+P;_P"#ZT_^.4?\+;\'_P#0Y>#?
> M_!]:?_'*/S.@HKG_\`A;?@_P#Z'+P;_P"#ZT_^
> M.4?\+;\'_P#0Y>#?_!]:?_'*/S.@HKG_\`A;?@
> M_P#Z'+P;_P"#ZT_^.4?\+;\'_P#0Y>#?_!]:?_'*/S.@I54NP5022<`#J:Y[_A;?@__H<O!O\`X/K3_P".5NW
> MX;>'XO$'A76'EU)K[['#JMM</.+6&2Z(\M7)88A)(P>`<\9KFQE#$8;#U,14
> MIRY8)R>CV2N^AI2P=:<U#E:N[;,_2)_9N\'Z=XP\6Z?#>_$6_
> MB$X$P#IH2,.(HQT\['WWZ@DJIP"6^P***_FW,,PKXVN\17=V_P`/)>1^E8;#
> M4Z%-4Z:LD%%%%<1T!17G'GO]DCXH>/=&AL+C6/!/A/5->L8KY'>U
> MEGM;26>-951D8QED`8*RDC."#S7SM^S%_P`%-X+SP?XX\3_$/XB?"SQW\//"
> M]OH93QY\.](NETF/4=2G>V;1G@CO-1>2ZA<V;,\<N`M]'OCCQN<C[SDNUOQ;
> M2^^WWV6.6__I2VUM=[)M?:%%>46O8\901S:.=8\$ZWI=E>.]K)="V^UW-I';I=B&*5C:O(LZ^6ZM&&4@<W\(?\`
> M@IU\#_CE'<S>'_&KBQMO#LWBT:CJNB:CH^GW.DP;!<WD%U>0103QP-(BS&)W
> M,#MMD"-D4/2]^E_3OT/>ZH>*_$,7A+POJ6JSI)
> M)!IEK+=R*F-S+&A<@9XS@5\L^$/^"KW@+N=+O$5K=\"6VN8XYX7]4E16'<"JY':7:U^[T<5G>%?VH]-M_`MK=>*XI=/UY+V]TRIH^,_B=XJ@>8BT
> MFC2,$X&6=`N3S@9R<'`X.`+'=^`O%C>-O"\&H26<EA,TDT$UL_X*FM8VA>.2XGF$:,JLYB$L:DBN9N*W5OG?FM;_P%E)/E
> MY^G7RV6OJW9>?R/LNBOFWP9_P4Y\$:U\2/C;HFMZ?XF\-:?\%M5M]-GU6Z\/
> M:J;?6?.M*_P""A?PKUG5O!VF0
> MZIXG76O'=U=V6D:1-X-UJ#5/-M);>*Y%Q9O:">S$1NK=V:Y2)1%()L^4"X()
> MRY>77F2:\TU=!)6U?I]RO^6OIJ>UT5XWIG;PW>M
> M0>(_#&JZ#<Q032RPP2P0WMM%)=1RRPR11M;K())%V(68@'C9_P#@IMX7OOVD
> M?AK\/-.\+?$M?^%E:3JFH6^I:GX`\1:8=-DM)OFGRV];Z6WOIN$DXWYM+*[\EO?TMU/;J*^</
> M^"C'Q7^+_P`!?AU8>+?AOXC^&VG6"ZOHVAWFG^)?"%I+1OACX*\1P^/_%FF7WB/X=6MI+XJN=*\.7U
> MA;DW0)MWMK-GN9764Y1%BEG+2(Z`EU*"8^]!S[-K]8O\`PZ"^A:C#I_\`:ED9A<Z?]ND@6U%V
> MBP2R?9_-\UHE$JJT;*YWO@5^V)\/_P!I/7M0T
> M5MBYC%U87-S!'#J%MN`_?VCRQ8>,K/
> MSOIZZ&YJ7Q&U>7Q3JFGZ5HMA<0:1)'!-<WNI-;"25HDE*HJ0RD@)(F2<<MCM
> M2?\`":>*O^@'X9_\'MQ_\AUQ_P`3/$VJ>"O#?Q/UG1;:&\U+2;PWD-O*A=9_
> M+TVR=DP&4Y900.>I'7H:%S^T#I]GXCU6ZGNK6#PCHFC6E]<WIBDDEEN+MSY$
> M,:KDLWEJI\M49W:XB"\G!5U?^O.WWV=O,5GO_6Z7X71W_P#PFGBK_H!^&?\`
> MP>W'_P`AT?\`":>*O^@'X9_\'MQ_\AUQ%C\>M"\53Z,=+UE;/[7K)TB>SU'1
> MKN&\:?(P)+[^R
> M;P6ET3)Y2K;3&+RS_4+?U\VOS1V/_":>*O^@'X9
> M_P#!+N83'+;H9&BFMI##,A8+QNVG#JP#`C,>F?M/\`A:PU.ST+5]7)\1*]
> MG97YMM(O!9P7=S%&\2-+M>.$2^:OEB27YB2H9F5L-:NW73\=OZ]`>BOZ_A:_
> MYGH?_":>*O\`H!^&?_!KSP]XM
> M\(:EJ][9Z[I*6.MW&BPVG$DLC)$SO'&CM$`P?&TFN@T
> M[]HOPEK&NV>F6=IPU6.W@TB\EDCM\RC=(%B/E-NAD0I)M<.`A7>RJ
> M5?2_];7_`"U]!M--KM^CM^>AV'_":>*O^@'X9_\`!'O8=1^TNBND*V;Q"Y=V1U
> M=0L9)7+#(!(YG5_VMM+/B_Q#H<4&L:*ND>&D\0#5]2\.:D8+=6$U;[
> M_.MQ<-&(3*HC=M@?<5&X`J026W_`#7WDWTO_6NWY,[/_A-/%7_0#\,_
> M^#VX_P#D.C_A-/%7_0#\,_\`@]N/_D.IZP?'GQ-T7X96EO<:W=264%RYCCD%
> MM+*A8#.TE%8`D9(!QG!QG!P#L6]?^*?B'PMHMUJ5YX>T>:RL(S/<BSUF22=8
> MEY=E5>0>(?&VF_$'X(^)]2TF>2YLGTF^1)6@DA#E8'!V_:)_:A\(_LK>%8M<\
> M:-XEMM&82O-?:7X7U36K?3XXTWR373V5O,+6%5RQEG*1@`DMP<<GXA_X*,?!
> M[PO\9I/`-YXIO/\`A([;5K#0A>W\4$MC#<7T=NUI`;E;F$0F69
> M5E=BB%G1E51]Z7+'5Z$Y/9*_R6[]%W/;J*\6M_P#@H3\(L;X=>.-+\&WFCZ$WLBN27-R6U[=>WYIKY'IU%>'1?\%&OA
> M+)\.KWQ*^K^)K:&PUR/PU+I%SX-UJW\1-J4D"7$=HFCO:#49)&MW$P"6I!HOA/6-6U*633YC#?/]AM
> MK62Z6&WE`229HA$C/&"X\Q-S_K&GU$HMVLM]O/?_`"?W/L>P>/?%
> MC>"?"\^H1V<E_,LD,$-LCA#-++*D4:[CPH+NN3V&>#TK#_X33Q5WT/PT#Z?V
> M[/Q^5G3OB-K-IXC^'&EZCI]S!>V%_J>CW%M<0N'CGC>_MF1U8<%2I!!'4&O(
> MOB%\==0T+]I6U\&)XM\!^%K.73+*]ACUNU::\UB:>YGB:"W/VN$!L1)C"2'=
> M(.#P*JS4E!K5NW]?<0I)P=1/2R?WM+]3US_A-/%7_0#\,_\`@]N/_D.C_A-/
> M%7_0#\,_^#VX_P#D.N+T+]I7P9XE\;KX=L]5N)-3>]N=.7=IMU';-=6^_P`Z
> MW%PT8A,JB-VV!]Q4;@"I!/-^-/VP_#">!O$D_AK4/MVN:;H.HZSIT=UIMW%:
> MZ@EI'DRQR,B)-!O*#?$Y5LG:QP2(<E:_E?Y;EQ@W+DZWM\]CUC_A-/%7_0#\
> M,_\`@]N/_D.C_A-/%7_0#\,_^#VX_P#D.O/H/VAM'T+[=_:^J->7,=Y!9QV&
> ME:#>W-W!+)91W1BV1"5YSL8R;XT"JI"MRI)S-%_:KTBW^+7B7PUKEP+$V6K6
> M.G:8T>G71XNK2WDC%U(%9(&>:9T3S#'N*9/C/
> MQMIOP^T1M2U:>2VLD=4>58))@A;@;MBL0">,GC)`SDBD58N7'CCQ9#`ZZ?PIXAB\6^%]-U6!)(X-3M8KN-7QN59$#
> M@''&<&N(^''Q-T7XFA@MIECDD-M+$@8\[0750Q`P2!G&1G&1G?^"?
> M_)&?"/\`V!;/_P!$)0'4^-OV\X_,_:X\3<9QX0\+?^EOB:O'/LQKVO\`;BB\
> M[]KSQ0/3P?X6_P#2WQ-7D_V0^GZ5^D9'+_8XGQN:+_:)'RG_`,%RH/)_X)Y3
> M\=?&>D_^DVH5^<_CJMMJ5Q-\0/`DWAC3C:QHZPW+ZCI]T'EW.I6/9:2#*
> MAFW,ORX)(_O+Z.$,=4X%Q?\`9U24*GUO>*@W;DPZEI.,E;E;>U]-SSZJA.;7\#!U;]G3QF/AQ?^/]+\'>.KWX8VUX]M#XLG\/3P::X\WRD$DZ[X
> M(Y"Q53&)6P[;0S<$ZA_8G^,P\62:"?A'\3O8DT:>;^T%A^S000_8HXUA5XQ)\,E2HNFI
> MM^\_L_*ZUZ?R:[/WKN._Q+I?[)_Q3UQ_%BV7PU\?WC>`E9_$P@\/7<A\.A5=
> MV-[B,_9@%CD8^;MP$8]`:Z?]H3]AGQQ^R)XZ\$:5\4-+U3PI8^-=.L-6AOI=
> M+N46""XCADFCVSI"'N+83*LT0;"2#:7Y!KX-:67Q7?W4\X@6%5<E5>UMIK@%?,SF)/^6H8<C<?L5?&2U^)1\&2_"7XF
> MQ^,!9+J9T)_"]\-2%HTHA6X^SF+S/*,K+&'V[2Q^(7^+-G\!
