Home » Modeling » TMF (Xtext) » Auto edit for multi line comments
Auto edit for multi line comments [message #694615] Fri, 08 July 2011 21:37 Go to next message
Hi all,
unfortunately my grammar's comment terminal rules look like this:
terminal SL_COMMENT: "%" !("\n" | "\r")* ("\r"? "\n")?;
terminal ML_COMMENT: "%{" -> "%}";
so they have a common prefix. I think this causes the following problem:
Here's my auto edit strategy provider:
	private static void accept(IEditStrategyAcceptor acceptor, IAutoEditStrategy strategy) {
		acceptor.accept(strategy, IDocument.DEFAULT_CONTENT_TYPE);
		acceptor.accept(strategy, TerminalsTokenTypeToPartitionMapper.COMMENT_PARTITION);
		acceptor.accept(strategy, TerminalsTokenTypeToPartitionMapper.SL_COMMENT_PARTITION);
	public static final String[][] BLOCK_KEYWORD_PAIRS = { { "{", "}" }, //$NON-NLS-1$ //$NON-NLS-2$
		{ "%{", "%}" }, //$NON-NLS-1$ //$NON-NLS-2$
		{ "<<", ">>" } }; //$NON-NLS-1$ //$NON-NLS-2$
	protected void configure(IEditStrategyAcceptor acceptor) {
		accept(acceptor, defaultIndentLineAutoEditStrategy.get());
		for (String[] blockKeywordPair : BLOCK_KEYWORD_PAIRS) {
			accept(acceptor, singleLineTerminals.newInstance(blockKeywordPair[0], blockKeywordPair[1]));
			accept(acceptor, multiLineTerminals.newInstance(blockKeywordPair[0], null, blockKeywordPair[1]));
		final String[][] brackets = new String[][] { { "[", "]" }, //$NON-NLS-1$ //$NON-NLS-2$
			{ "\\(", "\\)" }, //$NON-NLS-1$ //$NON-NLS-2$
			{ "(", ")" } }; //$NON-NLS-1$ //$NON-NLS-2$
		for (String[] blockKeywordPair : brackets) {
		accept(acceptor, partitionInsert.newInstance("\"", "\"")); //$NON-NLS-1$ //$NON-NLS-2$
Unfortunately, when I type %{, only } is inserted, not %}. How can I circumvent this?
Thanks in advance,
thSoft
Re: Auto edit for multi line comments [message #694661 is a reply to message #694615] Sat, 09 July 2011 02:11 Go to previous messageGo to next message
what about simple changing the precedence (order) of the stuff in the BLOCK_KEYWORD_PAIRS array.
~Christian
Re: Auto edit for multi line comments [message #694808 is a reply to message #694661] Sat, 09 July 2011 16:53 Go to previous message
Hmm, this solved it, but strangely only if the document is not empty. I'll file a bug. Thanks!
Previous Topic:Cannot find meta model when reusing parts of XBase
Next Topic:Toggle "Link with editor" in Outline
Current Time: Sat Jul 26 23:14:52 EDT 2025
Powered by FUDForum. Page generated in 0.05466 seconds
