Home » Eclipse Projects » Eclipse Platform » [CVS] problems with CVSNT
[CVS] problems with CVSNT [message #69341] Tue, 10 June 2003 09:58 Go to next message
Hi all
i'm using CVSNT server in my machine
when i try to share a project in the repository in it i get this message
CVSNT repository ':pserver:jkhalil@jkhalil:/Tools' is configured to use a
repository prefix. However, CVSNT does not always properly communicate
resource paths in this mode resulting in the failure of some specialized
Eclipse CVS operations. The use of a repository prefix should be disable if
the full functionality of the Eclipse CVS client is desired
note: i got message like it when i first created the repository
how can i solve this???
thanks
Re: [CVS] problems with CVSNT [message #69460 is a reply to message #69341] Tue, 10 June 2003 10:28 Go to previous message
You need to load the CVSNT applet from the Control Panel. Under the
"Repositories" tab, uncheck "Repository Prefix". Note that this will change
your CVSROOT, and if you have TortoiseCVS or any similar applications, you
will need to make the appropriate changes.
"Joseph Khalil" <jkhalil@eg.ibm.com> wrote in message
news:bc4o8j$hgr$1@rogue.oti.com...
> Hi all
if
> thanks
Previous Topic:Status Line
Next Topic:debug variables not showing up
Current Time: Tue Jul 22 23:00:18 EDT 2025
Powered by FUDForum. Page generated in 0.04050 seconds