> M;#Q+X/US5=+\,ZC:ZM\4+=Y47_A*KBW@L]/0VXMI*C3J8;GG-VE>.D+6AS)Q=G%RA*IRRM)QJPY6U&2
> MB*EAZCO?E7NOTYI:K7^6%K^:?0^:(_V./'WCCQ(=.\!?#_XL>+Y+71+'6;^,
> M>#+F.YM(UO6YM.T&>6T\*1V^I7EBOVFX3>BJXM'D#N(P,L,':6/TI\!?^"E/
> MP7\#_%+PCXOUSP]XFA\0>#-%\#Z=:ZE_PB&C^(9I$T:R$.H6D,=]<".R,\\<
> M#Q7\0:XC6+"K'N;.9H'_``4>^&ND^`/A=KVO\XV=^C35K232\#\<?L#>.8OB'
> MX>\,^`="\6?%#5=:\$Z-XUGMO#_AZXN6NM0>_N;"*PFO3+,\AF>WA9HH6?=N,<;,B$E5)`!KZGA+,
> M\\KU*E#-Z*@H1ARRM)2DW%.3=HJG;F;BHJ7,N6[
> MSO?7336VECGZ***^X.4*^XO^#;S_`)31?!G_`+C?_IBU"OAVON+_`(-O/^4T
> M7P9_YI_XE^9_5-1117^(1^E!111
> M0!PW[3OP8/[1W[-OQ`^'HU+^QCXZ\.:AX?\`[0^S_:?L/VJVD@\[RMR>9LW[
> MMN]<XQN&<U\^77_!,_Q-\0K/XUWGBCPM=MINOQZR+>.W7$SR,S/O;+(/^"4ME=?!/X;>!]1\;W<UCX"
> M^%^M_#2:YM=+6"?4%U**PC-ZFZ1UA:+XV^(_P`+O'/B
> MGQ;X;T3PVB:K\,)CH-DFF7UW=I<_8EU83-.S76Y7%TABFC61,`+&OLF@_"W4
> MO@G^Q/-X4UCQ/J?C/5="\+7-K=ZWJ$DTEQJ,H@<M(6GEFFQDX7S9I9`H4/+(
> MV7;UNJNNZ+;^)-$O-.O$,EI?P/;3H&*ED=2K#(Y'!/2KYW9KN<M-3>]D6:>62#
> M?#LE\U0RM&RA5+)M*D`>UVOPFN>II-C;:?;23/.T<*;5+N<D_R`'0``#```O\`_"K_Z''Q(/<6^G`_\`I+2"Y!X"M;Z]^&&L0Z9<VEEJ4VHZREI<75LU
> MS!!,;ZZ"/)$KQM(@;!*"1"P!`9<Y'S+\+/\`@DQJ'@?]G;Q/X&U/XD6>J77B
> M/X-6WP@&HVOAIK..VCMVU3R_DC6E
> M5G"W*[6L_FFI+XTT.3PM\49]#UI+&]\)
> M+?O8:QI4.G0PR3^9<F"\L)!IL/FV;P(SB24>>`1MWOV??^"<Y^"_C3P9K:WG
> MPO\`#;>$--\0Z:--^''P^'A#2<O_I.GDDDMD9P]U12^SMY:6_+\;O=L^#?@]_P1._X5IX3\70S
> M^./"R>(]>L-!6SUO0O`J:5/)JNC:A)J-IK.J;KR9]4O);EHVN7DDC\\(V/*+
> MY'N5Q^R]\2?$OQ<^%WC*U7^S_!-U::?K.FZC)9N\<$+Z
> MI+):W*?88@)GFG0:/NM'H#W<NK_RM^7W/7?4^
> M+O#/_!*;Q/\`#'X=:1X;\'_%FPTFVO\`X<Z=\,O&,]\1M+LO%)T^S\=^,?"WBJW
> M0Z:9CI<>B+HZK:Y,P,OFC21^\.W9Y_W7V?-],45:J24W5^TW=OO:7.K^DM4M
> MEJE9-HN4Y2ESO?\`X"7Y1BODCSG]JGX`?\-,_"-?"O\`:W]B;==T76OM7V7[
> M3_R#M4M-0\K9O3_6?9?+W;OEWWJ3)WA*F]GI^*?Z?J?#W[)'J3EZ7DY67DG)
> M^N[//]-C67Q7XR1@&5M80$$9!']G6->8:!^R-%X=^#VI>&8?$%Q)>W&K0:M9
> M:E+:JQLVM986L86CW?O(X4MX8R-REPK'*%LCV35/A6MWXDOM3LM<UO2)=3,;
> M745M]GDAE=$"!]LT4FUMBJIVXR%'%,_X5?>_]#AXC_\``;3O_D6BVMU_5FFO
> MN:T(OT_KM^NQY7!^S?>:IK>GZSKOB"VO]:CU]-;O9+733:VUPJ6,UE';Q1&9
> MVB4)+N+-)(Q;=T!4+F7WHMM,LD"
> M7>^=HKM`(XT=1%%O4-G!;(]G_P"%7WO_`$.'B/\`\!M._P#D6C_A5]S#^SMXC\#6DW@K0)O$
> M%O<6IN-"\+G3D%RQ:3;N^;S1SMR,+@P/^S#/>>'/$%I=>((GN?$
> M.K:/JTLT6GE$B:P6R!14,K'$AL\C+?)YF/FVY;UG_A5]I3R60JAR2.
> M=33_`-ER:QTG7(;?6-,T*?6?"\?AR,>'M'.F6VG,DUU*)X(A,Y3_`(^?N!LY
> M0D.-WR^N?\*OO?\`H</$?_@-IW_R+1_PJ^]_Z'#Q'_X#:=_\BU'*N7EZ?\#E
> M_+3\=R^9\W-U_P#MN;_TK7_@'A?@_P#8SG\"Z6\VDZSX;T?78-=BU[3VTSPR
> M+/2;.1;3[')&;-;C<Z21&3)\Y6WONW<8.WXW_9UUSQY>:Y<7?B?2HIO%/A)O
> M"^K>5HD@5F_TDQW$`-R3&`URQ:-S)N"@!UZUZS_PJ^]_Z'#Q'_X#:=_\BT?\
> M*OO?^AP\1_\`@-IW_P`BU4M=_P"M.7\O\]Q0?+;EZ6_!\R_'4\EO/V9;]]<U
> M*&W\2P0^%_$%[9:EJ^GOI9>T;N/2_\`A5][
> M_P!#AXC_`/`;3O\`Y%H_X5?>_P#0X>(__`;3O_D6G=WO_71_HB;+EY+:?\!K
> M\FQU4O$7AVQ\6Z)<Z;J5M'=V5VFR6)QPPZ_4$'!!'((!!!%6_P#A5][_`-#A
> MXC_\!M._^1:/^%7WO_0X>(__``&T[_Y%I#N<_P#$BSAT[X0>([>WBC@@@T.[
> MCCCC4*D:BV<!0!P`!P`*B_;-_9YU']J/X!7OA'2/$-EX6U9M5TG6++4IXB_X)T_V]X<^(NG_\)CY7_"?>,/"WBSS/[)W?8/D_?ROE_:/NOL^?Z9HJJ<W!WAIL_NDI+_P`F2?\`P`NKV^=K_`)(_/#3/
> MA3XOOOV[/A[X&\.ZIXQUWX>>!?B5KOCV\CU#X7:GH-OH"W-GJ8EB.NW92TU5
> M6O=3VVZ648<1,[2/*L6^NS\.?\$G/&>F>'-)T"X^-4%KH/@KP#K_`,/?!YT3
> MPI)INJ:3::E]C$5S<79OY//N8%LHUWQ);B3)(6-N:^W**B*2@H>5GYWCR_\`
> MI+:NVVKMWU+=67M?:Q=GT\K2E+\Y/:R\C\_)_P#@GZ?V$?A0WB31/$^@>&O$
> MEOX\MO%>EQ_#[X%ZCJ&@6,QTAM*FMFT#2KB:GX@\8:Z-)^*?PTA\2:;<V&NZL]ZC7.DM<V
> M\EG>A8***J[;<I:OIY*R5ON2VLM+L?L%BGEWMJF(+?>_D
> MQ#'R1.)_P#26G*3E+G>]FMK)?=
> MJOR1YC:?LV+;6^D1OK'F)I?BZ_\`%3#[)CSA="\!M_O_`"T;N/
> M'_"7P=USXG^(!X5&JZU-X7T#P5JOAFUU._\`!]UHIM1=^1#`A%RRF7?\*OO?\`H</$?_@-IW_R+1_PJ^]_Z'#Q'_X#:=_\BU$8I:=+
> M?^V\OX+;_A[Z<T::>?2FAL(K,/;20W<$D4_22<DD\DDDDDU>^"?_)&
> M?"/_`&!;/_T0E5+KX37=Y;20OXQ\3JDJE&,<5A&V",'#+;!@?<$&NHT+1;?P
> MWHEGIUFACM+"!+:!"Q8JB*%49/)X`ZT!U/BO]LZ+SOVP?%0QG_BCO"W_`*6^
> M)J\U^PG^Z/SKU3]KF'SOVQ/%H]/!OA;_`-+O$U<']@/H*_0,GE;"Q/D\QC>O
> M(Y/]H/\`94\+?MB0_#L2SN#;SGR-#UNYCVN`<?O(4SQ
> MR,CO3/\`B&`_98_Z!WCK_P`*!O\`XBO7;:T^S?'+X-G&,^-I?_4:U^L3]NOX
> M;Z#\/OC]'\;/&/A7P;\4_!WAVTTC3+JQU-D_M>_X*B^-]+_9I\`>
> M+(]-\%GQ#XG^"7BCXDW]F\%QY=OJ.EV]@\,2)Y^];<R7,RR*Q+G8H#J0<W'Q
> M9XT<.?\`MC%EC_`*!WCK_PH&_^(H_XA@/V6/\`H'>.O_"@;_XBO;_!'QR^,GQ`
> M^-FD?#V/7/A?HVKZ1X8T_P`8^(=0G\,7US%K%O?7ES&EEI]O_:,;1&WCMMLM
> MW)),&DFB(MXPVP8O[)GI/B#7/#`U-8;%9M/N-
> M-N)+=99+@:O)<RM,\+9MSI5OY8G0^=(J;Y=?^(I<;<_(\XQ7VO\`F(K?9?*_
> MM_S:+N_*S.;ZIAN3VGLXV]U;+/Y?>\EOK='E7_$,!^RQ_T#O'7_`(4#
> M?_$4?\0P'(U`>&M(:PAL;Q%^TH\EX\:+#&V)FF,91Q(5;TKQU^W7\5;7]J
> MWPUX$T&+PW-H&KWP\&ZOJ=WX:`AT#Q$VA3:EY8G.LQW%YL*P.T,6GI&8Y67[
> M8DB$#!^+7&JI\_\`:^+O:,K?6*VTHW6O/WM%]$Y0U]EC_`*!WCK_PH&_^
> M(KF?#7_X)?\`PCUVVUW1/B/\1KKP)<^--X#'A@?$'P=!
> MK&B:A!<W.LZJ=3T?0K-8K*E_;&*T
> MZ_6*V_,H_P`^W,VKJ_O1:\R)8"@MZ<=F]ETM=>3LXO7I)/O:+_B&`_98_P"@
> M=XZ_\*!O_B*/^(8#]EC_`*!WCK_PH&_^(KKH/^"@WQ=\5?M(>,/"_@OPSHGC
> M+P_?^'_$UUX$N)M+AT9M2U/1+)LRO^(8#]EC_H'>.O_"@;_P"(H_XA@/V6/^@=XZ_\
> M*!O_`(BOOSP3JFHZYX,TB]UC3#HFKWEE#/?:<9TG-A.R*TD/F(2CU?Y'YX?\0P'$=)1117YX=X4444`%%%%`!1110`444
> M4`%%%%`!1110`4444`%%%%`!1110`4444`%%%%`!1110`4444`%%%%`!1110
> M`4444`%%%%`!1110`4444`%%%%`!1110`4444`%%%%`!1110`4444`%%%%`!
