Home » Modeling » OCL » Navigating a non-navigable (one way) association(Is it possible to navigate along a non-navigable (one way) association?)
icon5.gif  Navigating a non-navigable (one way) association [message #694498] Fri, 08 July 2011 13:54 Go to next message
I have the following XML model:
MultiBlock
     Block
          BlockDef
               Parameters
                    Parameter
          EmbBlocks
               Block
                    BlockDef
               Block
                    BlockDef
Block must contain BlockDef
Block can contain EmbBlocks
EmbBlocks can contain Block
I want to select all the Block objects contained in the EmbBlock object if the top level BlockDef has certain values.
I was trying
context MultiBlock
block.embBlocks->excluding(null).block->select(this.block.blockDef.templateName='SYSTEM:CPM200')
but this fails.
Evaluating:
Results:
Parsing failure
null
Unresolved property 'block' for 'unknown-type'
Unresolved property 'embBlocks' for 'OclInvalid'
Unresolved property 'block' for 'Set<OclInvalid>'
Unresolved property 'this' for 'Bag<OclInvalid>'
Unresolved property 'block' for 'OclInvalid'
Unresolved property 'blockDef' for 'OclInvalid'
Unresolved property 'templateName' for 'OclInvalid'
Unresolved property 'block' for 'Bag<OclInvalid>'
Because the model is XML it does not contain opposite navigations
IE, I can't navigate from BlockDef up to its container Block.
Does OCL have the capability to select objects based on a condition that must be computed from on a non-navigable (one way) association? How do I reference back to the starting context?
I was thinking:
context MultiBlock
block.embBlocks->excluding(null).block->select(<<embBlocks_opposite>>.<<block_opposite>>.block.blockDef.templateName='SYSTEM:CPM200')
what would be a query that works?
This query is going to feed a QVTO transform.
Thank you,
-Mark
Re: Navigating a non-navigable (one way) association [message #694528 is a reply to message #694498] Fri, 08 July 2011 15:08 Go to previous messageGo to next message
Navigation of unnavigable opposites is an optional compliance point for OCL.
This is available from the Indigo release onwards. See "Customizing
Hidden Opposite Lookup and Navigation" in the OCL Documentation.
Navigation of hidden opposites can be expensive. It is usually better to
build a source match in an alternate order that is better defined.
Ed Willink
> MultiBlock
> Block
> BlockDef
> Parameters
> Parameter
> EmbBlocks
> Block
> BlockDef
> Block
> BlockDef
> I was trying
> context MultiBlock
> but this fails.
> Evaluating:
> Results:
> Parsing failure
> null
> I was thinking:
> context MultiBlock
> Thank you,
> -Mark
Re: Navigating a non-navigable (one way) association [message #694547 is a reply to message #694528] Fri, 08 July 2011 15:48 Go to previous messageGo to next message
Thank you Ed for your reply.
Can you make some suggestions on how I might get a collection of objects that depend on the attributes of parent node or sibling?
Something in XPath would be
select="Block/EmbBlocks/Block[../../BlockDef/templateName='SYSTEM:CPM200']"
Thank you,
-Mark
Re: Navigating a non-navigable (one way) association [message #694554 is a reply to message #694547] Fri, 08 July 2011 15:57 Go to previous messageGo to next message
Hi Mark
Try "select()" and "or".
Ed Willink
> Thank you,
> -Mark
Re: Navigating a non-navigable (one way) association [message #694562 is a reply to message #694554] Fri, 08 July 2011 16:46 Go to previous message
Ahhh I get it.
Here is my new query:
context MultiBlock
block->select(blockDef.templateName='SYSTEM:CPM200').embBlocks.block.blockDef
Thank you for your help.
I am just new to this OCL thing and I have 10s of hours trying to figure out what is possible or not worth its time. Ed you helped me understand that what I was doing was possible with OCL so thank you.
-Mark
Previous Topic:OCL Interactive Query fails for large file
Next Topic:oclAsType for external classes
Current Time: Fri Jul 25 21:31:04 EDT 2025
Powered by FUDForum. Page generated in 0.23437 seconds
