Home » Language IDEs » ServerTools (WTP) » Java EE Module Configuration Editors Proposal Posted
Java EE Module Configuration Editors Proposal Posted [message #690477] Wed, 29 June 2011 11:06 Go to next message
The proposal to create a project to build editors for Java EE descriptors such as web.xml and application.xml using Sapphire has been officially posted. If you are interested in this, follow the link for more information.
http://www.eclipse.org/proposals/webtools.jee-config/
[Updated on: Wed, 29 June 2011 11:07] by Moderator
Re: Java EE Module Configuration Editors Proposal Posted [message #694187 is a reply to message #690477] Thu, 07 July 2011 23:55 Go to previous messageGo to next message
One thing I'd like to see with such an editor is an option to extract all annotations and
configure them as deployment descriptor entries. This would save much time on deployments
that waste cycles searching hundreds of JARs for the possibility of annotations lurking
somewhere. Documenting infrastructure dependencies in deployment descriptors is much more
"visible" than having these lurking in some annotation among thousands of lines of code.
Re: Java EE Module Configuration Editors Proposal Posted [message #694474 is a reply to message #694187] Fri, 08 July 2011 13:03 Go to previous message
Sounds reasonable. Hang on to that thought and when the project is created open an enhancement request to track this requirement.
- Konstantin
Previous Topic:Problems including dependent projects in Dynamic Web Projects
Next Topic:Web Services Explorer blocked by Proxy Authentication
Current Time: Sat Jul 19 02:58:56 EDT 2025
Powered by FUDForum. Page generated in 0.04249 seconds