> M1110`4444`%%%%`!1110!\<?M/VQN?VR_&``Z>#/"O\`Z7>)JY3^R/\`9KO?
> MCY;?:?VTO&@QG'@KPK_Z7>)JR_[)/M7VF6U>7#Q1\WC(7K-F=X_U6W\$_%'X
> M.ZC=17TD$/CB7<EG8S7LYSX;UY1MBA1Y&Y(SM4X&2<`$UW7C'3_@Q\0_BAHW
> MCCQ!\+WUWQKX=5%TKQ!J'PMOL(/
> MC-\$B._CF?\`]1G7ZU/'_P"TK\0E_:XN/A?X&\!>#=>M](\.:=XDU;5==\8W
> M.CO#%>7E[;".""'3;L3.@LG;YY(@=ZCCEJ\7&2YJT+;]/57>_31/4]7#1M1F
> MWLM_1M+;KJUH6M)7X/Z!\7]0^(5A\-;BR\?:M!]EOO$L'PPU"/6+V+"+Y<MV
> MMD)G3$<8VLQ&(U_NBL;1?AO^S]X;U;7K_3O@OIUA?>*HA<YNF?MJ>%-,\0?%P>,=1\/>!/
> M#7PGUNQT:XU_6=;AM;&Z^U:=97B2/)*$2'YKU8@I=MQ4$'+;1Q*UM-DON3MI
> M_P"3+3SV.NTN;SO\)HLF4.^V:6R8PMF*,YCVG]VG]T8CM-(^"MA\:)OB1!\+##\1+A"DOBF/X6
> M7ZZU*IC$1#7@L?.(\L!,%_N@#IQ4'PE_X*(?#CQKX+AUGQ-XJ\$^!4U?Q=K'
> MA/P^FJ>)K6,>(WL-0ELEDM6D,?G--L1Q'&'*^:HRW#'WFJ2:]Y?U=)OYM-7Z
> M]S-I)N#Z:?\`@+:^Y-.W2^QX/<^&?@=>?&I/B3-\)HI?B+&05\4O\*;YM:4B
> M+R01>&Q\X8B_=CY_N?+TXJU-9_!NX^+A^($GPQED\>%44^)&^%VH'5R$0H@^
> MU?8O.PJ$J/FX!P.*]NHI)6M;IMY>@VQJMK:R_!ZZ>&VO+@*)[E$-AA9I0J[Y``S[1DG`K6N?#?P/O/BA9>.)OA
> M-'+XTTV036FOO\*;YM4M7$*0!H[DV/FHWDQQQY#`[]?U=W]3Y^E^'_P"GUKQ+J3_!NQ?4?&D<\/B"Z;X27AFUU)\><M
> MV_V'=.LF!O$A8-@9S4.K_"_]GKQ!\)M+\`W_`,%-+OO`NB7+7FG>'+CX0W<N
> MDV$"^-?A+POHEGIFF:'XOT`_Z!_CK_PBM9_^1:`_QU_X16L__`"+6
> MU\._C+I'BOQC9Z?:V?BN*>XW!-1._*QK<Z2BBBN(W"BBB@`HHHH`\]_:7^*<WPG^'7VNVG^QW%[
> M+)"MUY(F-I'';374TH0\,XAMY=H/!?;D$9!_/?X'_P#!4/Q#XP^/'P^TN(K#
> M;?%2%I="NH/%-UK#6,QB:>"VU*VE`MP9HT8,;7;Y3'H^PV<Z"&S>12R[@TFP,<#'!VSV?GY'FXZGC95:3PLXJ*?OIJ:VYK'B'PEI^EZEI>K:=?:`ULMY
> MI\^FW4-U:E/M4$\)"R01Y5XF!`(X<_:O\.:18?%;XG_%CX@R
> M>';.]CT:7@%AI]O&NH6HCVV\Q0B-9)?E8NQ/GT](R4MW
> M)_\`@/+'1>?,I6VU>K:;2]25G*/:R^_FEJ]M+.-]]+V2=F<Y\5/^"P_A']F^
> M7XD7?CFRUSR/"?C+2/!]MIL=AIVDR6=U?:3!J`CN-0N]4%@557<M/-):1J1Y
> M:B4A9)+GBC_@J)K<WQ=_9YT30?@_X]AT;XUV^JWMH4=E;NS(UN]
> MXA9D;9,\B&2.2#!@,J-
> MK>Z<3J$EMID6F/!/:26;V-U:W%O%F:VNK::)G=BJ)A`E3X;_`/!([X??!,\*^(_&V@+\&;W5FTOBTMV^!)^=E.8M>=^^K)*W+NV]CS+PW_P`%V?"&
> MD?!K2M<U3P9\2O&$]O\`#BQ^)OB'4M`T'3M.M--TBXGG@-RUM<:K(Z&-X&+0
> M12W$FU@4,F'V^A?%G_@L-X!^%?BK7+9/!?Q-\2^'/#7B72/!VJ>*-(L+$Z39
> M:QJ36OD6;">V,$GRO\`:3_X)(?$'XK_
> M`!UO[/PEJ-AX2^%'B'QGX=\8:ZC^-FN3J5WI;V3/>?V4=$#I<R1V20;5U9;?
> MY4F,1D&VNF+BZT8O9R_!U>O9*EKIKSM;QNE-6ZIRE#=1_%4U:WFZMT[Z<BZ/
> M5_3WQM_:=\1?!7]MWX1>#;ZWT%?AQ\4=.UBQ_M"6.5+ZSURTBCNM[]BGPU^WA\'K?P
> M?XDUCQ1X;_L_5(-8T<&?2V/GV<LR&-B
> M0R12I&XP60L`U98?24?:;*27K!OFDW_>3]V-NFY5>+DU,:U:Z;-:1
> M6RZM!=N7%R)%GV"-$.Y@\B&W;GOVA_\`@MYX6\#WGQN\$^&-!U>Q^*'PO\$:
> M_P"+-.A\1+9?8M0.F(N1+:07IU"W21I(Y(Q=06QGAS)$S(58^Q:I_P`$T?`F
> MK_!+Q5X"DU;Q:NC^+OB$?B5>3+=6XN8M1.JQ:IY4;>1M%OY\*KM96?RR1OW8
> M8>4Q?\$'?A<AUJ%_''Q6FTK5-&\5:!:Z=)?::8-'L_$4QGU!('^P^<KEE?_$Z<;?=4YO+EWUU?1&5-5N9_#SK_`,`4W>_F
> MX6\^9]$C.^*?_!8B_P!!^#DOV'P/K'A'XF6+^#[]]*\76,7V75='UO6(-/.H
> M6GV2\D(3YIPL<0NY=:O=<O?#5
> MAJ/]HZ3+;W^HV:.T\(M(3A3,,RK/<6<4$C1?)*P>(O:'_``1Q\!ZMIFHQ
> M^(O'/Q3\7ZE>0^'1L6O=+TW1-074+'3X3%:1HT/GKF229)+B4,=TQ
> M.&'<_!#_`()Z:%^SY\6)]=\->._B;:>%CK&H^(+7P(NJP0^&K&_ORS74P2*!
> M+J9&D>:18+FYF@CDF9TB5EC*=K<'5;?PWF_E>'(O)\JE?=<J_;9\<#KCP1X5/_D_XEJ3^R?8?E5KQ]!Y_P"W!X[!
> M[>!O"G_I?XEK5_LX>E?286I:DEZ?DCQJ\+S;/E7X`_M9:I^T9^T)\*[/4-.L
> M[)-,\9/,A@+$L6\-^(!@Y^E>\>,OV"O"WQ;_`&ZK(T
> MCP__`&SI,.H7^C7]I?ZA<RW$/G1,(01<V^UXWWEHCD#:I/PW^PEIEQX@_:#\
> M#6MKJE_HT\OBQ=EY9I"\\./#_B`G:)HY(^0"#N0\$XP<$?I?_P`*EU__`**A
> MXZ_\!-&_^0*$C^(>O\`@F*ZT_7]5%]$XU+2XFN!
> M-$L,226@3X@>`O$TGBOPKIWPZN=1T?QOH_BK1/#.K:[
> M?/IYM[;PK#H,MM)J!M))DFB82R0W'V>4N(TWJC2-Y?TW_P`*EU__`**AXZ_\
> M!-&_^0*/^%2Z_P#]%0\=?^`FC?\`R!7S=->SCRPTM9?<U)>NJOK?=I66A
> M%0\=?^`FC?\`R!1_PJ77_P#HJ'CK_P`!-&_^0*J+M!02T6WDNWIU\VVW=MLS
> ME%0\=?\`@)HW_P`@4?\`"I=?_P"BH>.O
> M_`31O_D"BX'<T5PW_"I=?_Z*AXZ_\!-&_P#D"C_A4NO_`/14/'7_`(":-_\`
> M(%%P.YHKAO\`A4NO_P#14/'7_@)HW_R!1_PJ77_^BH>.O_`31O\`Y`HN!W-7
> M-`_Y"T7X_P#H)KSK_A4NO_\`14/'7_@)HW_R!6U\._AWJ^A>,;.ZNO'GBO6H
> M(M^ZSO+?3$@FRC`;C#:1R<$AAM<<@9R,@S-^ZQK<]/HHHKB-PHHHH`****`"
> MBN1^*=J=4U3PE8-<W]O;7^L/%<?9+R6T>5%L;N0*7B96QO1#C/.T5+_PI_2?
> M^?OQ3_X4VI?_`!^F!U-%<M_PI_2?^?OQ3_X4VI?_`!^C_A3^D_\`/WXI_P#"
> MFU+_`./T:`=317+?\*?TG_G^*?\`PIM2_P#C
> M]&@'4T5RW_"G])_Y^_%/_A3:E_\`'Z/^%/Z3_P`_?BG_`,*;4O\`X_1H!U-%
> M<M_PI_2?^?OQ3_X4VI?_`!^C_A3^D_\`/WXI_P#"FU+_`./T:`=317+?\*?T
> MG_G^*?\`PIM2_P#C]&@'4T5RW_"G])_Y^_%/
> M_A3:E_\`'ZC@^$FE2RS*;OQ1B-]H_P"*FU+^Z#_SW]Z-`.MHKEO^%/Z3_P`_
> M?BG_`,*;4O\`X_1_PI_2?^?OQ3_X4VI?_'Z-`.IHKEO^%/Z3_P`_?BG_`,*;
> M4O\`X_1_PI_2?^?OQ3_X4VI?_'Z-`.IHKEO^%/Z3_P`_?BG_`,*;4O\`X_1_
> MPI_2?^?OQ3_X4VI?_'Z-`.IHKEO^%/Z3_P`_?BG_`,*;4O\`X_1_PI_2?^?O
> MQ3_X4VI?_'Z-`.IHKEO^%/Z3_P`_?BG_`,*;4O\`X_1_PI_2?^?OQ3_X4VI?
