Home » Archived » BIRT » Scripted dataset with Birt 3.7.0
Scripted dataset with Birt 3.7.0 [message #694285] Fri, 08 July 2011 05:18 Go to next message
I upgraded the birt engine on my application from 2.6.2 to 3.7.0.
I designed some reports with scripted datasets that worked fine under the 2.6.2 version. However, now that I have upgraded Birt to 3.7.0, all the fields retrieved through the dataset appear blank on the report.
Here is the code for the different event handlers.
open():
importPackage(Packages.com.xxxxxxxxx.yyyy.serverimpl.dao);
retriever = ReportDataRetriever();
details = retriever.getList("from MovementDeliveryDetail mdd where mdd.movement.id = '" + inputParams["deliveryId"] + "'");
iterator = details.iterator();
sum = 0
fetch():
if(iterator.hasNext() == false) {
        return false;
var detail = iterator.next();
row["product"] = detail.getProduct().getFullName();
row["expirationDate"] = detail.getExpiryDateString();
row["price"] = detail.getUnitPrice();
var quantityBox = "0"
if (detail.getNbBoxes() != null)
        quantityBox = detail.getNbBoxes() + " x " + detail.getNbUnitsPerBox();
row["nbBoxes"] = quantityBox;
row["nbUnits"] = detail.getNbUnits() + " unit(s)";
sum += detail.getNbUnits() * detail.getProduct().getPrice();
row["sum"] = sum + " " + detail.getDelivery().getCenter().getCurrency().getSymbol();
return true;
close():
details = null;
retriever = null;
iterator = null;
When I put breakpoints, in the different getters for example at delivery.getReceiptNumber(), the code stops. Do I need to change the way I bind the fields to a data element or a table?
EDIT : It's actually not working either with datasets connected to JDBC data sources, so most probably with no kind of dataset.
I read that reports designed under 2.6.2 version would still work under the 3.7.0 version. What am I missing?
Thanks for your help.
[Updated on: Fri, 08 July 2011 06:21] by Moderator
Re: Scripted dataset with Birt 3.7.0 [message #694515 is a reply to message #694285] Fri, 08 July 2011 14:24 Go to previous messageGo to next message
My guess would be a classpath issue. Where do you have this class? You
may just want to put it in web-inf/lib if it is in a jar.
The above was for the deployed viewer. If you are in the designer check
the project classpath in windows->preferences->report design->classpath
Jason
On 7/8/2011 5:18 AM, forums-noreply@eclipse.org wrote:
> open():
> sum = 0
> fetch():
> return false;
> return true;
> close():
> details = null;
> retriever = null;
> iterator = null;
Re: Scripted dataset with Birt 3.7.0 [message #695315 is a reply to message #694515] Mon, 11 July 2011 09:37 Go to previous message
Thanks. It was due to a conflict between the js.jar in the birt suite and a jar with kind of similar functionalities already present in my application. I fixed it now.
Thanks for your help!
Previous Topic:Customize the pop-up message in BIRT viewer
Next Topic:Implementing an ODA
Current Time: Sat Jul 26 09:37:00 EDT 2025
Powered by FUDForum. Page generated in 0.03850 seconds