> M_'Z-`.IHKEO^%/Z3_P`_?BG_`,*;4O\`X_5?5OA5I=AI\DJW?B<LF,9\3:EC
> MJ!_SWHT`^*?\`PIM2_P#C]'_"G])_Y^_%/_A3:E_\?HT`
> MZFBN6_X4_I/_`#]^*?\`PIM2_P#C]'_"G])_Y^_%/_A3:E_\?HT`ZFBN6_X4
> M_I/_`#]^*?\`PIM2_P#C]'_"G])_Y^_%/_A3:E_\?HT`ZFBN6_X4_I/_`#]^
> M*?\`PIM2_P#C]'_"G])_Y^_%/_A3:E_\?HT`ZFBN6_X4_I/_`#]^*?\`PIM2
> M_P#C]'_"G])_Y^_%/_A3:E_\?HT`ZFBN6_X4_I/_`#]^*?\`PIM2_P#C]'_"
> MG])_Y^_%/_A3:E_\?HT`ZFBN6_X4_I/_`#]^*?\`PIM2_P#C]'_"G])_Y^_%
> M/_A3:E_\?HT`ZFBN6_X4_I/_`#]^*?\`PIM2_P#C]'_"G])_Y^_%/_A3:E_\
> M?HT`ZFBN6_X4_I/_`#]^*?\`PIM2_P#C]'_"G])_Y^_%/_A3:E_\?HT`ZFBN
> M6_X4_I/_`#]^*?\`PIM2_P#C]'_"G])_Y^_%/_A3:E_\?HT`ZFBN6_X4_I/_
> M`#]^*?\`PIM2_P#C]'_"G])_Y^_%/_A3:E_\?HT`ZFBN6_X4_I/_`#]^*?\`
> MPIM2_P#C]'_"G])_Y^_%/_A3:E_\?HT`ZFBN6_X4_I/_`#]^*?\`PIM2_P#C
> M]'_"G])_Y^_%/_A3:E_\?HT`ZFBN6_X4_I/_`#]^*?\`PIM2_P#C]'_"G])_
> MY^_%/_A3:E_\?HT`ZFBN,\$Z2OAKXHZ_IT%UJLUFFE:?<I'>:C<7GER/->J[
> M*9G<KD1H"`0/E%=G0T!\,?MP?'Z_^`'\3-
> MD8KRG_AY'XA_Z`>E?]]O_C6K_P`%9'V?M0ZQ_P!BMX7_`/2OQ-7RGYGN:_7.
> M&<IPE?+X5:L$VSX#.<?7I8N4*<K(]%_X)R-N_:>\`?\`8U_^ZN5_AK]ZTW3ZIII'M<.:Y<X][K\;
> MKEX?^!O@2-\)KV34H3XS>/_VB/V&OVH/$5QJ/@O2_`>B>&_&OAB'PZFC7,FO)<6$-U:FY
> MN+XW@AC$K1-*MN+,E8YHOWS9)/J?['7QK^(=9W-LMK;WLE[;M93F>:39N/A3?2ZAJMF\2Q/;7$[6)DEA:-50QNQ4JH4C``KJ%\/\`54N9+6%G>*`R"TW&)&EE94SM4R.0
> M!N.71:BO>UNHI^J4KOYMI^2O%:;E9J4>6*V<FO)2=/3SM&,H^;:D]=O"_P!F
> M7X0_#+]H/7/'OCCXH:1X9\4?%7P7XZU:RN=0UV.*;4/`\-O?2?V9%9NISXD?$W6O#=]J-C\(Y/C\
> MGP1K$7]GZK/KMKL^'&IK]FU"?S?.O$Q9_+<2>?/OE&';SI,D[VSGR7I*G>VB
> M6FUY>;2?FK_$WJ.4D
> M;]F;POX?@T0U^Q^TW+-='EU2]CO]
> M2E\/SR327(NOLY>T>_G\IHXCF1()`P$1$WK^M?";]G?Q)X`/A34?@AI%_P"%
> MCJDFMG1KGX07<NGF_<%7N_(:P,?GL"09=N\@G)YKI;.^^$^GZ)<:9;_#R^@T
> MVO)
> MV6VT?=UO=VG+GDGTB]M;.XC1CJES-=(DTLT;226-BNZ)6C\U'!KZXKQ'PE9
> M_!OP!\1=4\8:#\,9=$\6ZY))+J6MV'PNU"VU'4'D(,C37"60DD+$`DLQS@9Z
> M5VO_``T/H'_0/\=?^$5K/_R+6<&E3A!;$2UG*2V;T]#N:*X;_
> M`(:'T#_H'^.O_"*UG_Y%H_X:'T#_`*!_CK_PBM9_^1:=T*QW-7-`_P"0M%^/
> M_H)KSK_AH?0/^@?XZ_\`"*UG_P"1:VOAW\9=(\5^,;/3/HHHKB-PHHHH`****`.5^(;;/%
> M7@<^FMRG_P`IM]7GW[;'QB\1?!KX*1>,?#TS6\/A;6],U#7HPL3"YT87<2:B
> MI,B-MV6KRRAE*L#"/F`)!V:&5"CJ?8JQ'XT.Z2E%7:::71M.]GY.UGW5T"LWRRT3T?>S5
> MFUYKIV>QX7XJ_P""@C?!GPY\7?B9XFBEU+X>>&O%,'A31;2+5M$T=8OL\:17
> M=V]UJEU9P9>_EF@V/<9(M8S&F7;.5XQ_X*T^#?&'PPOI4]O?/%)MO9C&]V'LG18O)G0N\9.Z(2.FO!_P3P\,Z'\"OAE
> MX)T#QEX_\.S_``HOGU/1O$EM=V=WK,]S+!<P7,URUW:S0323I>7!D<PAMTA9
> M"AYJ+1/^";/@/0?AEX@\*1:QXPDT_P`2?#6W^%EU+->P27"Z9#]MVS*YA_X^
> MC]OFRKV@TWY<T^5VZ:K:S*HRCS)U--O.UZBNM=^6
> MG>SM9NUUT-S7?^"G/@GP7^U3X,^#.IV6JQ>)?'-C'<:1>R:MHLGVDM:37(,E
> ME'>'48U*V\JF8V2V_F#:).1GY]^'/_!6#Q9XF_X)FS:OJFD^.-#^)UU\&]5\
> M7Z)XRU/1E^U,3:JJF,W'E!E#*B
> MFN8\%?\`!)YI)JUXI-I/0>#J1A.#JZI<E^N
> MS]QXTOCI^GWMR-5TB!+74+
> MNU2XA@^QR7::A-O62+]Y:V<L"&8!I%V2^7F_&_\`;/\`&_P2_P""C%U:75ZM
> MQ\%M"\%:)=>(M/%E$TFCS:CJ.J6PUCS@OF^5$UI;1S(6,:0RR387RF)2_9V\,ZY\8?%'C+48Y]3N/&/A>U\(:GIMUY<NG3V,$
> MUY*`8RFXLYOIE?<Q4J%`48):YN/-&:6J<FULGCMX5CO;NS-TZVT`581NG6>7SVO8(<0PN
> MT4C9F$4;)(_!6?\`P1R\!:!\+-/\):)X_P#BSHEE:67B+2KF\AU6RNK_`%/3
> M]<NDNKZSFGN;25@OF1Q%\96$NI^)5A\<>(]!
> M\3WY2Y@#17.CKIRVR19AP(V&F6_F!@S'?)M9,KM5.,-%)NRY?7>*EW^RG*^_
> M,VG=)-
> MG/\`:8\/_M1?!'PYX^\+EI=#\2VOVBWW7$$S1D,R21F2!Y(7*2(Z%X9)(V*Y
> M1W4ACY#\2OV!?#'Q"\4>(/$5MXG\:^%_%>L^++/QI9ZYI%U:B*!
> MMDGMY86BDLT>.2.YCF5O/D.`=FSV#X>:'?>"O!=AI>I>)=9\7WUFA276-6CM
> M(KV^)8G=(MI!!`"`0OL]
> MQ^=1QW>+BZY_Y:K_`.B8J5D*[/F?XRVOQ*M/^"AGP]\,Z9\>OB?H_A+QMH^O
> M^(+K1+;2_#$D%HVGS:4L-K!+-I#W`@=;R8/YDKRGY=LB8.>U\7?\%./!G@L]]H\6@B5=1%PIG$89)XUMU".X:6:/G86=>
> MS\2_!K2?%'QU\*?$*XN=176O!VE:GI%E!'(@M98K]XN_9%\1_$GX1?M7>*;?P;JOA_QA\9?#6I:%X<\,:CJEG)/;YTUH"Y
> M>&>2U@>]NL2,%F*W?F?+ZZ.-];JVB>K7314)U8<
> MMSX/\`
> M_"9^$%9;&*_GTRY@;4]/U$VMQ$063Q<VDN4>-P89Y``X!(<,J^.Z1_P3
> M;T'Q'\-];L_&7C3XB>)O$?B+3M)LXM<O;VRBU+PLNF7'VRPCL'M;:*(&WNR9
> MA),DSRLJB9YE`6O<OA!X*U;X:>$CINM>.O%/Q"O#.\W]J^((--@NPI`Q%MT^
> MTM8-BX)!\K=\QRQXQU.$%*:>N]O2^GJN#_GG_`./?_6K%^V>X_.CL]Q^="2"8_P"Q
> M7\+_`/I7XFKY.\WV%?5__!6\X_:?U?\`J_<N#U_PET_F
> M?E_$3_VZ?R/3_P#@F\<_M/>`/^QK_P#==\0U^L=?DY_P3=X_:=\`?]C7_P"Z
> M8Z^(XT_Y&DO2/Y'U/#7^XQ]7^84445\F>^%%%%`!1110`4444`%%%%`
> M!1110`5<T#_D+1?C_P"@FJ=7-`_Y"T7X_P#H)J9_"QK<Z2BBBN$W"BBB@`HH
> MHH`XOXP7$=I?^$Y90[11:I<.X1RC$#2[\G!'(/N*KGP.[')NEB/]SSKI]OMG
> MSQG\A2_'3_5^'/\`K_NO_35?TZYU\+<R#)X8C]:8AG_"#/\`\_R_]]W7_P`D
> M4?\`"#/_`,_R_P#?=U_\D4?\)`/4U#J6NRRZ=<+;2".X:-A$QZ*^#@G\<5$Y
> MN,7)*]AQ5VD<<_Q@^'47QI7X;-\3O`R_$5XO.7PL=?QK31^7YN\6?VSSMOE@
> MOG9C:,].:[?_`(09_P#G^7_ONZ_^2*^/O^"?G9T&Q^
> M,FCQ[O$_@^\9#XGNM?0&:^OFLR!<3F6;S+D780I(CK*K>&ZTC7M2\+KJOB/KVUM
> M<_3_`,4VNF>!M)_M#6_$6F:/8&>&U^TWUY/;P^;-*D,,>][D#?)+(B*N<LSJ
> MHR2!63\7?&G@[]G_`,'MXA\>>//"W@G0$F2W;4]?U=]-LUD?.Q#+-=JFYL'`
> MSDXXK\]/VW_C_JTGB_6_A_XG^-M^-6\*^.?`>G:1X)O=+TQ+KQ=IW]I:-/)K
> MLQCMHYWD:Z:X0RVIALXS;&(PP_RK"K-QPSQ$=;-_<HQE
> M\F^:WEU5TT-*TN5_U_7W/HVM3C?@G\7?AW^TKI=]??#GXF^!_']EIDJP7EQX
> M;U_^U8K21AN5)&@O'",1R`2"17;?\(,__/\`+_WW=?\`R17PK^SE^T7J?FCX@O=WK^!/#_AJQMO&&GVUHD\DMI<67EP7,?RF3?%=_9@0KJICGF+!
> MBJ8X/]H#]M+XI?!WQCJ>@^+_`(^CX>>(K+X6V'B_2M'&A:1)/X@\27-L4%L+:'%U,(8W25'\YI.BO%0JRIK7E;7S2;T2U=TG9)-I;^"]=\3VFF7GBBSNK"&2XGM+.72
> MIKF_E%U+<Q1O;:G!&KVBH\)*N9OOW_A(!ZFEROD4^_\`P/\`,Q4O>Y?)/.S#_A!G_P"?Y?\`ONZ_^2*/^$&?)/VU<L<GYKKG@#_GX]`!^`H_X2`>IH_X
> M2`>IJ"C,,>DKXR7PX?$FE#Q"UD=2&E_;9_MAM0XC,_D_:M_E!R%WXV]W7_`,D5^;FJ?M)ZVO"T9AHFC6']O^7';>;9N6G;[);YEG\T?N(_DYE\UT?WBC;K;\7!*ZW5N=
> M7\U*VUBIP<5.72/Z1G)Z[/\`AR?HX]]W7_P`D5^<>A?MR_%SXQ_MA?$#PG\/?B)#-;_V1XD.D^'M3OM*O=3T3
> M5-)O;2*"*ZM(-)BDT^"Z/VA5%S=WDLMO.LJB!UX^J_V1_P!I#5_VJ/#OBGX@
> MV%L+>+9<W,AV^87>\::(JS,H6T0JH+/NCF?LE5B
> MK^[S6ZVNTOFVMD)JT^26FKC\U:_R\^O2YV^E?&?X;:#)=>%X/$/F:S;*$5RSV@O#,H",K9*#A@>A%;7ACQ!X8\;^+_$'A_1?&?AW5
> M]?\`"<D4.N:;9:G)<7FC/*F^);F)+HO"SI\RAP"PY&17P+X&^*O@?4?V,OA/
> M\&M%N;#_`(:$\/\`BG0KO5?#4)67Q%HVMP:I#-J^L7D*;98H)%^VS/>2!8KB
> M*Z7:SBYC63V?_@EEX7N/!?P&^*46L>+?$WBN"_\`B5XP64W]O9121[-9O8Y9
> M$^Q6T#%YL&1L;Z2:Y-4^B]Y].B=]6E4HV2?>2C;J
> MKJ;U7?W/+5M=+OZ`^&/Q4\`?&WQ!X@TGP9\2?!7BQHTQ
> M9T$=S'%=LT+9ZG_PCCW=[)-':W7_R11_P@S_\`/\O_`'W=?_)%?"7PW_:=^+D/Q6\)
> M^)=1^(VH:]H7B?XR>*_AX?"3Z-IMO80Z?:?VT]G(LZ0"Z-U&UA"A<S>6T9PT
> M6_=*U#]A?]NGQ3\7_P!IGX9:/=?&H>/6\6^#M=UKQIX671M/ME\%:S;S:8JZ
> M:##"EQ;_`&<W%Q']GNI)+CY=TCN"F,Z2=1I+JK^GNN=ON72Z3:3>H58.G.4)
> M=&UZVE*%_OB^?\(,__/\`+_WW=?\`R139?`)GB:-32)%;P1(S$F^!)Y)+W7/_DQ2?\`"#/_`,_R_P#?
> M=U_\D4?\)`/4T?\`"0#U-`!_P@S_`//\O_?=U_\`)%'_``@S_P#/\O\`WW=?
> M_)%'_"0#U-'_``D`]30`?\(,_P#S_+_WW=?_`"11_P`(,_\`S_+_`-]W7_R1
> M1_PD`]31_P`)`/4T`'_"#/\`\_R_]]W7_P`D4?\`"#/_`,_R_P#?=U_\D4?\
> M)`/4T?\`"0#U-`!_P@S_`//\O_?=U_\`)%'_``@S_P#/\O\`WW=?_)%'_"0#
> MU-'_``D`]30`?\(,_P#S_+_WW=?_`"11_P`(,_\`S_+_`-]W7_R11_PD`]31
> M_P`)`/4T`'_"#/\`\_R_]]W7_P`D4?\`"#/_`,_R_P#?=U_\D4?\)`/4T?\`
> M"0#U-`!_P@S_`//\O_?=U_\`)%'_``@S_P#/\O\`WW=?_)%'_"0#U-'_``D`
> M]30`?\(,_P#S_+_WW=?_`"11_P`(,_\`S_+_`-]W7_R11_PD`]31_P`)`/4T
> M`'_"#/\`\_R_]]W7_P`D4?\`"#/_`,_R_P#?=U_\D4?\)`/4T?\`"0#U-`!_
> MP@S_`//\O_?=U_\`)%'_``@S_P#/\O\`WW=?_)%'_"0#U-'_``D`]30`?\(,
> M_P#S_+_WW=?_`"11_P`(,_\`S_+_`-]W7_R11_PD`]31_P`)`/4T`'_"#/\`
> M\_R_]]W7_P`D4?\`"#/_`,_R_P#?=U_\D4?\)`/4T?\`"0#U-`!_P@S_`//\
> MO_?=U_\`)%'_``@4^V^Z&?_`"8H_P"$@'J:/^$@'J:`#X<E!\3-;6-'
> M01:/81D-*TIW+=ZDK?,W)&0<92>7^T[JO;/ACPQ_Z5^)J^1_-
> M^E?N?!W_`"*Z?S/R_B+_`'Z9ZS_P3@'_`!D[X`_UWQ#7ZQ5^4'_!.1
> M-GVS_\``Q__`(U7?4RZ)6VD()!"G!_"LJU14X2F^B;^
> MXI*[L<)_PK34OVS_\``Q__`(U7Y>?LZ?%'QS=_
> ML#>(O''@>^)O^"DFN^"_VB?"GPLT7P=I/B]M=M(M,36TU?5T33M9;1YM
> M0BM=1F72)+"VWB)-RB^ENQ'<Q2BT=6YVKQ]DG?5KI\YKKVY5!N_\`X'KVLSZ&/PSU(@C;9\_]/K__`!JO./A+^P=I?P5\57&LZ/J7
> MCN\N>^)WB'7_/-"CY48=4#`%@"`Q!^3OV;OVC?C]^TGX
> MR_8WN?B#'HL.A>(?!>J>-]:N-"^(.H:;-KDMH-,"7=U;6FFVZ2;%NR?[/,C6
> MLIG?>?W$>_V.S_X*N>)M.^"4OQ%U_P"$UCIWA3Q'\/=8^(O@AK3Q=]KO-6M+
> M"U2[%MJ,1LXUL)YH)8F7R7O$4^8K/E5\QU(^RYI-[<R;\DY+7U<9676UE[UX
> MIJE.<E3BKW:MYMNR^'J%YHUI
> M>PBSUYXG26!+HO:--Y<<L:2!89(@Y&V3S$)0S:=^R4NE_'K6/B)'-(=;UK0;
> M+P]/`VH?Z*EO:7%W/&RK]GW"0O>2AB6((5,*""3X[\4_^"G/Q)^%0\0BY^"&
> MB7K>"/A[;_$[Q*;?Q^(+$2K$1'`SM+&;E!'')/ZY^S
> M1^UCXE^+GQH\5>!O&7@;3?!FKZ-H6E^*M,?3_$)UF+4=,U"6\BA,I-M;^1=(
> M]G()(E$L8W+LFD&2!4Y1;2W3?WZQ?_I+^2;6B,92]RUXR7XR@_G&^Z.
> MV_X5IJ7]VS_\#'_^-4?\*TU+^[9_^!C_`/QJN^HJ!G`_\*TU+^VS_P#`Q_\`XU7?44`<#_PK34OK9(E^)58_:-_:4^/7A?X>:%X@T
> M_P`+66F^)/C_`*YX0OVS_\#'_^-5\S
> M_#?_`(*=?%/XN^$OA'/H'P-\-2ZY\:/#>J>*M$LKGXAM#;6%C9)IK;KV<::S
> M(\K7TBJL,4V"D!;:)93;]C^R7_P43US]I#Q]\/
> M^OB,:A?RPVKV*SP7]JMND=K+_IT3(8I[A656W&-ODK54I.7);77\.:__`*1+
> M[FMQ3BXJ;=/7M/PU_/4X'_A6FI?W;/\`\#'_`/C5'_"M-2_NV?\`X&/_
> M`/&JVS_P#`Q_\`XU1_
> MPK34OVS_P#`Q_\`XU1_
> MPK34O0KJ:;`_,+_@L9/Y'SX._Y%=/YGY?Q%
> M_OTSZ)_X)V)M_:=^'_\`V-?_`+KOB&OU:K\J/^">(_XR:^'I_P"IL_\`==\0
> MU^J]?#\:_P#(TEZ1_(^IX:_W&/J_S"BBBODSWPHHHH`****`"BBB@`HHHH`*
> M***`"KF@?\A:+\?_`$$U3JYH'_(6B_'_`-!-3/X6-;G24445PFX4444`%%%%
> M`'+?$'_D;/`W_8;E_P#3;?5U-<M\0?\`D;/`W_8;E_\`3;?5U-,04CH)$*GD
> M,,&EHJ9135GL,X&Q_9?\"Z=^S0WP>AT/9\.6T!_"YTC[9<'_`(ESPF!H/.,G
> MG<QL5W^9OYSNSS7,VWG17J67V$7
> M8L/M'V/RTWD^8R<,QKV2BJ<FY.;W?7J.3<H\LM5K^._WVU_6^
> MM^YYSXN_9,^'WCO_`(2G^U?#_P!J_P"$U\)Q^!]9_P!.N4^V:/']IV6ORR#9
> MCD%
> M%%%2`4444`<W\-/A'X>^#^B:CIOAS3_N9+FYES(S
> M$;YI9&V@A5W84*``/)6_X)?_``1W^&!'X3U*VM_"%AIFF:?:6_B;5H+.2#3)
> MS<:>+F!+D17C6\I+QO<K*Z$G#<U[]133LTUTM^%TONN[=KNPVV[WZZOSN[N_
> M>=3R?0/V(?AIX8\8G7;/1-26]7Q5+XVACDU_49K.SUB6&ZAFNH+5YS!`9
> M%O;HND2+&W*KRB2XA@25_/FW.?-DW>MT5-E:WE;Y62MZ625NR2Z()2<K\
> MVM_\V_SE)^K;ZL\Y^'_[)GP^^%O_``@G]A>'_L/_``K/0KGPUX;_`-.N9?DM_GEWN/+X8;FROP]_9.^'_PJ?P&V@:!]@/PRT.X\-^&O
> M].N9?QY?##<V?1:*OGE>]]?\[__`"4O_`GW
> M8<S[A1114B"BBB@`HHHH`****`"BBB@`HHHH`****`"BBB@`HHHH`****`"B
> MBB@`HHHH`****`"BBB@`HHHH`****`"BBB@#EM(_Y+7X@_0KJ:Y;
> M2/\`DM?B#_L":9_Z/U"NIIL#\M/^"U3;?VDM0_Z^U_\`
> M@M:,_M(:A_V+7AC_`-*O$U?$&\U^Y\'?\BNG\S\OXB_WZ9]2_P#!/'_DYGX>
> M_P#8V?\`NN^(:_5:ORI_X)X_\G,_#W_L;/\`W7?$-?JM7Q'&W_(UEZ1_(^HX
> M9_W"/J_S"BBBODCZ`****`"BBB@`HHHH`****`"BBB@`JYH'_(6B_'_T$U3J
> MYH'_`"%HOQ_]!-3/X6-;G24445PFX4444`%%%%`'+?$'_D;/`W_8;E_]-M]7
> M4URWQ!_Y&SP-_P!AN7_TVWU=33$%%%%(84444`%%%%`!1110`4444`%%%%`!
> M1110`4444`%%%%`!1110`4444`%%%%`!1110`4444`%%%%`!1110`4444`%%
> M%%`!1110`4444`%%%%`!1110`4444`%%%%`!1110`4444`<MI'_):_$'_8$T
> MS_T?J%=37+:1_P`EK\0?]@33/_1^H5U--@?EI_P6K'_&2.H?]BUX8_\`2KQ-
> M7Q#L%?<'_!:C_DY'4?\`L6O#'_I5XFKXB\OWK]SX._Y%=/YGY?Q%_OTSZ@_X
> M)X_\G-?#W_L;#_ZCOB&OU6K\J/\`@G@<_M,_#W_L;#_ZCOB&OU7KXCC;_D:R
> M](_D?4<,?`%%%%`!1110`4444`%%%%`!1110`5<T#_`)"T
> M7X_^@FJ=7-`_Y"T7X_\`H)J9_"QK<Z2BBBN$W"BBB@`HHHH`Y;X@_P#(V>!O
> M^PW+_P"FV^KJ:Y;XEVM_]N\,W]AIEUJW]DZJUS/!;20I+Y;6=U#N'FNBG#RI
> MQNS@GTH_X6!JW_0C>*?_``(TW_Y+IV$=317+?\+`U;_H1O%/_@1IO_R71_PL
> M#5O^A&\4_P#@1IO_`,ET6&=317+?\+`U;_H1O%/_`($:;_\`)='_``L#5O\`
> MH1O%/_@1IO\`\ET6`ZFBN6_X6!JW_0C>*?\`P(TW_P"2Z/\`A8&K?]"-XI_\
> M"--_^2Z+`=317+?\+`U;_H1O%/\`X$:;_P#)='_"P-6_Z$;Q3_X$:;_\ET6`
> MZFBN6_X6!JW_`$(WBG_P(TW_`.2Z/^%@:M_T(WBG_P`"--_^2Z+`=317+?\`
> M"P-6_P"A&\4_^!&F_P#R71_PL#5O^A&\4_\`@1IO_P`ET6`ZFBN6_P"%@:M_
> MT(WBG_P(TW_Y+H_X6!JW_0C>*?\`P(TW_P"2Z+`=317+?\+`U;_H1O%/_@1I
> MO_R71_PL#5O^A&\4_P#@1IO_`,ET6`ZFBN6_X6!JW_0C>*?_``(TW_Y+H_X6
> M!JW_`$(WBG_P(TW_`.2Z+`=317+?\+`U;_H1O%/_`($:;_\`)='_``L#5O\`
> MH1O%/_@1IO\`\ET6`-(_Y+7X@_0KJ:Y'P8NI:I\0];U:\T6_T:VN
> M-.L;2%;N6W=Y7BENW<@0RR``"9.I&>>.*ZZA@?EO_P`%I5W?M(ZE_P!BUX8_
> M]*O$U?$OE^]?;G_!:`9_:2U+_L6?#'_I5XFKXG\OWK]SX._Y%=/YGY=Q%_OT
> M_D?2W_!.C9_3PQ_N$?5_F%%%%?)'T`4444`%%%%`!1110`4444`%%%%`!5S0/^0M%^/\`
> MZ":IU<T#_D+1?C_Z":F?PL:W.DHHHKA-PHHHH`****`,;QU*Y"I'&O&68D#D@#DD@`D>7:7^U]NU&1K_0IKPA>>*?!%E<6<%U=G1KQKN:WMEWSS1/
> M;7%LYC7^)T%QY@4<DQ`#)(%>;:3XO\+?\(\FGZ+]CUWQ&C+Y>F6#K-<-*"-H
> M=/O0IG[S2A`J.>VCN-4-O
> M-<Q1&XF2&$E84=]K22(-P7`!R2`"1H?#7X\>$_B_XH\8Z-X<U8:EJ7@'5$T7
> M7HA;S1"QNWMH;I8]SJJR9AN(7W1EE^?&<@@>!?\`!0_]DGQ)\</^">VC?"_0
> M=*B\5ZG9ZKX42\MI+B*%+NTL=5L);MRTS(I`@AE8KG<V,`%B`?B;QE_P2D^/
> MFJ^#/'&DZUH^LZYX2'QMAUR?1=(O/#]YJ'CGPQ;:';Z98W`AUCS=-EFBD@AF
> M>WU!5#-$8J+;TG%<L91?>__`(#-JWJX
> MI>7,MVT?L+17Y5>)O^"47Q(\/?LY_"NU\'>'?$L6M:XX^!?Q@\9>
> M)OB-HRZ4?!NDV_PL^'BB]MQ%>A8G?R3/YT$9C<K(!9(64$UJHK
> MFY6^]_E?;O>\-N\FSYJ]EK\Z?'7M/Q'X=TX'^U:2FI^'+2+^V-/\0+
> M<ZFT#V5PSR1I;,+->SJG)J:\UR/:2;
> MNJN5MQU5F81<OYBH8TV&XAX=E+;_E!P<?GM^VC_P`$WO&>B?%KQ_%\'?@O
> MX8G^&.N^$/"?A\:'I`TK3X9(H-?O[S5%M+"::"SEN(X`^#EG\1/V<+GXO>"_`4GQ"M;KPG=:KX8WQ6FJ:E:W.DD
> M6QN(-/<@*SF-/+C@,;-&JM'!&T0FY1YK;<^FU^7F4;><O=:W35[,NI!1GRIW
> M7NSNM]';Y_K1IWQT\*ZM\<-5^'%OJGF>--%T>VU^]T[[-,/)L;B::&
> M&;S2GE-NDMYAM5RPV9(`()ZVOQI?4?@1?:%<RW=_K+?"/P7X;U
> M6>UUVRGG\2-IVM7MWJ6BI+>;D=FLIHX0]W']EF)"2%HVDQ]L_P#!)?\`91U#
> M]E#X-^+;"ZT'QGX0L-?\23:EIOA_Q%J&@22Z;!Y,,1=+30;6#3-/$KQO(;>V
> M:926\UI/,ED1>B,$U*Z^U/^"R*TX._P"173^9^7\1?[],^@_^"=7_`"<U\/O^QL_]UWQ#7ZM5
> M^4O_``3J_P"3FOA]_P!C9_7^84445
> M\D?0!1110`4444`%%%%`!1110`4444`%7-`_Y"T7X_\`H)JG5S0/^0M%^/\`
> MZ":F?PL:W.DHHHKA-PHHHH`****`"BBB@`HHHH`****`"BN+U+XCZPWB75;+
> M3=(TJ:WTF=+5Y%<1_P`)%<1_PGOB;_H#>
> M%_\`P>7/_P`A4?\`">^)O^@-X7_\'ES_`/(5`';T5Q'_``GOB;_H#>%__!Y<
> M_P#R%1_PGOB;_H#>%_\`P>7/_P`A4`=O17$?\)%<1_P`)%<1_PGOB;_H#>%_\`P>7/_P`A4?\`">^)O^@-X7_\'ES_`/(5`';T5Q'_
> M``GOB;_H#>%__!Y<_P#R%1_PGOB;_H#>%_\`P>7/_P`A4`=O17$?\)%<1_P`)%<1_PGOB;_H#>%_\`P>7/_P`A4?\`">^)O^@-X7_\
> M'ES_`/(5`';T5Q'_``GOB;_H#>%__!Y<_P#R%1_PGOB;_H#>%_\`P>7/_P`A
> M4`=O17$?\)%<1
> M_P`)%<1_PGOB;_H#>%_\`P>7/_P`A
> M4?\`">^)O^@-X7_\'ES_`/(5`';T5Q'_``GOB;_H#>%__!Y<_P#R%1_PGOB;
> M_H#>%_\`P>7/_P`A4`=O17,^!_'%]XAUW4=.U'3K2QN;&""Z1.:Z:@#\Q/\`@L6,_M+:K_V+'AC_`-*O$U?&GE^]?9O_``6&
> M7=^TOJO_`&+'AC_TK\35\<>5C7_`.Z6Z^(XV_Y&LO2/Y'U/#'^
> MX1]7^84445\D?0!1110`4444`%%%%`!1110`4444`%7-`_Y"T7X_^@FJ=7-`
> M_P"0M%^/_H)J9_"QK<Z2BBBN$W"BBB@`HHHH`^<?^"KM]K=I^Q7J</AG?V4=UXATZWE,4J$$$QRNI'1@Q!!!(/D5G^VEX@T[]
> MISP)I_C37+/P]KGPZ\$^-HO'NGW.K-8:'<WMC_84MMJ4NT,J6TUO.;B*1HW:
> M&.ZD3;O61*^R/BI\)?#_`,;/"(T'Q/I_]IZ4+ZRU(0>?)#_I%G=17=L^Z-E;
> MY)X(GQG#;<,"I(/$_%G]ACX3_'+XGWOC/Q5X+T_5O%&I>%;OP3=Z@TTT4ESH
> M]RX>6T<1NJL-ZAE<C?&2VQEW',PYHWMU<W]]/EC]TKW75-/5Q2-H2A
> MZ;5U]VJWU5E92;/GCX??\%;_`!;\0O">FP6OP7=/'&J?$2+X?1:3=ZOJ6CV0
> M>;1)=6BOC)JFDV=ZL`6/9(&L58*'>(7&$23HOA)_P4P\7>+_`!;X+7Q3\*-,
> M\+>%_%/BS5_A]=:C;^+SJ5WI^O:9'J#W"K;"SC66P<Z;<+'<^<DS$H7MHP<C
> MUOX>?L"_"SX87=A=:9H>KW%_IWB)/%D=_JOB75-6OI=42P?3EN9;B^U_:;KF3YM
> M_P!NNOW;9C7S?E0;5VZ2MKR^7Y03_'G?JX]-%CHX)/XK?C^\?GI_#7HI=;-_
> M/?[(/_!47QI^V-LO/#_P)\2V^A:K_9NI:1J%V=5TV&72;F0TNUM&
> MN(K:5;E8+"YODF5)%6;A&D^RJ\+\&?\`!-WX1?#]$M]*T;Q-!I%OJ5KJ]GHD
> MGC/6I]#TJYMKU+Z!K/3I+MK2T5+A%8);Q1IM!3;L)4^Z4VX\B26MW]VENWGT
> M\[NZ45*?+J^UE:WXP\8)$
> MK2O'K2,RH-Q4'3K'!('3.#^1K0_LJZ_Y]KC_`+]FH&5Z*L?V5=?\^UQ_WE77_/M<?]^S0!7HJQ_95U_S[7'_`'E77_/M<?\`?LT`5Z*L?V5=?\^U
> MQ_WE77_/M<?]^S0!7HJQ_95U_P`^UQ_WE77_`#E77_/M<?]^S0!7HJQ_95U_S[7'_`'E77_/M<?\`?LT`
> M5Z*L?V5=?\^UQ_WE77_/M<?]^S0!7HJQ_95U_P`^UQ_WE77_`#E77_/M<?]^S0!7HJQ_95U_S[7'_`'E7
> M7_/M<?\`?LT`5Z*L?V5=?\^UQ_WE77_/M<?]^S0!7HJQ_95U_P`^UQ_W
> ME77_`#E77_/M<?]^S0!7HJQ_95U_S
> M[7'_`'E77_/M<?\`?LT`5Z*L?V5=?\^UQ_WE77_/M<?]^S0!7HJQ
> M_95U_P`^UQ_WE77_`#E77_/M<?]^S
> M0!7HJQ_95U_S[7'_`'E77_/M<?\`?LT`5Z*L?V5=?\^UQ_WE77_/
> MM<?]^S0!7HJQ_95U_P`^UQ_WE77_`#E77_/M<?]^S0!7HJQ_95U_S[7'_`'E77_/M<?\`?LT`5Z*L?V5=?\^U
> MQ_WE77_/M<?]^S0`SP%_R4W6?^P)IW_I3J-=O7$>!?D^*6N1GB2+1=.5
> MU/5#]HU`X(`'YD?\%@O^3F=6_Z^Q/\`@L`,
> M_M,ZM_V+'AC_`-*_$U?'M?NG!W_(KI_,_+^(O]^F>V_\$ZQC]ISX??\`8U_^
> MZ6Z_*?_`()X+M_:<^'P_P"IL_\`==\0U^K%?$<;?\C67I'\CZCAC_<(
> M^K_,****^2/H`HHHH`****`"BBB@`HHHH`****`"KF@?\A:+\?\`T$U3JYH'
> M_(6B_'_T$U,_A8UN=)1117";A1110`4444`%%<M\8?C#I'P-\&/KVMVGBB\L
> M4F2$QZ!X:U+Q#>;FS@_9=/@GG*\<OLVKW(S7/_LQ?M9>"_VPO`8\3^`Y?$]Y
> MH$BQO;WNK>%-5T&*^CD7>DMO]OMH#<1%?^6D0=.V<T1]Z_+K;?R]0>EK]3TF
> MBBB@`HHHH`P]=^&7AOQ1J#7>I^'M#U&4V_M._#IOX>^_BP_\`J.^(:_4^OA^-7_PJ
> M2](_D?4\-?JY+XC_!#PY\6M?\`#>H^(+;4+Z3PG?#4M/ME
> MU2:N+=_&-WJ.ML+BX>S#K!!YRK&@O"NGB&-$F#+#"$Z]<
> M^-O&_P`3/#^EV,^E#P_9>&O`WBK6-&UG3FTR)+V);S3%>3>GG9\KO=.-HM-*X2G>3:VLEYOW8)WMTO%M
> M6M9R<KW=EQ/T_Y"/_3Y_P`]O^FF^NVH
> MHK2K/GFY]W<PI0Y(*'96"BBBLS0****`"BBB@`HHHH`****`"BBB@`HHHH`*
> M***`"BBB@`HHHH`****`"BBB@`HHHH`****`"BBB@`HHHH`****`"BBB@`HH
> MHH`****`"BBB@`HHHH`****`"BBB@`HHHH`_,*_$
> MU?(E?7O_``5S&?VG-7]?^$7\+_\`I7XFKY&K]TX._P"173^9^7<1?[]/Y'N'
> M[!"[?VF/AV?7Q:?_`%'/$-?J17Y<_L%C'[2WPZ_1J^%XR_P"1
> MG+T7Y'U?#?\`N*]7^84445\J>\%%%%`!1110`4444`%%%%`!1110`5<T#_D+
> M1?C_`.@FJ=7-`_Y"T7X_^@FIG\+&MSI****X3<****`"BBB@#`^('C*?PA:Z
> M>MGIXU*^U2\%G;PM.((PWER2LSOAMJJD3GA2>`,<UE_\)IXJ_P"@'X9_\'MQ
> M_P#(=2_%#_D->#_^PO+_`.FZ]KS'6/''CCQKXW\26/@U_#%A8>$72TG?5N/_`)#H_P"$T\5?]`/PS_X/;C_Y#KRZS_;/\#P>%])O]6O;S3+G4=&M
> M];GM8]/N;W^SN7U-
> MY(X6:+3N/_D.N5^(?Q]\*_"O5TL=;U"Y
> M@N3;_;)1;Z=<WBV5ONV^?<-#&ZV\60WL.S]YM6-49F4"4.49<J/O.R\_PW_'3^F#
> M5MSTG_A-/%7_`$`_#/\`X/;C_P"0Z/\`A-/%7_0#\,_^#VX_^0ZGHH"Q!_PF
> MGBK_`*`?AG_P>W'_`,AU>\#^.+WQ%K6IZ;J6F1:=>Z='!.#!=_:8+B*7S`K*
> MQ1&!#12`@J,8'7-<)I/L+S69(YVB;E&94MG52RD'&XXS5S_A-/%7_`$`_#/\`X/;C_P"0Z\G\
> M:?%'4?A;\#O`$]G<:5I%MJ-M8VEC^U-9>'/'.J>&_$J2B3PHC)V9;K:#>&^T_P`^:U\T
> MPR1$212-'(I5U5@5=6'3M6Y0P^9!_P`)IXJ_Z`?AG_P>W'_R'1_PFGBK_H!^
> M&?\`P>W'_P`AU/10%B#_`(33Q5_T`_#/_@]N/_D.C_A-/%7_`$`_#/\`X/;C
> M_P"0ZGHH"Q!_PFGBK_H!^&?_``>W'_R'1_PFGBK_`*`?AG_P>W'_`,AU/10%
> MB#_A-/%7_0#\,_\`@]N/_D.C_A-/%7_0#\,_^#VX_P#D.IZ*`L0?\)IXJ_Z`
> M?AG_`,'MQ_\`(='_``FGBK_H!^&?_!N/_D.IZ*`L0?\)IXJ_P"@'X9_\'MQ_P#(='_"
> M:>*O^@'X9_\`!N/\`Y#H_X33Q5_T`_#/_
> M`(/;C_Y#J>B@+$'_``FGBK_H!^&?_!%`6(/\`A-/%7_0#\,_^#VX_^0Z/^$T\5?\`0#\,_P#@]N/_`)#J>B@+$'_"
> M:>*O^@'X9_\`!%`6(/^$T\5?]`/PS
> M_P"#VX_^0Z/^$T\5?]`/PS_X/;C_`.0ZGHH"Q!_PFGBK_H!^&?\`P>W'_P`A
> MT?\`":>*O^@'X9_\'MQ_\AU/10%B#_A-/%7_`$`_#/\`X/;C_P"0Z/\`A-/%
> M7_0#\,_^#VX_^0ZGHH"Q!_PFGBK_`*`?AG_P>W'_`,AT?\)IXJ_Z`?AG_P`'
> MMQ_\AU/10%B#_A-/%7_0#\,_^#VX_P#D.C_A-/%7_0#\,_\`@]N/_D.IZ*`L
> M0?\`":>*O^@'X9_\'MQ_\AT?\)IXJ_Z`?AG_`,'MQ_\`(=3T4!8@_P"$T\5?
> M]`/PS_X/;C_Y#H_X33Q5_P!`/PS_`.#VX_\`D.IZXO2?V@_"6N>)X]%M=1N9
> M-5DF,`M3IURLBN,TZ.
> M"<&"<_P"P-IW_`*4:A79T
> M,$?FA_P5Q&?VG-8_J^N/^"N'_)SNL?\`8K^%_P#TK\35
> M\DU^Y\'?\BNG\S\PXB_WZ1KSOQ)\&_$$'B2\(^*K
> M3PY%XI$;:M%<:1]N<3)&(1<VK>=&L4QB5%)D69"8HSLX8/ZSXV\$P>.+&UBE
> MNKZPGL+E;NVN;214E@D567(W!E(*NZD,I!#'BLK_`(5?>_\`0X>(_P#P&TP3:/)K[]E"R30?$&EZ=JLMG8ZQX*A\&0++!Y\EJD8N0+AFWCS&/VC
> ME<+DH3N^;BG8?LB6NB?&U_&%M_PAEZUU-:7-P=7\+)>ZE;2P0I"3:7@F1H`R
> MQH0K))M?<P^]BO9?^%7WO_0X>(__``&T#AXC_P#`;3O_`)%J
> MDVI<RW_X+?YL3U5G_6B7Y)?TV>:?$_X"ZIXQ\7ZKJ>B^)+?0XO$VCQZ%K44^
> ME_;7EMT:8J]N_FH(9@+B8;G65.4.SY3NW_AK\)XOAMXA\3WEO=F:#Q#=6UQ'
> M`8]IM%ALX+4)NW'?D0;LX'WL8.,GK/\`A5]NO^=_SV[=`;N_Z'#Q'_X#
> M:=_\BT?\*OO?^AP\1_\`@-IW_P`BTPN4+;PCIEGXGN=:BL;:/5;R%()KH)B2
> M1%Z`G\LGJ0J@Y"KBUX+_`.2IZY_V!M._]*-0J7_A5]#\+WNC:=XGABL-6\'/X4OA/I7F/DFZ=)X=DR+$JO=/^Z*L-B(H9<;J]
> MKTKX+GP_I\=EI_BCQ):6-N"MO;[;.9;=,\(K2V_P"A
> MP\1_^`VG?_(M#BM?/_)K\F_SW",FK6Z6_!I_FD>6>.OV9/\`A--;N;S^V_LW
> MVBQT6RV?8]^W^SM0:\W9WC_6;MF/X<9RW2L?XM?"E_!>L:GXQM==O#AXC_P#`;3O_`)%IN_1];_>TW]#AXC_\``;3O_D6@+CJ*;_PJ^]_Z'#Q'
> M_P"`VG?_`"+1_P`*OO?^AP\1_P#@-IW_`,BT!<=13?\`A5]_Z'#Q'_X#:=_\BT?\*OO?
> M^AP\1_\`@-IW_P`BT!<=13?^%7WO_0X>(_\`P&T[_T.'B/_P`!M._^1:/^%7WO_0X>(_\`P&T_Z'#Q'_`.`VG?\`R+1_PJ^]_P"AP\1_^`VG?_(M`7'44W_A5][_T.'B/_`,!M._\`D6C_`(5?>_\`0X>(_P#P&T_P"AP\1_^`VG?_(M'_"K#AX
> MC_\``;3O_D6C_A5]`3^63U(50<A5Q?_`.%7WO\`T.'B/_P&T#AXC_\``;3O_D6@
> M+D7@O_DJ>N?]@;3O_2C4*P2,-L1
> M5C1$507<\+R6.2:WZ&"/S2_X*W#/BOX7_]*_$U?)%?7'_!6W_DYSX._P"173^9^7\1?[]/Y'M71SQ#7ZC5\+QE_P`C.7HOR/J^&_\`<5ZO\PHH
> MHKY4]X****`"BBB@`HHHH`****`"BBB@`JYH'_(6B_'_`-!-4ZN:!_R%HOQ_
> M]!-3/X6-;G24445PFX4444`%%%%`&/XS\=6'@*RMI[_CO@(@+?=1CG':L(?'O16/%EXH/_<`O/_C=.^+D)GU3P<@ZG6G_`/2"\K1L
> MM&6-03R:`#0OB?IGB/35N^`/`T'A7]GOX`S>$=*\.Z/K.L:Q:33W!L@D<\QTJ]!FG$6UIF4$G!92V-
> MN],[@1U;7G%?^!.WZ#:T;[)O\C_&C_`(3*U_YYW'_?
> M(_QKY4TWXW^*/$.J:4(/#OAC5O&D%CXGLHY88L)M/UOQ/HK_`-=UW06=[=;V^?;\_6S/<O\`A,K7_GG<?]\C
> M_&C_`(3*U_YYW'_?(_QKYJ\2?M)ZKKFAS:CX1DL+NVU:_BT_PT!I1O)=69+=
> MI]^TEXF\?_#C4/-'>*;<8F">1N@4G(<E=RY.X.K=U>_3_)O\DPBN9I+K_FH_FSZ]_X3
> M*U_YYW'_`'R/\:/^$RM?^>=Q_P!\C_&OF2;]HS6XOC3H&B6%K877A>]O(]%O
> M9%T]8/L-X=/>Z\M)C=[Y"%$9VK:;`KD>;N4BO+/"_P`0?$.G_L9VFA7TOAZ\
> MT;7OAIJMQ9QV44HN[#[+;(A::0N4D5_-P<)'Y;X3,GWJ):*3[?Y-_DKKNF%)
> M<OQ=OP=T_-'W=_PF5K_SSN/^^1_C1_PF5K_SSN/^^1_C7S'X/^.'C?Q!
> M\97\/:-X<BNO#'AN:QT_4YREOYJB6TBF,YD:\22,*)1A%M)0XC;$@+$)UWCC
> MXB>(?#/QETO3;C1O'\W=;^='.HM"`L95I861]Q`8-
> MA:*ON*_W?I]^EO6V^AG"7-'F\K_UZ=>V^Q[=_P`)E:_\\[C_`+Y'^-'_``F5
> MK_SSN/\`OD?XU\6?!/XYC<>WUGX^>,O`,-_:ZK-X1UR]@BT6]CN]-LY;61)(VGD.0F]TD\P!L'*`*=UN'O\B6+EHKO^MOUDE_3/IS_A
> M,K7_`)YW'_?(_P`:/^$RM?\`GG<?]\C_`!KY9^(7Q,N?%?QITC3Y4M7MO"7Q
> M!@LK8VX)DD5M`GN&#Y8@N'E8<`<`#&<DU/AEX_USXE_'SX9ZYK%WX:EAUWPK
> MJNIV-KIB2++812R6!$4K/(PE*X`\Q5C!97&P8J*?OVMU_P#D>9?>K_=Z!/W7
> M;RO^+7YK\3ZQ_P"$RM?^>=Q_WR/\:/\`A,K7_GG<?]\C_&ODJX^(/B'X=?&3
> MXH:EIDOAY]*M_%&C6]>_:;2P@"PLCJL3#=E=R2>8<KB/;N/4?!SX
> MX>-_BA\5M41O#D47@JSU+4-)^U!+<26LEK(T8=Y/MC2N79#^\C_&C_A,K7_GG<?]\C_&
> MOG'XD_M`>(OA3XG\73:O:V<.DZ5I=WJ&A6`TV5I=<6WMEE=_MRS-%$0^\&)X
> M%?:-REP":S/#_P`=OB0_A_2+?6=&TC2-2\5ZM;V&D:M=VL2V"1R6TL[.T%OJ
> M%R9#^YV)_I$7F-,G"?RZZA+3?S_``5V_1?CTN?4/_"96O\`
> MSSN/^^1_C1_PF5K_`,\[C_OD?XU\`NC/7;.X_9L\!6
> M"W=HVH1>'+.YDMDF5I4B=2JR%>NQBC@,1@E3Z&FE=-KR_'F_^1?F3?\`K^O5
> M?>>]?\)E:_\`/.X_[Y'^-'_"96O_`#SN/^^1_C7,T4AG3?\`"96O_/.X_P"^
> M1_C1_P`)E:_\\[C_`+Y'^-<S10!TW_"96O\`SSN/^^1_C1_PF5K_`,\[C_OD
> M?XUS-%`'3?\`"96O_/.X_P"^1_C1_P`)E:_\\[C_`+Y'^-<S10!TW_"96O\`
> MSSN/^^1_C1_PF5K_`,\[C_OD?XUS-%`'3?\`"96O_/.X_P"^1_C1_P`)E:_\
> M\[C_`+Y'^-<S10!TW_"96O\`SSN/^^1_C1_PF5K_`,\[C_OD?XUS-%`'3?\`
> M"96O_/.X_P"^1_C1_P`)E:_\\[C_`+Y'^-<S10!TW_"96O\`SSN/^^1_C1_P
> MF5K_`,\[C_OD?XUS-%`'3?\`"96O_/.X_P"^1_C1_P`)E:_\\[C_`+Y'^-<S
> M10!TW_"96O\`SSN/^^1_C1_PF5K_`,\[C_OD?XUS-%`'3?\`"96O_/.X_P"^
> MSSN/^^1_C1_PF5K_`,\[C_OD?XUS-%`'8Z7K,6K^9Y:R+Y>,[@!US?\`_\`9JWJ`/S3_P""MO\`R<]K'_8K^%__`$K\35\EU]:?\%;?^3GM
> M8__<Z;=:;=_:X9
> MX!&65O*DB(Q(CJ05E;^&L0?#;Q*/^9TUC_OS8_\`R+7=44`<7X=^%]QX=TLV
> MPN_M9>::XDFG(WRO+*TKDGS0]3MI8;G0/#5Q#.MRDJ2V,;K(+
> MA@]P&!3!$K`,^?OD`MDU=\*_!ZS\"Z%#I>AZ?H^C:9;;O*L"O/#?A:ZT.TE\Z#3IM/B>TADRQWK
> M$4V*V68Y`SECZU8B^`^D06,ULFB^'DMKBR&F2Q+9H$EM1NQ;LNS!B&]\(?E^
> M=N.37?T4`>=#]G3P^/%JZ_\`\([X8_MU%5%U+K"JNQ0)=F_`7Y1SP..E
> M5]#_`&7_``KX8AU&/3?"GA#3X]7M_LE^MMID,0O8=NWRI0L8WIM)&ULC!Q7I
> MM%`?U]VQYQJG37H
> M-%']?>%CAK'X+:?I:V"VVEZ);KI=N]I9"*V5!:0OMW11X7Y$;8F57`.U>.!6
> M=HG$TG;0+?QP_B>/P]X83Q+("'U9;",7S#;LP9MF\_+\O7IQTKT6BDM-@>N
> MYY\06V@^&DZ4.4,L8CVN5/(W`X/2O4Z*+:6"
> M^MSRX0\&7EMHT+6^GPSZ5#)'8QMPR1*8R(U.!D+@'%:\W
> MP4TZXL=2M9-+T.2VUE=FH0M;*8JR8XW`9]ZV]#^#-CX
> M8=&TW3=%T]HK:.R0VUNL12",L4A&U1B-2'_"C_`(0VZ_YZ6_\`WT?\*Z6BD,YK_A#;K_GI;_\`?1_PH_X0
> MVZ_YZ6__`'T?\*Z6B@#FO^$-NO\`GI;_`/?1_P`*/^$-NO\`GI;_`/?1_P`*
> MZ6B@#FO^$-NO^>EO_P!]'_"C_A#;K_GI;_\`?1_PKI:*`.:_X0VZ_P">EO\`
> M]]'_``H_X0VZ_P">EO\`]]'_``KI:*`.:_X0VZ_YZ6__`'T?\*/^$-NO^>EO
> M_P!]'_"NEHH`YK_A#;K_`)Z6_P#WT?\`"C_A#;K_`)Z6_P#WT?\`"NEHH`YK
> M_A#;K_GI;_\`?1_PH_X0VZ_YZ6__`'T?\*Z6B@#FO^$-NO\`GI;_`/?1_P`*
> M/^$-NO\`GI;_`/?1_P`*Z6B@#FO^$-NO^>EO_P!]'_"C_A#;K_GI;_\`?1_P
> MKI:*`.:_X0VZ_P">EO\`]]'_``H_X0VZ_P">EO\`]]'_``KI:*`.:_X0VZ_Y
> MZ6__`'T?\*/^$-NO^>EO_P!]'_"NEHH`YK_A#;K_`)Z6_P#WT?\`"C_A#;K_
> M`)Z6_P#WT?\`"NEHH`YK_A#;K_GI;_\`?1_PH_X0VZ_YZ6__`'T?\*Z6B@#F
> MO^$-NO\`GI;_`/?1_P`*/^$-NO\`GI;_`/?1_P`*Z6B@#,\.Z-+I'G>8T;>9
> MMQM)/3/MK'_8
> MK^%__2OQ-7R77H
Re: Call drops when it gets to DB query module [message #699464 is a reply to message #699237] |
Thu, 21 July 2011 11:02  |
Hi Sergej--
After talking this over with the guy who fixed the error, there is one
more step that I didn't communicate to you (sorry about that). There's
a field in the OpenVXML database table file (which appears in OpenVXML
under the databases folder -- yours is IVR_REPORT_CREDIT_CARD_INFO.dbt)
which contains an invalid value as a result of the error (now fixed).
You can easily correct this manually or, if you'd prefer, delete the
table and the recreate it. However, fixing it by hand is pretty simple.
Right-click the .dbt file and open it with the XML editor. Towards the
top of the file, you'll see a name attribute with
simply remove the extension so that it reads
and then save the file.
Good luck, and please let me know how this works out for you.
Randy
In <j08ie9$ba6$1@news.eclipse.org> Sergej wrote:
> Hi Randy!
> Thanks for the reply ...
> But again after i have updated VTP and rebuild DB block (remove and
> add new one) errors are still the same .... nothing changed :(
> Am i missing something?
> Brgds,
> S.
Current Time: Wed Jul 23 00:49:47 EDT 2025
Powered by FUDForum. Page generated in 0.09559 seconds
